UMW
R
General Description
The SN74LVC1G126 is a high performance single noninverting buffer operating
from a 1.65V to 5.5V supply. This device is
fabricated with advanced CMOS technology to achieve ultra-high speed with high
output drive.
SN74LVC1G126
Features
Designed for 1.65V to 5.5V VCC Operation
Overvoltage Tolerant Inputs
24 mA Balanced Output Sink and Source
Capability
● Near Zero Static Supply Current Substantially
Reduces System Power Requirements
● These Devices are Pb−Free and are RoHS
Compliant
● 3−State OE Input is Active− High
Pin Configuration
www.umw-ic.com
1
UTD Semiconductor Co.,Limited
UMW
R
SN74LVC1G126
Pin Function
(SC70-5/ SOT23-5)
PIN
1
2
3
4
5
FUNCTION
OE
INA
GND
Y
VCC
PIN
1
2
3
4
5
6
FUNCTION
OE
IN A
GND
Y
NC
VCC
DFN6
Block Diagram
Figure2: Logic Symbol
Functional Description
Function Table
Input
Output
OE
A
Y
H
L
L
H
H
H
L
X
Z
www.umw-ic.com
2
UMW
R
SN74LVC1G126
Absolute Maximum Ratings
Symbol
Parameter
Value
Unit
VCC
DC Supply Voltage
−0.5 to 7.0
V
VI
DC Input Voltage
−0.5 ≤VI ≤+7.0
V
VO
DC Output Voltage Output in Higher or Low State (Note 1)
−0.5 to VCC + 0.5
V
VI < GND
−50
mA
VOVCC
±50
mA
IIK
DC Input Diode Current
IOK
DC Output Diode Current
IO
DC Output Sink Current
±50
mA
ICC
DC Supply Current per Supply Pin
±100
mA
IGND
DC Ground Current per Supply Pin
±100
mA
TSTG
Storage Temperature Range
−65 to 150
TL
Lead Temperature, 1 mm from Case for 10 Seconds
260
TJ
Junction Temperature Under Bias
150
Thermal Resistance
θJA
SC70-5
SOT23-5
DFN6
435
300
423
℃/W
PD
Power Dissipation in Still Air at 85°C
200
mW
MSL
Moisture Sensitivity
Level 1
ESD Classification Human
ESD
ILatchup
Body Model (Note 2)
Machine Model (Note3)
Charged Device Model (Note 4)
Latchup Performance Above VCC and Below GND at 125°C
(Note 5)
2000
200
N/A
V
±100
mA
Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are
exceeded, device functionality should not be assumed, damage may occur and reliability may be affected.
1. IO absolute maximum rating must be observed.
2. Tested to EIA/JESD22−A114−A, rated to EIA/JESD22−A114−B.
3. Tested to EIA/JESD22−A115−A, rated to EIA/JESD22−A115−A.
4. Tested to JESD22−C101−A.
5. Tested to EIA/JESD78.
Recommended Operating Conditions
Symbol
Parameter
Min
Max
Unit
VCC
DC Supply Voltage Operating
Date Retention
1.65
1.5
5.5
5.5
V
VIN
DC Input Voltage
V
VOUT
DC Output Voltage (High or Low State)
V
TA
Operating Temperature Range
-40
85
5
ns/V
Input Rise and Fall Time
tr,tf
VCC = 2.5 V ±0.2 V
VCC = 3.0 V ±0.3 V
VCC = 5.0 V ±0.5 V
Functional operation above the stresses listed in the Recommended Operating Ranges is not implied.
www.umw-ic.com
3
UMW
R
SN74LVC1G126
Electrical Characteristics
DC ELECTRICAL CHARACTERISTICS
Symbol
Parameter
VIH
High−Level
Input Voltage
1.65to1.95
2.3 to 5.5
VIL
Low−Level
Input Voltage
1.65to1.95
2.3 to 5.5
VOH
VOL
High−Level
Output
Voltage VIN =
VIL
Low−Level
Output
Voltage VIN =
VIH
Condition
VCC(V)
TA = 25 ℃
Typ
Min
Max
0.75Vcc
0.7Vcc
−40℃ ≤TA≤85℃
Min
Max
0.75Vcc
0.7Vcc
0.25Vcc
0.3Vcc
V
0.25Vcc
0.3Vcc
IOH =−100uA
1.65to5.5
Vcc−0.1
Vcc
Vcc−0.1
IOH =−3mA
1.65
1.29
1.52
1.29
IOH =−8mA
2.3
1.9
2.1
1.9
IOH =−12mA
2.7
2.2
2.4
2.2
IOH =−16mA
3.0
2.4
2.7
2.4
IOH =−24mA
3.0
2.3
2.5
2.3
IOH =-32mA
4.5
3.8
4.0
3.8
IOH =100uA
1.65to5.5
0.0
0.1
0.1
IOL =3mA
1.65
0.08
0.24
0.24
IOL =8mA
2.3
0.20
0.3
0.3
IOL =12mA
2.7
0.22
0.4
0.4
IOL =16mA
3.0
0.28
0.4
0.4
IOL =24mA
3.0
0.38
0.55
0.55
IOL =32mA
4.5
0.42
0.55
0.55
±0.1
IIN
Input
Leakage
Current
VIN = 5.5V or
GND
0 to 5.5
IOFF
Power
Off
Leakage
Current
VIN = 5.5V or
VOUT = 5.5V
ICC
Quiescent
Supply
Current
VIN = 5.5V or
GND
5.5
1
Unit
V
V
V
±1.0
uA
10
uA
10
uA
Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless
otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under
different conditions.
www.umw-ic.com
4
UMW
R
SN74LVC1G126
AC ELECTRICAL CHARACTERISTICS
tr=tf= 2.5ns
Symbol
Parameter
Condition
RL= 1MΩ
CL= 15 pF
tPD
Propagation Delay
(Figure3 and 4)
RL= 1MΩ CL= 15
pF
RL= 500Ω CL =50
pF
RL= 1MΩ CL= 15
pF
RL= 500Ω CL=50
pF
tPZL,
tPZH
tPLZ,
tPHZ
Output Enable
Time
(Figure5 and 6)
Output Disable
Time
(Figure5 and 6)
RL= 500Ω
CL=50 pF
RL= 500Ω
CL=50 pF
−40℃
≤TA≤85℃
TA = 25 ℃
VCC(V)
Min
Typ
Max
Min
Max
1.65
2.0
10.1
12.9
2.0
13.9
1.8
2.0
9.1
11.6
2.0
12.4
2.5
0.2
6.0
7.7
0.8
8.2
0.8
5.0
6.5
0.5
7.0
1.2
5.6
7.1
1.5
7.6
0.5
4.4
5.6
0.5
6.1
0.8
4.8
6.1
0.8
6.6
1.65
2.0
12.9
15.8
2.0
16.8
1.8
2.0
10.8
13.2
2.0
14.1
2.5
1.5
7.2
8.8
1.5
9.4
3.3
1.5
5.8
7.1
1.5
7.6
5.0
0.8
4.5
5.5
0.8
5.9
1.65
2.0
11.5
14.1
2.0
15.1
1.8
2.0
9.8
12.0
2.0
12.8
2.5
1.5
7.7
9.5
1.5
10.1
3.3
1.0
7.2
8.8
1.0
9.4
5.0
0.5
5.4
6.8
0.5
7.3
3.3
Unit
ns
5.0
ns
ns
CAPACITIVE CHARACTERISTICS
Symbol
Parameter
Condition
Typical
Unit
CIN
Input Capacitance
VCC= 5.5 V,VI = 0 V or VCC
>2.5
pF
CPD
Power Dissipation Capacitance
(Note 6)
10MHz,VCC = 3.3 V, VI = 0 V or VCC
10MHz, VCC = 5.5 V, VI = 0 V or VCC
4
4
pF
6. CPD is defined as the value of the internal equivalent capacitance which is calculated from the operating current
consumption without load. Average operating current can be obtained by the equation:
ICC(OPR)=CPD*VCC*fin+ICC*CPD is used to determine the no−load dynamic power consumption;
PD=CPD*VCC2*fin+ICC*VCC*Fig.
www.umw-ic.com
5
UMW
R
SN74LVC1G126
PROPAGATION DELAYS:
tR=tF=2.5ns, 10% to 90%; f=1MHZ;
tW=500ns
Figure3. Switch Waveform
S1
RT=50Ω(typ)
Figure4. Test Circuit
2*VCC
open
VCC
GND
OE
A
RL
Y
CL
RL
Figure5. Output enable/disable Time Test Circuit
VCC
EN
50%
50%
GND
tPZL
output
tPLZ
50%
VOL+0.3V
VOL
tPZH
tPHZ
VOH
VOH-0.3V
output
50%
Figure6. Output enable/disable Waveform
www.umw-ic.com
6
UMW
R
SN74LVC1G126
Package Dimension
SC70-5
www.umw-ic.com
7
UMW
R
SN74LVC1G126
SOT23-5
www.umw-ic.com
8
UMW
R
SN74LVC1G126
DFN6
www.umw-ic.com
9
UMW
R
SN74LVC1G126
Orderinginformation
Order code
UMW SN74LVC1G126DBVR
UMW SN74LVC1G126DCKR
UMW SN74LVC1G126DRYR
www.umw-ic.com
Marking code
C265
CNK
CN
Package
SOT23 5
SC70-5
SC70-5
10
Baseqty
3000
3000
5000
Deliverymode
Tape and reel
Tape and reel
Tape and reel
很抱歉,暂时无法提供与“SN74LVC1G126DBVR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.674711+0.21771
- 10+1.1381710+0.14796
- 25+0.9984325+0.12980
- 100+0.85123100+0.11066
- 250+0.78014250+0.10142
- 500+0.73726500+0.09584
- 1000+0.701981000+0.09126
- 国内价格 香港价格
- 3000+0.658463000+0.08560
- 6000+0.637156000+0.08283
- 9000+0.626479000+0.08144
- 15000+0.6146415000+0.07991
- 21000+0.6077321000+0.07901
- 30000+0.6010930000+0.07814
- 国内价格
- 10+0.16275
- 100+0.15225
- 500+0.14175
- 2000+0.12600
- 5000+0.12075
- 10000+0.11760
- 国内价格
- 1+0.28296
- 200+0.18360
- 1500+0.15876
- 3000+0.14040
