NJM4558D-#ZZZB
NJM4558D-#ZZZB
    JRC(⽇本无线)
    DIP-8
    双运算放大器
NJM4558D-#ZZZB 数据手册
NJM4558/4559 DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM4558/4559 integrated circuit is a dual high-gain operational amplifier internally compensated and constructed on a single silicon chip using an advanced epitaxial process. Combining the features of the NJM741 with the close parameter matching and tracking of a dual device on a monolithic chip results in unique performance characteristics. Excellent channel separation allows the use of the dual device in single NJM741 operational amplifier applications providing density. It is especially well suited for applications in differential-in, differential-out as well as in potentiometric amplifiers and where gain and phase matched channels are mandatory. ■ FEATURES ● Operating Voltage ● High Voltage Gain ● High Input Resistance ● Bipolar Technology ● Package Outline ■ PACKAGE OUTLINE NJM4558D NJM4559D ( DIP8 ) NJM4558M NJM4559M ( DMP8 ) NJM4558V ( SSOP8 ) ( ±4V~±18V ) ( 100dB typ. ) ( 5MΩ typ. ) NJM4558L NJM4559L ( SIP8 ) NJM4558E ( SOP8 ) DIP8, DMP8, SIP8 SOP8 JEDEC 150mil (only NJM4558), SSOP8 (only NJM4558) ■ PIN CONFIGURATION ( Top View ) 1 8 A 2 A B 7 B 3 4 6 5 NJM4558D, NJM4558M, NJM4558E, NJM4558V NJM4559D, NJM4559M 1 2 3 4 5 NJM4558L NJM4559L 6 7 8 PIN FUNCTION 1. A OUTPUT 2. A - INPUT 3. A +INPUT 4. V5. B +INPUT 6. B - INPUT 7. B OUTPUT 8. V+ ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) V+ - INPUT + INPUT OUTPUT VVer.2013-11-05 -1- NJM4558/4559 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL V+/VVID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 30 ± 15 ( note1 ) ( DIP8 ) 500 ( DMP8 ) 300 ( SOP8 ) 300 ( SSOP8 ) 250 ( SIP8 ) 800 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note1 ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( V+/V-=±15V,Ta=25˚C ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Resistance Large Signal Voltage Gain Maximum Output Voltage Swing 1 Maximum Output Voltage Swing 2 Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current Slew Rate NJM4558 NJM4559 Equivalent Input Noise Voltage (note2) Gain Bandwidth Product NJM4558 NJM4559 SYMBOL VIO IIO IB RIN AV VOM1 VOM2 VICM CMR SVR ICC SR SR VNI GB TEST CONDITION RS≤10kΩ RL≥2kΩ,VO=±10V RL≥10kΩ RL≥2kΩ RS≤10kΩ RS≤10kΩ RIAA,RS=2.2kΩ,30kHz LPF MIN. 0.3 86 ± 12 ± 10 ± 12 70 76.5 - TYP. 0.5 5 25 5 100 ± 14 ± 13 14 90 90 3.5 MAX. 6 200 500 5.7 UNIT mV nA nA MΩ dB V V V dB dB mA - 1 2 1.4 - V/µs V/µs µVrms 3 6 MHz MHz (note2) In regard to Noise Standard, NJRC is preparing for special D Rank type products (VNI=1.8µV max.) except for SSOP package. -2- Ver.2013-11-05 NJM4558/4559 ■ TYPICAL CHARACTERISTICS Maximum Output Voltage Swing vs. Frequency Open Loop Voltage Gain vs. Frequency V+/V-=±15V, RL=2kΩ, Ta=25ºC 100 NJM4559 80 60 NJM4558 40 20 0 1 10 100 1k 10k 100k Frequency f [Hz] 1M 25 NJM4559 20 15 NJM4558 10 5 0 10M 1 28 26 24 22 20 18 16 14 12 100 1k Load Resistance RL [Ω] 10k Maximum Output Voltage Swing [V] Operating Current Icc [mA] 7 6 5 4 3 2 1 0 Ver.2013-11-05 1M 100 10 1 1 10 100 Frequency f [Hz] V+/V-=±15V, RL=10kΩ 15 8 -25 0 25 50 75 100 Ambient Temperature Ta [ºC] 100k 1k Maximum Output Voltage Swing vs. Temperature V+/V-=±15V -50 100 1k 10k Frequency f [Hz] V+/V-=±15V, RS=50Ω, AV=60dB, Ta=25ºC 1000 Operating Current vs. Temperature 9 10 Equivalent Input Noise Voltage vs. Frequency V+/V-=±15V, Ta=25ºC Equivalent Input Noise Voltage en [nV/√Hz] Maximum Output Voltage Swing Vopp [V] Maximum Output Voltage Swing vs. Load Resistance 30 V+/V-=±15V, RL=2kΩ, Ta=25ºC 30 Maximum Output Voltage Swing V opp [V] Open Loop Voltage Gain Av [dB] 120 125 -9 +VOM 14 -10 13 -11 12 -12 -12 -13 11 -13 -VOM -14 10 -50 -25 0 25 50 75 100 Ambient Temperature Ta [ºC] -14 125 -3- NJM4558/4559 ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. temperature 2 V+/V-=±15V 45 1.5 40 Input Bias Current IB [nA] Input Offset Voltage VIO [mV] Input Bias Current vs. Temperature V+/V-=±15V 1 0.5 0 -0.5 -1 -1.5 35 30 25 20 15 10 -2 5 -50 -25 0 25 50 75 100 Ambient Temperature Ta [ºC] 125 -50 Maximum Output Voltage Swing vs. Operating Voltage Ta=25ºC 9 8 10 Operating Current ICC [mA] Maximum Output Voltage Swing [V] 125 Operating Current vs. Operating Voltage RL=2kΩ, Ta=25ºC 15 -25 0 25 50 75 100 Ambient Temperature Ta [ºC] +VOM 5 0 -5 -VOM -10 7 6 5 4 3 2 1 -15 0 ±6 ±8 ±10 ±12 ±14 Operating Voltage V+/V- [V] ±16 0 ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 Operating Voltage V+/V- [V] [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2013-11-05
NJM4558D-#ZZZB 价格&库存
很抱歉,暂时无法提供与“NJM4558D-#ZZZB”相匹配的价格&库存,您可以联系我们找货
NJM4558D-#ZZZB
    • 1+2.40560
    库存:28
