DIO2501CS14
DIO2501CS14
    DIOO(帝奥)
    SOIC-14
    2-VRMS音频线路驱动器与集成功能
DIO2501CS14 数据手册
Rev 1.0 0 D DIO250 01 2-Vrms Audio 2 A L Line Driiver with h Integrrated th O One-ch, , 6 -Ord der SD Video V F Filter F Feature s  De escriptions Line Output: able to o drive 600o ohm and 10k kΩ  2-Vrms With 3.3 3V Supply Voltage V driv ver and Audio A driver, with tw wo separate ed  No Pop/Clicks Noise at the e line outputt mo odules, the Audio Lin ne Driver module an nd en Power ON N/OFF whe    One-ch 6th-order SD Video o filter driverr module. No Need for Ou utput DC-Blo ocking e Audio Lin ne Driver allow for the e removal of o The pacitors Cap  The e DIO2501 is i an integrrated solution for Vide eo outtput AC- coupling capa acitors. It is s designed to t Acc cepting Diffe erential Inpu ut t th SD Filter: One-ch 6 -order 11M MHz SD filterrs opttimize the audio driv ver circuit performanc ce  6dB B Output Driver Gain an nd while reducing g the BOM cost by eliminating th he  Driv ve Dual Vide eo Load perripheral  Tran nsparent Input Clampin ng red duction. Fea aturing diffe erential inpu ut mode, gaiin  AC or DC Coup pled Inputs/O Outputs ran nge of ±1 V/V V to ±10 V V/V can be achieved via  Tran nsparent Input Clampin ng discrete omponents co for nois se extternal gain resistor r setting. Optimize ed Frequenc cy Respons se between The e 6th-order SD Video o filter driv ver provide es 20H Hz–20kHz imp proved imag ge quality co ompared witth passive LC L filte ers and dis screte drive ers solution n, especially A Applica tions suited for stan ndard definittion video signals. s It ca an be directly driv ven by a DC C-coupled DAC output or o  DVD Pla ayers  Video Amplifiers  Set-Top p Boxes and d bias circuitry may be used iff AC-couple ed  Persona al Video Rec corders inp puts are requ uired. The output can also a drive AC A  Communications Devices or DC coupled d single (150 0Ω) or dual (75Ω) loads. d signal. Intternal diode e-like clamp ps an AC-coupled The e DC couplin ng capacitors can be re emoved. O Orderin g Inform mation Order Pa art Number DIO2501CS14 4 Top p Marking D DIO2501 TA Green/R RoHS -40 to +85°C Package e SOIC-14 Tape & Reel, 2500     w www.dioo.com   © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1      D DIO250 01 SOIC-14 VCC 1 14 GN ND VIN 2 13 VOUT -INR 3 12 L -INL O OUTR 4 11 OU UTL EN 5 10 GN ND VSS 6 9 VDD 8 CP CN 7 1 1 M H z , 6 t h O rd e r Charge Pump Figure 1 Pin Ass signment P Des Pin scription n Pin Nam me VCC Video filter driver pow wer supply VIN Video filter driver Inp put -INR Right channel Negattive Input OUTR EN Enable e input, active--low Supplyy voltage outpu ut CN Charg ge-pump flying capacitor nega ative terminal CP Charg ge-pump flying capacitor posittive terminal VDD Audio line driver pos sitive supply GND GND OUTL Left ch hannel Output VOUT   Right channel Outpu ut VSS -INL w www.dioo.com De escription Left ch hannel Negativ ve Input Video filter driver Ou utput © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter P Ass Pin signmen nts      D DIO250 01 A Absolut te Maxim mum Ra atings S Stresses beyon nd those listed under “Absolu ute Maximum Rating” may cause c permane ent damage to o the device. These T are stresss ra atings only and d functional ope eration of the device d at these e or any other condition c beyon nd those indica ated in the ope erational section ns o the specificattions is not imp of plied. Exposure e to absolute maxim m rating co onditions for exttended periodss may affect de evice reliability. P Parameter Ra ating Unit Supply Voltag ge/VCC 0 to t 6.0 V Supply Voltag ge/VDD -0.3 to 4 V -0.3 to o VCC+0.3 V VSS-0.3 to VDD+0.3 V 6 600 Ω -0.3 to o VDD+0.3 V -65 to 150 °C Junction Tem mperature 1 150 °C Lead Temperrature Range 2 260 °C Input Voltage e/VIN Input Voltage e/-INR,-INL Minimum load impedance EN to GND Storage Temperature Rang ge HBM ESD Output Pinss 8 JEDEC: JESD22-A114 All Pins 5   w www.dioo.com   kV   © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter B Block D Diagram      D DIO250 01 T Recommen The nded Operating g Conditions ta able defines the e conditions fo or actual device e operation to e ensure optimal performance to th he datasheet specifications. DIOO D does nott recommend exceeding e them m or designing to Absolute Ma aximum Rating gs. Symbo ol P Parameter Min. Typ. Max. Unit 3.3 3.6 V 5.5 V VDD Sup pply Voltage 3 VCC Sup pply Voltage 3.135 VIH EN High level Inpu ut Voltage 60 % of VDD VIL EN Low level Inpu ut Voltage 40 % of VDD TA Ope erating Temperrature Range -40 85 °C Notes: The items belo N ow was div vided into two parts, the Audio o Line drive er module and the SD V Video filter module. E Electric al Charracteristtics for the Aud dio Line e Driverr modulle T Typical value: TA = 25°C, unle ess otherwise specified. s Symbol VOS Parrameter Min. Typ. Max. M Unit O Output Offset Voltage V VDD=3 3.3V, Input grou unded, Unity ga ain 0.9 mV P Power supply re ejection ratio VDD=3 3.3V 90 dB VOH H High level outpu ut voltage VDD=3 3.3V, RL=10kΩ VOL L Low level outpu ut voltage VDD=3 3.3V, RL=10kΩ IIH E High level in EN nput current IIL E Low level in EN nput current IDD S Supply current PSRR VO 3.1 V -3.05 - V VDD=3 3.3V, VI=VDD 1 µA VDD=3 3.3V, VI=0V 1 µA VDD=3 3.3V, VI= VDD, No N load 14 Shutdown mode, VDD=3.3V 0.8 mA 2.3 VRMS VO=2V VRMS, f=1kHz 0.0005 % C Channel crossta alk VO=2V VRMS, f=1kHz -105 dB S Signal noise rattio VO=2V VRMS,BW=22kH Hz A-weighted 105 dB 220 pF 10 µVRMSS O Output Voltage THD=1%, VDD=3.3V,, f=1kHz T Total harmonic distortion + noise XTALK SNR THD+N 2.0 90 CL M Maximum capacitive load VN N Noise output vo oltage GBW U Unity gain band dwidth 6.5 MHz AVO O Open loop volta age gain 165 dB fCP C Charge pump frrequency 300 kHz w www.dioo.com   Condittions BW=2 20Hz to 22kHz © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter R Recomm mended d Operating Co onditions      D DIO250 01 T Typical value: TA = 25°C, VCC C=5V, RSOURCE=37.5Ω, = RL=15 50Ω loads; all in nputs are AC couple c with 0.1µF; all outputs s are AC couple ed w 220µF; unless otherwise specified. with Symbol Pa arameter Conditions Min.. Typ. Max. M Unit 8 12 mA DC ELECTRIICAL CHARAC CTERISTICS ICC Supply Current VIN Video Inputt Voltage Range PSRR GND D Power Supp ply Rejection 1.4 VPP -50 dB DYNAMIC PE ERFORMANCE E AV Channel Ga ain 5.8 6.0 f1dB -1dB Bandw width 8.0 10.5 MHz f3dB -3dB Bandw width 9 11.8 MHz -40 dB Filter Respo onse f=27M MHz 6.2 dB DG Differential Gain 0.2 % DP Differential Phase 0.36 ° THD Output Disttortion f=1MH Hz 0.38 % XTALK Crosstalk f=1MH Hz -74 dB SNR Signal to No oise Ratio 70 dB 20 ns Group Dela ay f=400kkHz, 6.5MHz CLG_SD Chroma Luma Gain f=3.58 8MHz ref to SD D in at 400kHz CLD_SD Chroma Luma Delay f=3.58 8MHz ref to SD D in at 400kHz 95 100 5.5 105 % ns Notes: SNR=2 20 • log (714mV V / rms noise). Specifications subject to change without no otice. w www.dioo.com   © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter E Electric al Charracteristtics for the SD Video Filter F m module      D DIO250 01 vcc 0.1uF 1 10uF DIO2501 Vid deo Processor Rs VCC GND VIN VOUT -INR -INL OUTR OUTL EN GND VSS VDD CN CP 0.1uF 470 0pF RIGHT INPUT 6.8uF 43k 15 5k 30k RIG GHT OUT TPUT 47pF 3.3V Mute 75Ω Ω Video Cables 75Ω C1 47 70pF 15k 43k 47pF 30k 75Ω 6.8uF LEFT INPUT EFT LE OUT TPUT 100 k GPIO 33k 1µF OPTIONAL 3.3V Supply 0.1uF 10uF 1µF N Note: The valu ue of C1 is re ecommended d 2 to 4pF. A Applica tion No otes G Gain-Setting g Resistors Ranges R and d Input-Bloc cking Capacitors T gain-settting resistorss, RIN and RFB, must be chosen so that noise, sttability, and iinput capacittor size of th The he A Audio Line Driver are kep pt within acce eptable limitss. Voltage ga ain is defined as RFB divid ded by RIN. T Table 1 lists the recomm mended resistor value for f different gain setting gs. Selecting g values tha at are too lo ow d demands a la arge input acc-coupling ca apacitor CIN. Selecting values that are too high increases the e noise of th he a amplifier. T gain-settting resistor must The m be placced close to the input pins s to minimize e capacitive loading on these input pin ns a to ensure and e maximum stability. s Table 1 Resistor Va alues Recomm mended Input Res., Feedback RIN Re es., 22 kΩ 22 kΩ -1 V/V 15 kΩ 30 kΩ -2 V/V 10 kΩ 100 kΩ -10 V/V In nverting Gain n Figure 2 Differenttial, Inverting g and Non-inv verting Gain Configuration C ns w www.dioo.com   © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter T Typical A Applica ation      D DIO250 01 A Audio Line Driver. D These e capacitors block the dcc portion of the t audio so ource and allow the Aud dio Line Drive er in nputs to be properly p biased to provide e maximum performance e. C Charge Pum mp Flying Ca apacitor and d VSS Capac citor T charge pump The p flying capacitor c servves to transffer charge du uring the gen neration of the negative supply voltage. T The VSS cap pacitor mustt be at leastt equal to the charge pu ump capacito or in order tto allow max ximum charg ge trransfer. Low w-ESR capaccitors are an n ideal selecttion, and a value v of 1μF F is typical. Capacitor va alues that arre s smaller than 1μF can be used, u but the e maximum output o voltage may be red duced and th he device ma ay not operatte to o specificatio ons. D Decoupling C Capacitors T Audio Line Driver req The quires adequ uate power supply s decou upling to enssure that the e noise and total t harmon nic d distortion (TH HD) are low. A good low equivalent-se e eries-resistance (ESR) ceramic c capa acitor, typically 1μF, place ed a close as possible to the as e device VDD D lead workss best. Placin ng this decou upling capaciitor close to the t Audio Lin ne D Driver is important for the performan nce of the am mplifier. For filtering lowe er-frequencyy noise signa als, a 10μF or o g greater capaccitor placed near n the audio power amplifier would also help, bu ut it is not req quired in mos st application ns b because of th he high PSRR R of this devvice. P Pop-Free Po ower-Up P Pop-free pow wer up is ensured by keep ping the EN (enable pin) low during power-supply p y ramp up an nd ramp down. T EN pin sh The hould be kep pt low until the input ac-co oupling capa acitors are fullly charged b before asserting the EN pin h high to achievve pop-less power p up. Figure 4 illustrrates the preferred seque ence. Supply EN Supply Ramp Time for AC -Cou upling capacitors to ch arge   Figure 4 Power-Up Sequences S C Capacitive L Load T Audio Lin The ne Driver hass the ability to t drive a hig gh capacitive load up to 220 2 pF directly. Higher ca apacitive load ds c be accep can pted by addin ng a series re esistor of 47 Ω or larger. w www.dioo.com   © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter D input-bloccking capacitors are required to be added DC a in serries with the audio signal into the inp put pins of th he      D DIO250 01 SOIC C-14 COMMON N DIMENSIONS S (U UNITS OF MEA ASURE=MILLIM METER) Symb bol MIN NOM MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 A3 0.55 0.65 0.75 b 0.36 0.49 b1 0.35 0.40 0.45 c 0.17 0.25 c1 0.17 0.20 0.23 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC C L 0.45 0.60 0.75 L1 1.04REF F L2 0.25BSC C R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 6° 8° 10° Θ1 6° 8° 10° Θ2 5° 7° 9° Θ3 5° 7° 9° Θ4     w www.dioo.com   © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter P Physica al Dimen nsions:      D DIO250 01 CONTACT US Dioo is a profeessional design and sales corporation for high-quality and perrformance analoog semiconducttors. The compaany focuses on industry marke ets, such as, ce ell phone, handh held products, laptop, l and med dical equipmentts and so on. D Dioo’s product fa amilies include analog signal processing and d amplifying, LE ED drivers and charger IC. Go o to http://www.d dioo.com for a complete list of Dioo product families. ation, or full data asheet, please contact c with ourr Sales Departm ment or Represe entatives. For additional product informa w www.dioo.com   © 2014 DIOO MICROCIRCU UITS CO., LTD D DIO O2501• Rev. 1.0 1 2-Vrms Audio Line Driver with Integrated 6th -Order SD Video Filter
