GS339/339A
LOW POWER LOW OFFSET VOLTAGE QUAD COMPARATORS
Features
l
Wide Supply Voltage Range
l
Single Supply: 2.0V to 36V
l
Dual Supplies: ±1.0V to ±18V
l
Low Output Saturation Voltage: 200mV at 4mA
l
Low Supply Current Drain: 0.9mA
l
Open Collector Output
l
Low Input Bias Current: 25nA (Typ)
l
Small Package:
l
Low Input Offset Current: 5.0nA (Typ)
GS339/339A Available in SOP-14 and TSS0P-14
l
Low Input Offset Voltage: ±2.0mV (Typ)
Packages
l
Input Common Mode Voltage Range Includes
l
Differential Input Voltage Range Equals to the
Power Supply Voltage
Ground
General Description
The GS339/339A consist of four independent precision voltage comparators with a typical offset voltage of 2.0mV
and high gain. They are specifically designed to operate from a single power supply over wide range of voltages.
Operation from split power supply is also possible and the low power supply current drain is independent of the
magnitude of the power supply voltage.
The GS339/339A series are compatible with industry standard 339.
The GS339A has more stringent input offset voltage than the GS339.
The GS339 is available in SOP-14 and TSSOP-14 packages, and the GS339A is available in SOP-14 package.
Applications
l
Battery Charger
l
DC-DC Module
l
Cordless Telephone
l
PC Motherboard
l
Switching Power Supply
l
Communication Equipment
Pin Configuration
GS339/339A
SOP-14/TSSOP-14 Package
Figure 1. Pin Assignment Diagram
March 2020-REV_V0
1/7
GS339/339A
Functional Block Diagram
Figure 2. Functional Block Diagram of GS339/339A (Each comparator)
Absolute Maximum Ratings
Condition
Symbol
Max
Vcc
±20V or 40V
VI(DIFF)
40V
Input Voltage
VI
-0.3V~40V
Operating Junction Temperature
TJ
150°C
Tstg
-65°C ~+150°C
Differential input voltage
Storage Temperature Range
Note 1: Stresses greater than those listed under "Absolute Maximum Ratings" may cause permanent damage to the device.
These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated
under "Recommended Operating Conditions" is not implied. Exposure to "Absolute Max-imum Ratings" for extended periods may
affect device reliability.
Note 2: This input current will only exist when the voltage at any of the input leads is driven negative. It is due to the
collector-base junction of the input PNP transistors becoming forward biased and thereby acting as input diode clamps. In
addition to this diode action, there is also lateral NPN parasitic transistor action on the IC chip. This transistor action can cause
the output voltages of the comparators to go to the V+ voltage level (or to ground for a large overdrive) for the time duration that
an input is driven negative. This is not destructive and normal output states will re-establish when the input voltage, which was
negative, again returns to a value greater than -0.3 VDC at 25°C).
Package/Ordering Information
MODEL
CHANNEL
GS339
Quad
GS339A
Quad
March 2020-REV_V0
PACKAGE
PACKAGE
MARKING
DESCRIPTION
OPTION
INFORMATION
GS339-SR
SOP-14
Tape and Reel,2500
GS339
GS339-TR
TSSOP-14
Tape and Reel,3000
GS339
GS339A-SR
SOP-14
Tape and Reel,2500
GS339
GS339A-TR
TSSOP-14
Tape and Reel,3000
GS339
ORDER NUMBER
2/7
GS339/339A
Electrical Characteristics
o
o
o
Limits in standard typeface are for TA=25 C, bold typeface applies over TA=-40 C to 85 C (Note 3), VCC=5V, GND=0V, unless
otherwise specified.
o
o
Note 3: These specifications are limited to -40 C≤ TA ≤85 C. Limits over temperature are guaranteed by design, but not
tested in production.
Note 4: The input common-mode voltage of either input signal voltage should not be allowed to go negatively by
o
o
more than 0.3V (at 25 C). The upper end of the common-mode voltage range is VCC-1.5V (at 25 C), but either or
both inputs can go to +36V without damages,
March 2020-REV_V0
independent of the magnitude of the VCC.
3/7
GS339/339A
Typical Performance characteristics
March 2020-REV_V0
4/7
GS339/339A
Typical Applications
March 2020-REV_V0
5/7
GS339/339A
Package Information
SOP-14
March 2020-REV_V0
6/7
GS339/339A
TSSOP-14
March 2020-REV_V0
7/7
很抱歉,暂时无法提供与“GS339-SR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.41329
- 50+1.11942
- 150+0.99350
- 500+0.83636
