TP2314-SR
TP2314-SR
    3PEAK(思瑞浦)
    SOP14
    低噪声,供电电压2.2~5.5V,带宽增益积10MHz,轨到轨输入/输出四通道运放
TP2314-SR 数据手册
3PEAK TP2311/TP2312 /TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Features Description  Gain-bandwidth Product: 10 MHz  Low Noise: 8.2 nV/√Hz(f= 1kHz)  Slew Rate: 7 V/μs  Offset Voltage: 50 μV (max)  EMIRR IN+: 88 dB( under 2.4GHz)  Low THD+N: 0.0005%  Supply Range: 2.2 V to 5.5 V The TP2311 series products are very high precision amplifiers featuring very low noise, low offset voltage, high bandwidth, low input bias current and low temperature drift making them the ideal choice for applications requiring both high DC accuracy and AC performance. The combination of precision, low noise, and high bandwidth provides the user with outstanding value and flexibility relative to similar competitive parts.  Supply Current: 1.4 mA/ch Applications for these amplifiers include precision active  Low Input Bias Current: 0.3pA Typical  Rail-to-Rail I/O  High Output Current: 70 mA (1.0V Drop)  –40°C to 125°C Operation Range  Robust 6kV HBM and 2kV CDM ESD Rating filters, medical and analytical instrumentation, precision power supply controls, and industrial controls requiring high gains. Featuring low THD+N, the TP2311 series is also excellent for consumer audio applications, particularly for single-supply systems. The TP2311 is single channel version available in 8-pin SOIC and 5-pin SOT23 packages. The TP2312 is dual channel version available in 8-pin SOIC, SOT and MSOP packages. The TP2314 is quad channel version available in 14-pin SOIC and TSSOP packages. Applications  Sensor Signal Conditioning  Consumer Audio  Multi-Pole Active Filters  Control-Loop Amplifiers  Communications  Security  Scanners 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Pin Configuration (Top View) TP2311 8-Pin SOIC TP2312 8-Pin SOIC/MSOP/SOT (-S Suffix) (-S ,-V and -T Suffixes) 1 8 NC Out A 1 ﹣In 2 7 ﹢Vs ﹣In A 2 ﹢In 3 6 Out ﹢In A 3 ﹣Vs 4 5 NC ﹣Vs 4 Out 1 ﹣Vs 2 +In 3 A B ﹢Vs 7 Out B 90 6 ﹣In B 80 5 ﹢In B 70 TP2311 5-Pin SOT23 TP2314 14-Pin SOIC/TSSOP (-T Suffix) (-S and -T Suffixes) 5 ﹢Vs Out A 1 ﹣In A 2 A 4 -In Out D 13 ﹣In D D 3 12 ﹢In D ﹢Vs 4 11 ﹣Vs ﹢In B 5 10 ﹢In C ﹣In B 6 9 ﹣In C Out B www.3peakic.com.cn 14 ﹢In A B 7 100 8 C 8 Out C EMIRR IN+ (dB) NC EMIRR IN+ vs. Frequency 60 50 40 30 20 10 0 40 400 4000 Frequency (MHz) Rev. A03 1 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Order Information Model Name TP2311 TP2312 TP2314 Order Number Package Marking Information Transport Media, Quantity TP2311-SR 8-Pin SOIC Tape and Reel, 4,000 TP2311 TP2311-TR 5-Pin SOT23 Tape and Reel, 3,000 311 TP2312-SR 8-Pin SOIC Tape and Reel, 4,000 TP2312 TP2312-VR 8-Pin MSOP Tape and Reel, 3,000 TP2312 TP2312-TR 8-Pin SOT23 Tape and Reel, 3,000 312 TP2314-SR 14-Pin SOIC Tape and Reel, 2,500 TP2314 TP2314-TR 14-Pin TSSOP Tape and Reel, 3,000 TP2314 Absolute Maximum Ratings Note 1 Supply Voltage: V+ – V– Note 2............................7.0V Input Voltage............................. V– – 0.3 to V+ + Operating Temperature Range........–40°C to 125°C 0.3 Maximum Junction Temperature................... 150°C ±20mA Storage Temperature Range.......... –65°C to 150°C Output Short-Circuit Duration Note 4…......... Indefinite Lead Temperature (Soldering, 10 sec) ......... 260°C Input Current: +IN, –IN Note 3.......................... Current at Supply Pins……………............... ±60mA Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The op amp supplies must be established simultaneously, with, or before, the application of any input signals. Note 3: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. Note 4: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD MIL-STD-883H Method 3015.8 6 kV CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E 2 kV Thermal Resistance 2 Package Type θJA θJC Unit 5-Pin SOT23 250 81 ° C/W 8-Pin SOIC 158 43 ° C/W 8-Pin MSOP 210 45 ° C/W 8-Pin SOT23 196 70 ° C/W 14-Pin SOIC 120 36 ° C/W 14-Pin TSSOP 180 35 ° C/W Rev. A03 www.3peakic.com.cn TP2311/TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Electrical Characteristics The specifications are at TA = 27° C. VS = +2.2 V to +5.5 V, or ± 1.1 V to ± 2.75 V, RL = 2kΩ, CL =100pF.Unless otherwise noted. SYMBOL VOS VOS TC IB PARAMETER CONDITIONS MIN TYP MAX UNITS -50 +50 2 μV Input Offset Voltage VCM = VDD/2 Input Offset Voltage Drift -40° C to 125° C ±4 1 TA = 27 ° C 0.3 pA TA = 85 ° C 150 pA TA = 125 ° C 300 pA Input Bias Current 0.001 0.1 μV/° C IOS Input Offset Current Vn Input Voltage Noise f = 0.1Hz to 10Hz 3.14 μVPP en in Input Voltage Noise Density Input Current Noise 8.2 nV/√Hz fA/√Hz CIN Input Capacitance f = 1kHz f = 1kHz Differential Common Mode VCM = 2.5V CMRR PSRR Common Mode Rejection Ratio Common-mode Input Voltage Range Power Supply Rejection Ratio AVOL VCM 90 2 7.76 6.87 106 V– -0.1 pA pF 130 dB V+-0.1 V VCM = 2.5V 82 100 130 dB Open-Loop Large Signal Gain RLOAD = 1kΩ 100 130 150 dB VOL, VOH Output Swing from Supply Rail RLOAD = 100kΩ 10 20 50 mV ROUT Closed-Loop Output Impedance G = 1, f =1MHz, IOUT = 0 0.2 Ω RO Open-Loop Output Impedance f = 1kHz, IOUT = 0 125 Ω ISC Output Short-Circuit Current Sink or source current 130 mA VDD Supply Voltage IQ 100 2.2 Quiescent Current per Amplifier 1.4 5.5 V 1.95 mA PM Phase Margin RLOAD = 1kΩ, CLOAD = 60pF 60 ° GM Gain Margin RLOAD = 1kΩ, CLOAD = 60pF 8 dB Gain-Bandwidth Product f = 1kHz AV = 1, VOUT = 0V to 10V, CLOAD = 100pF, RLOAD = 2kΩ 10 MHz 7 V/μs 414 0.85 0.85 kHz 0.0005 % 110 dB GBWP SR FPBW tS THD+N Xtalk Slew Rate Full Power Bandwidth Note 1 Settling Time, 0.1% Settling Time, 0.01% Total Harmonic Distortion and Noise Channel Separation AV = –1, 1V Step f = 1kHz, AV =1, RL = 2kΩ, VOUT = 1Vp-p f = 1kHz, RL = 2kΩ 3.0 μs Note 1: Full power bandwidth is calculated from the slew rate FPBW = SR/π • VP-P www.3peakic.com.cn Rev. A03 3 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. Offset Voltage Production Distribution Unity Gain Bandwidth vs. Temperature 600 15 Number = 15489 pcs 14.9 500 14.8 14.7 GBW(MHz) Population 400 300 200 14.6 14.5 14.4 14.3 14.2 100 14.1 0 14 -50 -40 -30 -20 -10 0 10 20 30 40 50 -40 -20 0 Offset Voltage(uV) 20 40 Open-Loop Gain and Phase 80 100 120 Input Voltage Noise Spectral Density 140 1000 330 120 100 VCC= +5V RL= 1kΩ 40 30 20 Phase (°) 130 60 -70 0 -20 Noise(nV/√Hz) 230 80 Gain(dB) 60 Temperature(℃) 100 10 -170 -40 -60 0.1 10 1k 100k 10M 1 -270 1000M 1 10 Input Bias Current vs. Temperature 1k 10k 100k 1M Input Bias Current vs. Input Common Mode Voltage 5.00E-16 1.00E-11 Input Bias Current(A) 1.00E-13 Input Bias Current(A) 100 Frequency(Hz) Frequency (Hz) 1.00E-15 1.00E-17 5.00E-17 1.00E-19 5.00E-18 1.00E-21 -10 10 30 50 70 90 110 Temperature(℃) 4 Rev. A03 130 150 0 1 2 3 4 5 6 Common Mode Voltage(V) www.3peakic.com.cn TP2311/TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) CMRR vs. Frequency 170 180 160 160 150 140 120 140 CMRR(dB) CMRR(dB) Common Mode Rejection Ratio 130 120 100 80 60 110 40 100 20 90 0 0 1 2 3 4 1 100 Common Mode Voltage(V) 1M 100M Short Circuit Current vs. Temperature 1.48 200 1.46 180 160 1.44 ISINK 140 1.42 Ishort(mA) Supply current(mA) Quiescent Current vs. Temperature 1.4 1.38 120 100 1.36 ISOURCE 80 60 1.34 40 1.32 20 0 1.3 -40 -15 10 35 60 85 -50 110 0 50 100 150 Temperature(℃) Temperature(℃) Power-Supply Rejection Ratio Quiescent Current vs. Supply Voltage 1.8 140 1.6 Supply current (mA) 120 100 PSRR(dB) 10k Frequency(Hz) PSRR+ 80 PSRR- 60 40 20 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 1 100 10k Frequency(Hz) www.3peakic.com.cn 1M 1.5 2.5 3.5 4.5 5.5 Supply Voltage (V) Rev. A03 5 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) Power-Supply Rejection Ratio vs. Temperature CMRR vs. Temperature 145 140 140 135 135 CMRR(-dB) PSRR(-dB) 130 125 120 130 125 120 115 115 110 110 105 105 100 100 -40 -15 10 35 60 85 -40 110 -15 10 35 60 85 110 Temperature(℃) Temperature(℃) EMIRR IN+ vs. Frequency Large-Scale Step Response 100 90 Output Voltage (2V/div) EMIRR IN+ (dB) 80 70 60 50 40 30 20 Gain= +1 RL= 10kΩ 10 0 40 400 4000 Frequency (MHz) Time (20μs/div) Time (500ns/div) 6 Positive Over-Voltage Recovery 2V/div Gain= +10 ±V= ±2.5V 1V/div Gain= +10 ±V= ±2.5V 1V/div 2V/div Negative Over-Voltage Recovery Rev. A03 Time (500ns/div) www.3peakic.com.cn TP2311/TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) 0.1 Hz TO 10 Hz Input Voltage Noise Offset Voltage vs Common-Mode Voltage 500 2μV/div Offset voltage(μV) 0 Vcc=±2.5V -500 -1000 -1500 -2000 -2500 -3000 -2.5 5s/div -0.5 0.5 1.5 2.5 Common-mode voltage(V) Positive Output Swing vs. Load Current Negative Output Swing vs. Load Current 0 140 -20 -40℃ 120 25℃ -40 100 -60 Iout(mA) +125℃ Iout(mA) -1.5 80 60 -80 -100 -120 +125℃ -140 40 25℃ -160 20 -40℃ -180 0 0 1 2 3 Vout Dropout (V) www.3peakic.com.cn 4 5 -200 0 1 2 3 4 5 Vout Dropout (V) Rev. A03 7 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Pin Functions -IN: Inverting Input of the Amplifier. possible should be used between power supply pins or +IN: Non-Inverting Input of Amplifier. between supply pins and ground. OUT: Amplifier Output. The voltage range extends to V- or -Vs: Negative Power Supply. It is normally tied to within mV of each supply rail. ground. It can also be tied to a voltage other than V+ or +Vs: Positive Power Supply. Typically the voltage ground as long as the voltage between V+ and V– is from is from 2.2V to 5.5V. Split supplies are possible as long 2.2V to 5.5V. If it is not connected to ground, bypass it as the voltage between V+ and V– is between 2.2V and with a capacitor of 0.1μF as close to the part as possible. 5.5V. A bypass capacitor of 0.1μF as close to the part as Operation The TP2311 series op amps can operate on a single-supply voltage (2.2 V to 5.5 V), or a split-supply voltage (±1.1 V to ±2.75 V), making them highly versatile and easy to use. The power-supply pins should have local bypass ceramic capacitors (typically 0.001 μF to 0.1 μF). These amplifiers are fully specified from +2.2 V to +5.5 V and over the extended temperature range of –40°C to +125°C. Parameters that can exhibit variance with regard to operating voltage or temperature are presented in the Typical Characteristics. Applications Information Input ESD Diode Protection The TP2311 incorporates internal electrostatic discharge (ESD) protection circuits on all pins. In the case of input and output pins, this protection primarily consists of current-steering diodes connected between the input and power-supply pins. These ESD protection diodes also provide in-circuit input overdrive protection, as long as the current is limited to 10 mA as stated in the Absolute Maximum Ratings table. Many input signals are inherently current-limited to less than 10 mA; therefore, a limiting resistor is not required. Figure 1 shows how a series input resistor (RS) may be added to the driven input to limit the input current. The added resistor contributes thermal noise at the amplifier input and the value should be kept to the minimum in noise-sensitive applications. Current-limiting resistor required if input voltage exceeds supply rails by >0.5V. V+ 500Ω +2.5V IN+ Ioverload 10mA max TP2311 VIN Vout 5kΩ 500Ω IN- -2.5V VINPUT ESD DIODE CURRENT LIMITING- UNITY GAIN Figure1. Input ESD Diode 8 Rev. A03 www.3peakic.com.cn TP2311/TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps PHASE REVERSAL The TP2311 op amps are designed to be immune to phase reversal when the input pins exceed the supply voltages, therefore providing further in-system stability and predictability. Figure 2 shows the input voltage exceeding the supply voltage without any phase reversal. Figure 2. No Phase Reversal EMI SUSCEPTIBILITY AND INPUT FILTERING Operational amplifiers vary in susceptibility to electromagnetic interference (EMI). If conducted EMI enters the device, the dc offset observed at the amplifier output may shift from the nominal value while EMI is present. This shift is a result of signal rectification associated with the internal semiconductor junctions. While all operational amplifier pin functions can be affected by EMI, the input pins are likely to be the most susceptible. The TP2311 operational amplifier family incorporates an internal input low-pass filter that reduces the amplifier response to EMI. Both common-mode and differential mode filtering are provided by the input filter. The filter is designed for a cutoff frequency of approximately 500 MHz (–3 dB), with a roll-off of 20 dB per decade. 100 90 EMIRR IN+ (dB) 80 70 60 50 40 30 20 10 0 40 400 4000 Frequency (MHz) Figure 3. TP2311 EMIRR IN+ vs Frequency www.3peakic.com.cn Rev. A03 9 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps ACTIVE FILTER The TP2311 is well-suited for active filter applications that require a wide bandwidth, fast slew rate, low-noise, single-supply operational amplifier. Figure 4 shows a 20-kHz, second-order, low-pass filter using the multiplefeedback (MFB) topology. The components have been selected to provide a maximally-flat Butterworth response. Beyond the cutoff frequency, roll-off is –40 dB/dec. The Butterworth response is ideal for applications that require predictable gain characteristics, such as the anti-aliasing filter used in front of an ADC. One point to observe when considering the MFB filter is that the output is inverted, relative to the input. If this inversion is not required, or not desired, a noninverting output can be achieved through one of these options: 1. adding an inverting amplifier; 2. adding an additional second-order MFB stage; R4 22kΩ R1 R2 R3 2.7kΩ 22kΩ 10kΩ VIN C1 3000pF C3 100pF ½ TP2311 VO C2 2000pF fp  20kHz Figure 4. TP2311 Configured as a Three-Pole, 20-kHz, Sallen-Key Filter PCB Surface Leakage In applications where low input bias current is critical, Printed Circuit Board (PCB) surface leakage effects need to be considered. Surface leakage is caused by humidity, dust or other contamination on the board. Under low humidity conditions, a typical resistance between nearby traces is 1012Ω. A 5V difference would cause 5pA of current to flow, which is greater than the TP2311/2312/2314 OPA’s input bias current at +27°C (±3pA, typical). It is recommended to use multi-layer PCB layout and route the OPA’s -IN and +IN signal under the PCB surface. The effective way to reduce surface leakage is to use a guard ring around sensitive pins (or traces). The guard ring is biased at the same voltage as the sensitive pin. An example of this type of layout is shown in Figure 1 for Inverting Gain application. 1. For Non-Inverting Gain and Unity-Gain Buffer: a) Connect the non-inverting pin (VIN+) to the input with a wire that does not touch the PCB surface. b) Connect the guard ring to the inverting input pin (V IN–). This biases the guard ring to the Common Mode input voltage. 2. For Inverting Gain and Trans-impedance Gain Amplifiers (convert current to voltage, such as photo detectors): a) Connect the guard ring to the non-inverting input pin (VIN+). This biases the guard ring to the same reference voltage as the op-amp (e.g., VDD/2 or ground). b) Connect the inverting pin (VIN–) to the input with a wire that does not touch the PCB surface. 10 Rev. A03 www.3peakic.com.cn TP2311/TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Guard Ring VIN+ VIN- +VS Figure 5 The Layout of Guard Ring Power Supply Layout and Bypass The TP2311/2312/2312 OPA’s power supply pin (VDD for single-supply) should have a local bypass capacitor (i.e., 0.01μF to 0.1μF) within 2mm for good high frequency performance. It can also use a bulk capacitor (i.e., 1μF or larger) within 100mm to provide large, slow currents. This bulk capacitor can be shared with other analog parts. Ground layout improves performance by decreasing the amount of stray capacitance and noise at the OPA’s inputs and outputs. To decrease stray capacitance, minimize PC board lengths and resistor leads, and place external components as close to the op amps’ pins as possible. Proper Board Layout To ensure optimum performance at the PCB level, care must be taken in the design of the board layout. To avoid leakage currents, the surface of the board should be kept clean and free of moisture. Coating the surface creates a barrier to moisture accumulation and helps reduce parasitic resistance on the board. Keeping supply traces short and properly bypassing the power supplies minimizes power supply disturbances due to output current variation, such as when driving an ac signal into a heavy load. Bypass capacitors should be connected as closely as possible to the device supply pins. Stray capacitances are a concern at the outputs and the inputs of the amplifier. It is recommended that signal traces be kept at least 5mm from supply lines to minimize coupling. A variation in temperature across the PCB can cause a mismatch in the Seebeck voltages at solder joints and other points where dissimilar metals are in contact, resulting in thermal voltage errors. To minimize these thermocouple effects, orient resistors so heat sources warm both ends equally. Input signal paths should contain matching numbers and types of components, where possible to match the number and type of thermocouple junctions. For example, dummy components such as zero value resistors can be used to match real resistors in the opposite input path. Matching components should be located in close proximity and should be oriented in the same manner. Ensure leads are of equal length so that thermal conduction is in equilibrium. Keep heat sources on the PCB as far away from amplifier input circuitry as is practical. The use of a ground plane is highly recommended. A ground plane reduces EMI noise and also helps to maintain a constant temperature across the circuit board. www.3peakic.com.cn Rev. A03 11 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Package Outline Dimensions SOT23-5 D A2 A1 θ L1 e Symbol E1 E e1 12 Rev. A03 Dimensions In Millimeters In Inches Min Max Min Max A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e b Dimensions 0.950TYP 0.037TYP e1 1.800 2.000 0.071 0.079 L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° www.3peakic.com.cn TP2311/TP2312 / TP2314 Package Outline Dimensions 10MHz Bandwidth, Low Noise Precision Op-amps SOT-23-8 Symbol www.3peakic.com.cn Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.600 3.000 0.102 0.118 e 0.65(BSC) 0.026(BSC) e1 0.975(BSC) 0.038(BSC) L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° Rev. A03 13 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Package Outline Dimensions SO-8 (SOIC-8) A2 C θ L1 A1 e E D Symbol E1 b 14 Rev. A03 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e 1.270 TYP 0.050 TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° www.3peakic.com.cn TP2311/TP2312 / TP2314 Package Outline Dimensions 10MHz Bandwidth, Low Noise Precision Op-amps MSOP-8 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol E E1 A A2 e b D 3.100 0.114 0.122 0.026 A1 R1 R θ L1 www.3peakic.com.cn L L2 Rev. A03 15 TP2311 / TP2312 / TP2314 10MHz Bandwidth, Low Noise Precision Op-amps Package Outline Dimensions TSSOP-14 Dimensions E1 E A A2 e c D In Millimeters Symbol MIN TYP MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 b 0.20 - 0.28 c 0.10 - 0.19 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e L A1 R1 R 0.65 BSC 0.45 0.60 0.75 L1 1.00 REF L2 0.25 BSC R 0.09 - - θ 0° - 8° θ L1 16 Rev. A03 L L2 www.3peakic.com.cn TP2311/TP2312 / TP2314 Package Outline Dimensions 10MHz Bandwidth, Low Noise Precision Op-amps SO-14 (SOIC-14) D E1 Dimensions E In Millimeters Symbol e b A A2 A1 MIN TYP MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 b 0.36 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e L www.3peakic.com.cn 1.27 BSC 0.45 0.60 0.80 L1 1.04 REF L2 0.25 BSC θ L L1 0.49 0° 8° θ L2 Rev. A03 17
TP2314-SR 价格&库存
很抱歉,暂时无法提供与“TP2314-SR”相匹配的价格&库存,您可以联系我们找货
TP2314-SR
  • 1+7.11720
  • 10+5.61600
  • 30+4.87080
  • 100+4.13640
  • 500+3.69360
  • 1000+3.45600
库存:4059
TP2314-SR
    • 1+4.06000
    • 100+3.39300
    • 1250+3.07400
    • 2500+2.94350
    库存:2528
    TP2314-SR
      • 10+2.09000
      库存:1941
      TP2314-SR
      • 1+6.45820
      • 10+5.09600
      • 30+4.41980
      • 100+3.75340
      库存:300
