WPM2037
WPM2037
Http//:www.willsemi.com
Single P-Channel, -20V, -3.6A , Power MOSFET
VDS (V)
Rds(on) (ȍ)
0.047@ VGS=̢4.5V
0.060@ VGS=̢2.5V
-20
0.076@ VGS=̢1.8V
SOT-23-6L
Descriptions
The WPM2037 is P-Channel enhancement MOS
Field
Effect
Transistor.
Uses
advanced
D
D
S
6
5
4
1
2
D
D
3
G
trench
technology and design to provide excellent RDS
(ON)
with low gate charge. This device is suitable for use in
DC-DC conversion, power switch and charging circuit.
Standard Product WPM2037 is Pb-free.
Pin configuration (Top view)
Features
6
z
Trench Technology
z
Supper high density cell design
z
Excellent ON resistance for higher DC current
z
Extremely Low Threshold Voltage
z
Small package SOT-23-6L
5
2037
YYWW
1
2
2037
Applications
z
Driver for Relay, Solenoid, Motor, LED etc.
z
DC-DC converter circuit
z
Power Switch
z
Load Switch
z
Charging
Will Semiconductor Ltd.
4
3
= Device Code
YY
= Year
WW
= Week
Marking
Order information
Device
Package
Shipping
WPM2037-6/TR
SOT-23-6L
3000/Reel&Tape
1
Dec,2011 - Rev.1.1
WPM2037
Absolute Maximum ratings
Parameter
Symbol
10 S
Steady State
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±12
Continuous Drain Current a
Maximum Power Dissipation a
Continuous Drain Current b
Maximum Power Dissipation b
TA=25°C
ID
TA=70°C
TA=25°C
TA=70°C
TA=25°C
ID
TA=70°C
TA=25°C
-3.3
-2.9
-2.7
1.1
0.9
0.7
0.6
-3.3
-3.1
-2.7
-2.4
0.9
0.8
0.6
0.5
PD
TA=70°C
V
-3.6
PD
Unit
A
W
A
W
Pulsed Drain Current c
IDM
-20
A
Operating Junction Temperature
TJ
150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Parameter
Junction-to-Ambient Thermal Resistance a
Junction-to-Ambient Thermal Resistance b
Junction-to-Case Thermal Resistance
Symbol
t 10 s
RșJA
Steady State
t 10 s
RșJA
Steady State
Steady State
Typical
Maximum
90
108
112
128
110
128
132
152
50
68
RșJC
a
Surface mounted on FR4 Board using 1 square inch pad size, 1oz copper
b
Surface mounted on FR4 board using minimum pad size, 1oz copper
c
Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1%
d
Repetitive rating, pulse width limited by junction temperature TJ=150°C.
2
Unit
°C/W
Dec,2011 - Rev.1.1
WPM2037
Electronics Characteristics (Ta=25oC, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
OFF CHARACTERISTICS
Drain-to-Source Breakdown Voltage
BVDSS
VGS = 0 V, ID = -250uA
-20
V
Zero Gate Voltage Drain Current
IDSS
VDS =-16 V, VGS = 0V
-1
uA
Gate-to-source Leakage Current
IGSS
VDS = 0 V, VGS = ±12V
±100
nA
VGS(TH)
VGS = VDS, ID = -250uA
-1.0
V
ON CHARACTERISTICS
Gate Threshold Voltage
Drain-to-source On-resistance
Forward Transconductance
RDS(on)
gFS
-0.35
-0.58
VGS = -4.5V, ID = -3.2A
47
61
VGS = -2.5V, ID = -2.8A
59
71
VGS = -1.8V, ID = -2.3A
77
94
VDS = -5.0 V, ID = -3.6A
10
m
S
CHARGES, CAPACITANCES AND GATE RESISTANCE
Input Capacitance
CISS
Output Capacitance
COSS
Reverse Transfer Capacitance
CRSS
115
Total Gate Charge
QG(TOT)
11
Threshold Gate Charge
QG(TH)
VGS = -4.5 V, VDS = -10 V,
0.6
Gate-to-Source Charge
QGS
ID = -2.7A
1.3
Gate-to-Drain Charge
QGD
2.7
Turn-On Delay Time
td(ON)
9.5
Rise Time
tr
VGS = -4.5 V, VDS = -6 V,
5.8
Turn-Off Delay Time
td(OFF)
RL=3 , RG=6
54
Fall Time
tf
VGS = 0 V, f = 1.0 MHz, VDS =
-10 V
1130
pF
120
nC
SWITCHING CHARACTERISTICS
ns
13
BODY DIODE CHARACTERISTICS
Forward Voltage
VSD
VGS = 0 V, IS = -1.0A
3
-0.75
-1.5
V
Dec,2011 - Rev.1.1
WPM2037
Typical Characteristics (Ta=25oC, unless otherwise noted)
VGS=-3.0 ~ -4.5V
VGS=-2.5V
-IDS-Drain to Source Current(A)
-IDS-Drain-to-Source Current (A)
VGS=-2.0V
10
VGS=-1.5V
5
VGS=-1.0V
2
3
4
5
VDS= -5V
16
o
T=-50 C
12
o
T=125 C
8
o
T=25 C
4
0.5
-V DS-Drain-to-Source Voltage(V)
Output characteristics
RDS(on)- On-Resistance (m:)
RDS(on)- On-Resistance(m:)
2.0
2.5
3.0
3.5
80
80
VGS=-2.5V
60
VGS=-4.5V
40
70
IDS=-3.2A
60
50
40
1.0
2
4
6
8
-IDS-Drain-to-Source Current(A)
1.5
10
2.0
2.5
3.0
3.5
4.0
4.5
5.0
-V GS-Gate-to-Source Voltage(V)
On-Resistance vs. Drain current
On-Resistance vs. Gate-to-Source voltage
80
0.8
-VGS(TH) Gate Threshold Voltage (V)
1.5
Transfer characteristics
100
-VGS-Gate-to-Source Voltage(V)
70
VGS=-4.5V,ID=-3.2A
60
50
40
30
-25
50
75
100 125 150
IDS=-250uA
0.6
0.5
0.4
0.3
-50
o
-25
50
75
100
125
150
o
Temperature( C)
Temperature ( C)
On-Resistance vs. Junction temperature
0.7
Threshold voltage vs. Temperature
4
Dec,2011 - Rev.1.1
WPM2037
1.5
1750
1250
1000
750
Ciss
Coss
Crss
500
250
8
12
16
0.9
o
T=150 C
0.3
0.2
0.3
0.4
0.5
0.6
0.7
0.8
-VSD-Source-to-Drain Voltage(V)
Capacitance
Body diode forward voltage
100
40
TJ(Max)=150°C, TA=25°C
TJ(Max)=150°C
TA=25°C
RDS(ON)
limited
-ID (Amps)
30
Power (W)
o
T=25 C
0.6
-V DS Drain-to-Source Voltage (V)
100Ps
1ms
1
10ms
DC
10
100m
10s
1s
0.1
0.01
0.1
1
10
Pulse Width (s)
100
1000
0.1
1
10
100
-VDS (Volts)
Single pulse power
Safe operating area
2
1
Normalized Effective Transient
Thermal Impedance
C - Capacitance(pF)
1500
-ISD-Source to Drain Current(A)
V GS =0V
F=1MHz
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = RthJA = 112_C/W
3. TJM ï TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10ï4
10ï3
10ï2
10ï1
1
Square Wave Pulse Duration (sec)
10
100
600
Transient thermal response (Junction-to-Ambient)
5
Dec,2011 - Rev.1.1
WPM2037
Package outline dimensions
SOT-23-6L
Symbol
Dimensions in millimeter
Min.
Typ.
Max.
A
1.050
1.150
1.250
A1
0.000
0.050
0.100
A2
1.050
1.100
1.150
b
0.300
0.400
0.500
c
0.100
0.150
0.200
D
2.820
2.920
3.020
E
1.500
1.600
1.700
E1
2.650
2.800
2.950
e
0.950(BSC)
1.900
e1
1.800
L
0.300
0.600
0e
8e
6
2.000
Dec,2011 - Rev.1.1
很抱歉,暂时无法提供与“WPM2037-6/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.89586
- 50+0.72998
- 150+0.64703
