TSM6968SDCA RVG
TSM6968SDCA RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TSSOP-8
    MOSFET - 阵列 20V 6.5A(Ta) 1.04W 表面贴装型 8-TSSOP
TSM6968SDCA RVG 数据手册
TSM6968SD 20V Dual N-Channel MOSFET w/ESD Protected TSSOP-8 PRODUCT SUMMARY VDS (V) RDS(on)(mΩ) Pin Definition: 1. Drain 1 8. Drain 2 2. Source 1 7. Source 2 3. Source 1 6. Source 2 4. Gate 1 5. Gate 2 20 Features ID (A) 22 @ VGS = 4.5V 6.5 29 @ VGS = 2.5V 5.5 Block Diagram ● ● Advance Trench Process Technology High Density Cell Design for Ultra Low On-resistance ● ESD Protect 2KV Application ● Specially Designed for Li-on Battery Packs ● Battery Switch Application Ordering Information Part No. TSM6968SDCA RVG Package Packing TSSOP-8 3Kpcs / 13” Reel Dual N-Channel MOSFET Note: “G” denotes for Halogen Free Absolute Maximum Rating (Ta = 25°C unless otherwise noted) Parameter Symbol Limit Unit Drain-Source Voltage VDS 20 V Gate-Source Voltage VGS ±12 V ID 6.5 A IDM 30 A IS 1.4 A Continuous Drain Current, VGS @4.5V. Pulsed Drain Current, VGS @4.5V Continuous Source Current (Diode Conduction) Maximum Power Dissipation a,b Ta = 25°C PD Ta = 75°C Operating Junction Temperature Operating Junction and Storage Temperature Range 1.04 0.625 W TJ +150 °C TJ, TSTG -55 to +150 °C Symbol Limit Unit RӨJF 83 °C/W RӨJA 120 °C/W Thermal Performance Parameter Junction to Foot (Drain) Thermal Resistance Junction to Ambient Thermal Resistance (PCB mounted) Notes: a. Pulse width limited by the Maximum junction temperature b. Surface Mounted on FR4 Board, t ≤ 5 sec. Document Number: DS_P0000131 1 Version: F15 TSM6968SD 20V Dual N-Channel MOSFET w/ESD Protected Electrical Specifications (Ta = 25°C unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250uA BVDSS 20 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250uA VGS(TH) 0.6 0.8 1.0 V Gate Body Leakage VGS = ±12V, VDS = 0V IGSS -- -- ±10 uA Zero Gate Voltage Drain Current VDS = 16V, VGS = 0V IDSS -- -- 1.0 uA VDS =5V, VGS = 4.5V ID(ON) 30 -- -- A -- 15 22 -- 20 29 On-State Drain Current Drain-Source On-State Resistance VGS = 4.5V, ID = 6.5A VGS = 2.5V, ID = 5.5A RDS(ON) mΩ Forward Transconductance VDS = 10V, ID = 6.5A gfs -- 30 -- S Diode Forward Voltage IS = 1.7A, VGS = 0V VSD -- 0.6 1.2 V Qg -- 15 20 Qgs -- 3.4 -- Qgd -- 1.2 -- Ciss -- 950 -- Coss -- 450 -- Crss -- 135 -- td(on) -- 140 200 tr -- 210 250 td(off) -- 3700 4800 -- 2000 2600 Dynamic b Total Gate Charge Gate-Source Charge Gate-Drain Charge Input Capacitance Output Capacitance Reverse Transfer Capacitance VDS = 10V, ID = 6.5A, VGS = 4.5V VDS = 10V, VGS = 0V, f = 1.0MHz nC pF c Switching Turn-On Delay Time Turn-On Rise Time Turn-Off Delay Time VDD = 10V, RL = 10Ω, ID = 1A, VGEN = 4.5V, RG = 6Ω Turn-Off Fall Time tf Notes: a. pulse test: PW ≤300µS, duty cycle ≤2% b. For DESIGN AID ONLY, not subject to production testing. b. Switching time is essentially independent of operating temperature. Document Number: DS_P0000131 2 nS Version: F15 TSM6968SD 20V Dual N-Channel MOSFET w/ESD Protected Electrical Characteristics Curve (Ta = 25°C, unless otherwise noted) Output Characteristics Transfer Characteristics On-Resistance vs. Drain Current Gate Charge On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage Document Number: DS_P0000131 3 Version: F15 TSM6968SD 20V Dual N-Channel MOSFET w/ESD Protected Electrical Characteristics Curve (Ta = 25°C, unless otherwise noted) On-Resistance vs. Gate-Source Voltage Threshold Voltage Single Pulse Power Normalized Thermal Transient Impedance, Junction-to-Ambient Document Number: DS_P0000131 4 Version: F15 TSM6968SD 20V Dual N-Channel MOSFET w/ESD Protected TSSOP-8 Mechanical Drawing DIM A a B C D E e F L TSSOP-8 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 6.20 6.60 0.244 0.260 4.30 4.50 0.170 0.177 2.90 3.10 0.114 0.122 0.65 (typ) 0.025 (typ) 0.25 0.30 0.010 0.019 1.05 1.20 0.041 0.049 0.05 0.15 0.002 0.009 0.127 0.005 0.50 0.70 0.020 0.028 Marking Diagram Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000131 5 Version: F15 TSM6968SD 20V Dual N-Channel MOSFET w/ESD Protected Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000131 6 Version: F15
TSM6968SDCA RVG 价格&库存
很抱歉,暂时无法提供与“TSM6968SDCA RVG”相匹配的价格&库存,您可以联系我们找货
TSM6968SDCA RVG
  • 150000+2.42533150000+0.31504
库存:1260
TSM6968SDCA RVG
  • 1+11.816711+1.53493
  • 10+7.4345110+0.96571
  • 100+4.90181100+0.63672
  • 500+3.81403500+0.49543
  • 1000+3.463801000+0.44993
库存:1260
