Oct 2014
SE2N60B
N-Channel Enhancement-Mode MOSFET
Revision: A
General Description
Features
This series is a high voltage power MOSFET
For a single MOSFET
and is designed to have better characteristics,
such as fast switching time, low gate charge,
VDS = 600V
RDS(ON) = 3.4Ω @ VGS=10V
low on-state resistance and have a high rugged
avalanche characteristics
Pin configurations
See Diagram below
TO-252
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
600
V
Gate-Source Voltage
VGS
±30
V
Continuous
Drain Current
2
ID
A
Pulsed
Avalanche Energy Single Pulsed
3
8
EAS
180
mJ
Dv/dt
4.5
V/ns
Power Dissipation
PD
33
W
Operating Junction Temperature Range
TJ
-55 to 150
Peak Diode Recovery dv/dt
4
Thermal Resistance
Symbol
RθJA
Parameter
Junction to Ambient (t≦10s)
ShangHai Sino-IC Microelectronic Co., Ltd.
Typ.
Max.
Units
62.5
℃/W
1.
SE2N60B
Electrical Characteristics
Symbol
(TJ=25℃ unless otherwise noted)
Parameter
Test Conditions
Min
Typ
Max
Units
OFF CHARACTERISTICS (Note 2)
BVDSS
Drain-Source Breakdown Voltage
VGS=0V, ID=250μA,
IDSS
Drain to Source Leakage Current
VDS=600V, VGS=0V
IGSS
Gate-Body Leakage Current
VGS=30V
VGS(th)
RDS(ON)
Gate Threshold Voltage
VDS= VGS, ID=250μA
Static Drain-Source On-Resistance
2
VGS=10V, ID=1A
600
V
1
μA
100
nA
4.5
V
3.4
4.3
Ω
520
680
pF
60
80
pF
8
10.5
pF
2.5
DYNAMIC PARAMETERS
Ciss
Input Capacitance
VGS=0V, VDS=25V,
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
f=1MHz
SWITCHING PARAMETERS
Qg
Total Gate Charge
2
10.5
VGS=10V, VDS=520V,
13.5
nC
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
Turn-On Delay Time
VDS=325V, RGEN=25Ω
11
33
ns
td(off)
Turn-Off Delay Time
ID=2A
45
90
ns
td(r)
Turn-On Rise Time
40
88
ns
td(f)
Turn-Off Fall Time
48
100
ns
1.4
V
ID=2A
2.5
nC
4.0
nC
Source-Drain Diode Characteristics
VSD
Drain-Source Diode Forward Voltage
VGS=0V,IS=2A
IS
Max Drain-Source Diode Current
2
A
ISM
Max Pulse Drain-Source Current
8
A
trr
Reverse Recovery Time
QRR
Reverse Recovery Charge
VGS=0V,IS=2A
dIF/dt=100A/μs
1
300
ns
2.2
μC
2.
SE2N60B
Typical Characteristics
3.
SE2N60B
4.
SE2N60B
Package Outline Dimension
TO-252
5.
The SINO-IC logo is a registered trademark of ShangHai Sino-IC
Microelectronics Co., Ltd.
© 2005 SINO-IC - Printed in China - All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road,
ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China
Phone:
+86-21-33932402
33932403
33932405 33933508 33933608
Fax: +86-21-33932401
Email: webmaster@sino-ic.com
Website: http://www.sino-ic.com
6.
很抱歉,暂时无法提供与“SE2N60B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68202
- 50+0.60491
- 150+0.57186
- 500+0.53066
- 2500+0.43881
- 5000+0.42779
