HT2803ARWZ
HT2803ARWZ
    HTCSEMI(海天芯)
    SOP18_300MIL
    8通道达林顿灌电流驱动器
HT2803ARWZ 数据手册
HT2803A 8CH Darlington Sink Driver The HT2803A&HT2804A are high-voltage, high-current darlington drivers comprised of eight NPN darlington pairs. All units feature integral clamp diodes for switching indicative loads. Application include relay, hammer, lamp and display (LED) drivers. Features HT2803AN HT2804AN DIP-18 • Output current (single output) 500mA (Max) • Output clamp diodes • Inputs compatible with various types of logic TYPE HT2803AN/ARW HT2804AN/ARW INPUT BASE RESISTOR 2.7kΩ 10.5kΩ HT2803ARW HT2804ARW DESIGNATION TTL, 5V CMOS 6~15V PMOS, CMOS SOP-18 TA = -40 ~ +85 C Pin Configuration (top view) Block Schematics HT2803A Note: The input and output parasitic diodes cannot be used as clamp diodes. HT2804A HT2803A Maximum Ratings Ta =25°C Parameter Limit Values min. max. Symbol Unit VCE(SUS) IOUT –0.5 50 500 Input Voltage VIN – 0.5 30 Clamp Diode Reverse Voltage VR 50 V Clamp Diode Forward Current IF 500 mA Power Dissipation PD 1.47 W Output Sustaining Voltage Output Current HT2803AN HT2803ADW V mA/ch V 0.96 Operating Temperature Topr -40 85 C Storage Temperature Tstg -55 150 C * Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Recommended Operating Conditions (Ta=-40~85°C) Parameter Symbol Output Sustaining Voltage Output Current IOUT DW Input Voltage Input Voltage (Output On) VIN HT2803A Unit Min Typ Max 0 - 50 Tpw=25ms,Duty=10%, 8 Circuits 0 - 347 Tpw=25ms,Duty=50%, 8 Circuits 0 - 123 Tpw=25ms,Duty=10%, 8 Circuits 0 - 268 Tpw=25ms,Duty=50%, 8 Circuits 0 - 90 0 - 30 3.5 - 30 8 - 30 VCE(SUS) N Limit Value Test Condition mA/ch V V VIN(ON) HT2804A V Clamp Diode Reverse Voltage VR - - 50 V Clamp Diode Forward Current IF - - 400 mA - - 0.52 - - 0.4 Power Dissipation N DW PD W HT2803A Electrical Characteristics Ta = 25°C Parameter Output Leakage Current Test Circuit HT2803A ICEX 1 VCE(sat) 2 IIN(ON) 2 HT2804A Collector-Emitter Saturation Voltage Input Current Symbol HT2803A HT2804A HT2803A Input Voltage (Output On) VIN(ON) 5 HT2804A DC Current Transfer Ratio Clamp Diode Reverse Current hFE IR Clamp Diode Forward Voltage Input Capacitance VF CIN - Turn-On Delay Turn-Off Delay tON tOFF 8 8 Note : VR=VRMAX 2 6 7 Test Condition Limit Values Unit Min Typ Max VCE=50V Ta=25°C VCE=50V Ta=85°C VCE=50V VIN=1V IOUT=350mA,IIN=500um IOUT=200mA,IIN=350um IOUT=100mA,IIN=250um - 1.3 1.1 0.9 50 100 500 1.6 1.3 1.1 VIN=3.85V VIN=5V VIN=12V VCE=2V, IOUT=200mA VCE=2V, IOUT=250mA - 0.93 0.35 1.0 - 1.35 0.5 1.45 2.4 2.7 VCE=2V, IOUT=300mA VCE=2V, IOUT=125mA - - 3.0 5.0 VCE=2V, IOUT=200mA VCE=2V, IOUT=275mA VCE=2V, IOUT=350mA - - 6.0 7.0 8.0 VCE=2V, IOUT=350mA Ta=25°C (Note) Ta=85°C (Note) 1000 - - 50 100 uA - - 2.0 V - - 15 pF - 0.1 0.21 - us us IF=350mA RL=125Ω, VOUT=50V RL=125Ω, VOUT=50V uA V mA V HT2803A Test Circuit HT2803A Note 1 : Pulse Width 50us, Duty Cycle 10% Output Impedance 50Ω, tr ≤ 5ns, tf ≤ 10ns Note 2 : See below. Input Condition Type number R1 VIH HT2803A 0Ω 3V HT2804A 0Ω 8V Note 3 : CL includes probe and jig capacitance Precautions for Using Utmost care is necessary in the design of output line, COMMON and GND line since IC may be destroyed due to short-circuit between outputs, air contaminaton fault, or fault by improper grounding. HT2803A HT2803AN HT2804A IIN vs VIN IIN vs VIN IOUT vs DUTY CYCLE IOUT vs VCE (sat) HT2803A HT2803A Package Dimensions DIP-18 Unit: mm HT2803A SOP-18
HT2803ARWZ 价格&库存
很抱歉,暂时无法提供与“HT2803ARWZ”相匹配的价格&库存,您可以联系我们找货
HT2803ARWZ
  • 1+2.64600
  • 10+2.09520
  • 30+1.86840
  • 100+1.57680
  • 500+1.44720
  • 1000+1.17720
库存:1775
