MMBT5401 SOT-23
PNP Transistors
3
2
Features
1
High Voltage Transistors
1.Base
2.Emitter
3.Collector
■ Simplified outline(SOT-23)
Pb-Free Packages are Available
Absolute Maximum Ratings Ta = 25
Parameter
Symbol
Rating
Un i t
Collector-base v oltage
VCBO
-160
V
Collector-emitter v oltage
VCEO
-150
V
Emitter-base voltage
VEBO
-5
V
Collector current-continuous
IC
-0.6
A
Collector Power Dissipation
Pc
300
mW
TJ, Tstg
-55 to +150
Junction and storage temperature
Electrical Characteristics Ta = 25
Parameter
Symbol
Testconditions
Collector-base breakdown voltage
VCBO
IC = -100
Collector-emitter breakdown voltage *
VCEO
IC =- 1.0 mA, IB = 0
A, IE = 0
Min
Typ
Max
Unit
-160
V
-150
V
-5
V
Emitter-base breakdown voltage
VEBO
IE = -10
Collector cutoff current
ICBO
VCB =- 120 V, IE = 0
-0.1
A
Emitter cutoff current
IEBO
VEB = -4.0 V, IC = 0
-0.1
A
IC = -1.0 mA, VCE = -5 V
80
DC current gain *
hFE
IC = -10 mA, VCE = -5 V
100
IC = -50 mA, VCE = -5 V
50
A, IC = 0
300
Collector-emitter saturation voltage *
VCE(sat) IC = -50 mA, IB = -5.0 mA
-0.5
V
Base-emitter saturation voltage *
VBE(sat) IC = -50 mA, IB = -5.0 mA
-1.0
V
Transiston frequency
* Pulse Test: Pulse Width = 300
fT
VCE=-5V,IC=-10mA,f=30MHz
100
MHz
s, Duty Cycle=2.0%.
■ Classification of hfe(2)
Type
MMBT5401
MMBT5401-L
MMBT5401-H
Range
100-300
100-200
200-300
Marking
www.yfwdiode.com
2L
1/3
Dongguan YFW Electronics Co, Ltd.
MMBT5401 SOT-23
Typical Characteristics
Static Characteristic
-20
COMMON
EMITTER
Ta=25℃
-90uA
-70uA
200
-12
-60uA
-50uA
-8
-40uA
-6
-4
50
-20uA
IB=-10uA
-0
-3
-6
VCE
-0.6
Ta=100℃
-0.2
-0.0
-0.1
-1
-10
IC
Ta=25℃
-1
(mA)
-10
Cob / Cib
100
VCE=-5V
-600
-100
COLLECTOR CURRENT
(mA)
IC
—— VCB / VEB
f=1MHz
IE=0 / IC=0
IC (mA)
o
(pF)
Ta=25 C
Cib
C
-10
o
Ta=100 C
CAPACITANCE
COLLECTOR CURRENT
IC
-0.1
IC —— V
BE
-100
(mA)
Ta=100℃
-0.01
-0.1
-600
-100
COLLECTOR CURRENT
VCEsat ——
-600
-100
IC
β=10
Ta=25℃
-0.4
-10
COLLECTOR CURRENT
-1
β=10
-0.8
-1
(V)
VBEsat —— IC
-1.0
Ta=25℃
-1
-0.1
-0.0
-0.2
-0.4
-0.6
-0.8
fT
—— IC
-10
Pc
0.4
fT
200
150
100
50
V
(V)
Ta
0.3
0.2
0.1
VCE=-5V
o
Ta=25 C
-0
-5
-10
-15
COLLECTOR CURRENT
www.yfwdiode.com
-1
REVERSE VOLTAGE
250
Cob
1
-0.5
-1.0
COLLECTOR POWER DISSIPATION
Pc (W)
300
10
VBE(V)
BASE-EMITTER VOLTAGE
(MHz)
COLLECTOR-EMITTER VOLTAGE
TRANSITION FREQUENCY
o
Ta=25 C
100
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
-0
150
-30uA
-2
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
hFE
-80uA
-10
VCE=-5V
o
Ta=100 C
250
DC CURRENT GAIN
(mA)
-14
COLLECTOR CURRENT
-16
IC
-18
hFE —— IC
300
-100uA
-20
IC
-25
0.0
-30
50
75
AMBIENT TEMPERATURE
(mA)
2/3
100
Ta
125
150
MMBT5401 SOT-23
SOT-23
Package Outline
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
c
bp
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
Summary of Packing Options
Package
SOT-23
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,7”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“MMBT5401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12258
- 500+0.09515
- 3000+0.08144
- 6000+0.07226
- 24000+0.06437
- 51000+0.06016
