MMBT2907A
MMBT2907A
    YFW(佑风微)
    SOT-23
    PNP 电流:600MA 电压:60V
MMBT2907A 数据手册
MMBT2907A SOT-23 ■ PNP Transistors 3 2 ■ ● 1 ● 1.Base 2.Emitter 3.Collector ■ Simplified outline(SOT-23) ■ Marking Marking 2F ■ Absolute Maximum Ratings Ta = 25℃ Symbol Rating Collector - Base Voltage Parameter VCBO -60 Collector - Emitter Voltage VCEO -60 Emitter - Base Voltage Unit V VEBO -5 Collector Current - Continuous IC 600 mA Power Dissipation PD 250 mW RθJA 500 ℃/W TJ 150 Tstg -55 to 150 Thermal resistance from junction to ambient Junction Temperature Storage Temperature Range ℃ ■ Electrical Characteristics Ta = 25℃ Parameter Symbol Test conditions Min Max Unit IC = -100 μA, IE = 0 -60 V(BR)CEO IC = -10 mA, IB = 0 -60 V V(BR)EBO IE = -100μA, IC = 0 -5 V Collector Cutoff Current ICBO VCB = -50 V, IE = 0 -20 nA Collector Cutoff Current ICEX VCE = -30 V,VEB(off) =0.5V -50 nA Collector-Base Breakdown Voltage V(BR)CBO Collector-Emitter Breakdown Voltage* Emitter-Base Breakdown Voltage DC Current Gain hFE Collector-Emitter Saturation Voltage * VCE(sat) Base-Emitter Saturation Voltage * VBE(sat) Current Gain - Bandwidth Product fT Delay Time td Rise Time tr Storage Time ts Fall Time tf VCE=-10V,IC=-0.1mA 75 VCE=-10V,IC=-1mA 100 VCE=-10V,IC=-10mA 100 VCE=-10V,IC=-150mA 100 VCE=-10V,IC=-500mA 50 V 300 IC = -150 mA, IB = -15 mA -0.4 V IC = -500 mA, IB = -50 mA -1.6 V IC = -150 mA, IB = -15 mA -1.3 V IC = -500 mA, IB = -50 mA -2.6 V VCE=-20V,IC=-50mA,f=100MHz 200 VCC = -30 V, IC = -150 mA,IB1 = -15 mA VCC = -6.0 V, IC = -150 mA,IB1 = IB2 = -15 mA MHz 10 ns 40 ns 80 ns 30 ns * Pulse test: Pulse width ≤ 300 μs, duty cycle ≤ 2.0% www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. MMBT2907A SOT-23 ■ Typical Characterisitics 30 C ,C APA C ITAN C E (pF) 20 Cibo 10 5.0 Cobo 1.0 -0.1 -1.0 -10 -30 REVERSE VOLTS (V) Fig. 1 Typical Capacitance V CE C O LLECT O R-EMITTER V O LTAGE (V) 1.6 1.4 I C = 300mA I C = 10mA I C = 100mA 1.2 I C = 1mA I C = 30mA 1.0 0.8 0.6 0.4 0.2 0 0.001 0.01 0.1 1 10 100 IB BASE CURRENT (mA) Fig. 2 Typical Collector Saturation Region www.yfwdiode.com 2/3 Dongguan YFW Electronics Co, Ltd. MMBT2907A SOT-23 SOT-23 Package Outline D E B A X HE v M A 3 Q A A1 1 2 e1 c bp w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 Summary of Packing Options Package SOT-23 www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,7”reel 3000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
MMBT2907A 价格&库存
很抱歉,暂时无法提供与“MMBT2907A”相匹配的价格&库存,您可以联系我们找货
MMBT2907A
  • 50+0.15277
  • 500+0.12559
  • 3000+0.10445
  • 6000+0.09542
  • 24000+0.08762
  • 51000+0.08332
库存:1749
