S9014
S9014
    YFW(佑风微)
    SOT-23
    NPN 电流:0.1A 电压:45V
S9014 数据手册
S9014 SOT-23 NPN Transistors 3 2 Features Excellent hFE linearity 1 Collector Current :IC=0.1A 1.Base 2.Emitter 3.Collector ■ Simplified outline(SOT-23) Absolute Maximum Ratings Ta = 25 Parameter Symbol Rating Unit Collector-Base Voltage VCBO 50 V Collector-Emitter Voltage VCEO 45 V Emitter-Base Voltage VEBO 5 V Collector Current -Continuous IC 0.1 A Collector Power Dissipation PC 0.2 W Junction Temperature Tj 150 Storage Temperature Tstg -55 to 150 Electrical Characteristics Ta = 25 Parameter Symbol Testconditi ons M in Typ M ax Unit Collector-base breakdown voltage VCBO Ic=100uA, IE=0 50 V Collector-emitter breakdown voltage VCEO Ic=1mA, IB=0 45 V Emitter-base Breakdown voltage VEBO IE=100 5 V Collector cutoff current ICBO VCB=50V, IE=0 0.1 A Emitter cutoff current IEBO VEB=5V, IC=0 0.1 A DC current gain hFE VCE=5V, IC=1mA A, IC=0 200 1000 Collector-emitter saturation voltage VCE(sat) IC=100mA, IB=10mA 0. 3 V Base-emitter saturation voltage VBE(sat) IC=100mA, IB=10mA 1 V Transition frequency fT VCE=5V, IC=10mA,f=30MHZ 150 MHz hFE Classification Type S9014 S9014-L S9014-H Range 300-400 200-450 450-1000 Marking www.yfwdiode.com J6 1/3 Dongguan YFW Electronics Co, Ltd. S9014 SOT-23 Typical Characteristics Static Characteristic 8 18uA COLLECTOR CURRENT Ta=25℃ hFE IC 16uA 14uA 4 12uA 10uA 8uA 2 —— IC Ta=100℃ DC CURRENT GAIN (mA) 20uA 6 hFE 1000 COMMON EMITTER Ta=25℃ 6uA 100 4uA COMMON EMITTER VCE= 5V IB=2uA 0 0 2 4 6 COLLECTOR-EMITTER VOLTAGE VCEsat —— IC 10 VBEsat 1 —— Ta=100℃ Ta=25℃ IC 100 (mA) IC Ta=25℃ BASE-EMITTER SATURATION VOLTAGE VBEsat (V) 0.1 Ta=100℃ β=20 β=20 1 10 COLLECTOR CURRENT IC IC 0.1 0.1 100 1 (mA) 10 COLLECTOR CURRENT —— VBE fT 1000 IC 100 (mA) —— IC (mA) (MHz) 100 Ta=100℃ 10 fT IC 1 COLLECTOR CURRENT 2 0.01 0.1 COLLECTOR CURRENT 8 (V) TRANSITION FREQUENCY COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (V) 1 VCE 10 0.1 Ta=25℃ 1 COMMON EMITTER VCE= 5V 0.1 0.0 0.3 0.6 0.9 100 10 COMMON EMITTER VCE=5V Ta=25℃ 1 0.1 1.2 1 BASE-EMMITER VOLTAGE VBE (V) 100 Cob/ Cib —— 10 COLLECTOR CURRENT VCB/ VEB PC 250 —— IC 100 (mA) Ta f=1MHz IE=0/IC=0 COLLECTOR POWER DISSIPATION PC (mW) 10 CAPACITANCE C (pF) Ta=25 ℃ Cib Cob 1 0.1 0.1 1 REVERSE VOLTAGE www.yfwdiode.com 10 VR 200 150 100 50 0 20 (V) 0 25 50 75 AMBIENT TEMPERATURE 2/3 100 Ta 125 150 (℃) Dongguan YFW Electronics Co, Ltd. S9014 SOT-23 SOT-23 Package Outline D E B A X HE v M A 3 Q A A1 1 2 e1 c bp w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 Summary of Packing Options Package SOT-23 www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,7”reel 3000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
S9014 价格&库存
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
S9014
  • 50+0.08986
  • 500+0.06945
  • 3000+0.06070
  • 6000+0.05390
  • 24000+0.04796
  • 51000+0.04482
库存:892
