S9013
S9013
    YFW(佑风微)
    SOT-23
    NPN 电流:500MA 电压:25V
S9013 数据手册
S9013 SOT-23 NPN Transistors 3 2 Features 1 Excellent hFE linearity 1.Base 2.Emitter 3.Collector ■ Simplified outline(SOT-23) Collector Current :IC=0.5A Absolute Maximum Ratings Ta = 25 Symbol Rating Unit Collector - Base Voltage Parameter VCBO 40 V Collector - Emitter Voltage VCEO 25 V Emitter - Base Voltage VEBO 5 V Collector Current - Continuous IC 500 mA Collector Power Dissipation PC 300 mW Junction Temperature Tj 150 Storage Temperature Tstg -55 to 150 Electrical Characteristics Ta = 25 Parameter Symbol Testconditions Min Typ Max Unit Collector - base breakdown voltage VCBO Ic= 100 A 40 V Collector - emitter breakdown voltage VCEO Ic= 0.1mA IB=0 25 V Emitter - base breakdown voltage VEBO IE=100 A IC=0 5 V Collector cut - off current ICBO VCB=40 V , IE=0 Collector cut -off current ICEO Emitter cut - off current IEBO DC current gain hFE IE=0 0.1 A VCE=20V , IB=0 1 A VEB= 5V , IC=0 0.1 A VCE=1V, IC= 50mA 120 VCE=1V, IC=500mA 40 400 Collector - emitter saturation voltage VCE(sat) IC=500 mA, IB= 50mA 0.6 V Base - emitter saturation voltage VBE(sat) IC=500 mA, IB= 50mA 1.2 V Transition frequency fT VCE=6V, IC= 20mA,f=30MHz 150 MHz ■ Classification of hfe(1) Type S9013 S9013-L Range 200-350 120-200 Marking www.yfwdiode.com S9013-H S9013-J 144-202 300-400 J3 1/3 Dongguan YFW Electronics Co, Ltd. S9013 SOT-23 Typical Characteristics Static Characteristic 100 COLLECTOR CURRENT 60 DC CURRENT GAIN 300uA 250uA 200uA 40 150uA —— IC COMMON EMITTER VCE=1V Ta=100℃ hFE 350uA IC (mA) 400uA 80 hFE 1000 COMMON EMITTER Ta=25℃ Ta=25℃ 100 100uA 20 IB=50uA 0 0 4 8 12 16 COLLECTOR-EMITTER VOLTAGE VCEsat —— 10 20 Ta=100℃ Ta=25℃ 30 3 30 10 (mA) IC —— IC Ta=100℃ 0.4 1 3 30 10 (mA) 100 COLLECTOR CURRENT —— VBE IC Ta=25℃ 0.8 0.0 500 100 Cob/ Cib 100 —— IC 500 (mA) VCB/ VEB f=1MHz IE=0/ IC=0 30 (pF) C 10 Ta=25℃ Cib 30 Ta=100℃ CAPACITANCE (mA) IC β=10 β=10 1 COMMON EMITTER VCE=1V 3 Ta=25℃ 1 Cob 10 3 0.3 0.1 0.0 0.2 0.4 0.6 0.8 1 0.1 1.0 fT 1000 1 0.3 —— IC PC —— 400 VCE=6V 10 3 REVERSE VOLTAGE BASE-EMMITER VOLTAGE VBE (V) V 20 (V) Ta Ta=25℃ COLLECTOR POWER DISSIPATION PC (mW) (MHz) fT 500 100 30 VBEsat 1.2 100 100 TRANSITION FREQUENCY 10 COLLECTOR CURRENT IC COLLECTOR CURRENT IC 3 300 10 COLLECTOR CURRENT 1 (V) BASE-EMITTER SATURATION VOLTAGE VBEsat (V) COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (mV) 500 VCE 300 100 10 10 www.yfwdiode.com 200 100 0 100 30 COLLECTOR CURRENT 300 IC (mA) 0 25 50 75 100 AMBIENT TEMPERATURE 2/3 Ta 125 150 (℃) Dongguan YFW Electronics Co, Ltd. S9013 SOT-23 SOT-23 Package Outline D E B A X HE v M A 3 Q A A1 1 2 e1 c bp w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 Summary of Packing Options Package SOT-23 www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,7”reel 3000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
S9013 价格&库存
很抱歉,暂时无法提供与“S9013”相匹配的价格&库存,您可以联系我们找货
