C1815
C1815
    JSMSEMI(杰盛微)
    SOT-23
    晶体管类型:-;集射极击穿电压(Vceo):-;集电极电流(Ic):-;功率(Pd):-;集电极截止电流(Icbo):-;集电极-发射极饱和电压(VCE(sat)@Ic,Ib):-;直流电流增益(hF...
C1815 数据手册
C1815 Silicon Epitaxial Planar Transistor FEATURES  High voltage and high current VCEO=50V(Min),IC=150mA(Max)  Excellent hFE linearity : hFE(2)=100 (Typ) at VCE=6V,IC=150mA hFE(IC=0.1mA) / hFE(IC=2mA=0.95(Typ))  Low noise  Complementary to 2SA1015 APPLICATIONS JS  SOT-23 Audio frequency general purpose amplifier applications. O CR MI mi Se MAXIMUM RATING @ Ta=25℃ unless otherwise specified Symbol Parameter Collector-Emitter Voltage VEBO Emitter-Base Voltage V 50 V V 150 mA Base Current 50 mA Collector Dissipation 400 mW -55 to +150 ℃ IB PC Junction and Storage Temperature www.jsmsemi.com r Collector Current -Continuous 5 to IC Tj,Tstg 60 uc VCEO Units nd Collector-Base Voltage co VCBO Value 第1/4页 C1815 Silicon Epitaxial Planar Transistor ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Parameter Symbol Test conditions Collector-base breakdown voltage V(BR)CBO IC=100μA,IE=0 60 V Collector-emitter breakdown voltage V(BR)CEO IC=0.1mA,IB=0 50 V Emitter-base breakdown voltage V(BR)EBO IC=0.1mA,IC=0 5 V ICBO VCB=60V,IE=0 0.1 μA ICEO VCE=50V,IB=0 0.1 μA IEBO VEB=5V,IC=0 0.1 μA Collector cut-off current JS Collector cut-off current MI Emitter cut-off current VCE=6V,IC=2mA 130 VCE=6V,IC=150mA 25 TYP MAX UNIT 400 O CR DC current gain MIN hFE mi Se VCE(sat) IC=100mA, IB=10mA Base-emitter saturation voltage VBE(sat) IC=100mA, IB=10mA fT VCE=10V, IC= 1mA f=30MHz 0.25 V 1 V 80 MHz CLASSIFICATION OF hFE(1) L Range 130-200 www.jsmsemi.com H r Rank to uc nd Transition frequency 0.1 co Collector-emitter saturation voltage 100 200-400 第2/4页 C1815 Silicon Epitaxial Planar Transistor TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified O CR MI JS r to uc nd co mi Se www.jsmsemi.com 第3/4页 C1815 Silicon Epitaxial Planar Transistor PACKAGE OUTLINE Plastic surface mounted package SOT-23 A SOT-23 Dim Min Max A 2.70 3.10 B 1.10 1.50 C 0.90 1.10 D 0.30 0.50 E 0.35 0.48 G 1.80 2.00 H 0.02 0.10 J 0.05 0.15 K 2.20 2.60 E K B JS J D MI G CR H C O 0.95 0.95 nd co mi Se SOLDERING FOOTPRINT All Dimensions in mm 0.90 r Unit: mm 0.80 to uc 2.00 PACKAGE INFORMATION Device C1815 Package Shipping SOT-23 3000 pcs / Tape & Reel www.jsmsemi.com 第4/4页
C1815
物料型号:C1815
器件简介:JSMICRO SEMICONDUCTOR生产的C1815是一款硅外延平面晶体管,具有高电压和高电流特性,适合音频频率通用放大器应用。
引脚分配:SOT-23封装,引脚分别为A(集电极)、E(发射极)、B(基极)、D(引脚)、H(距离)、J(引脚)、K(引脚)。
参数特性: - 集电极-基极电压(Vcbo):60V - 集电极-发射极电压(Vceo):50V - 发射极-基极电压(Vebo):未指定 - 集电极电流(Ic):最大150mA - 基极电流(Ib):50mA - 集电极耗散(Pc):400mW - 结温和存储温度(Tj,Tstg):-55°C至+150°C
功能详解:C1815具有良好的hFE线性度和低噪声特性,互补型号为2SA1015。其hFE在VCE=6V、IC=150mA时的典型值为100。
应用信息:C1815适用于音频频率的通用放大器应用。
C1815 价格&库存
很抱歉,暂时无法提供与“C1815”相匹配的价格&库存,您可以联系我们找货
