HT2301A
P-Channel Enhancement Mode Power MOSFET
DESCRIPTION
D
The HT2301A uses advanced trench technology to provide
excellent RDS(ON), low gate charge and operation with gate
G
voltages as low as 2.5V. This device is suitable for use as a
load switch or in PWM applications.
S
GENERAL FEATURES
Schematic diagram
● VDS = -20V,ID = -3.5A
RDS(ON) <
mΩ @ VGS=-2.5V
RDS(ON) <
mΩ @ VGS=-4.5V
● High Power and current handing capability
● Lead free product is acquired
Marking and pin Assignment
● Surface Mount Package
Application
●PWM applications
●Load switch
SOT-23 top view
●Power management
Package Marking And Ordering Information
Device Marking
Device
Device Package
Reel Size
Tape width
Quantity
2301
HT2301A
SOT-23
Ø180mm
8 mm
3000 units
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
VDS
-20
V
Gate-Source Voltage
VGS
±12
V
Drain Current-Continuous
ID
-3.5
A
Drain Current -Pulsed (Note 1)
IDM
-10
A
Maximum Power Dissipation
PD
1
W
TJ,TSTG
-55 To 150
RθJA
125
℃/W
Operating Junction and Storage Temperature Range
Thermal Characteristic
Thermal Resistance,Junction-to-Ambient (Note 2)
Electrical Characteristics (TA=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=-250µA
-20
-24
V
Zero Gate Voltage Drain Current
IDSS
VDS=-20V,VGS=0V
-1
µA
Off Characteristics
Rev. 00
HT2301A
Gate-Body Leakage Current
IGSS
VGS=±12V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=-250µA
-0.4
-0.7
-1
V
Drain-Source On-State Resistance
RDS(ON)
-64
75
mΩ
89
95
mΩ
On Characteristics (Note 3)
Forward Transconductance
gFS
VGS=-4.5V, ID=-3.5A
VGS=-2.5V, ID=-3A
VDS=-5V,ID=-3A
9.5
S
Dynamic Characteristics (Note4)
405
PF
75
PF
Crss
55
PF
Turn-on Delay Time
td(on)
11
nS
Turn-on Rise Time
tr
VDD=-10V,ID=-1A
35
nS
td(off)
VGS=-4.5V,RGEN=10Ω
30
nS
10
nS
3.3
12
nC
0.7
nC
1.3
nC
-1.2
V
-1.3
A
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
VDS=-10V,VGS=0V,
F=1.0MHz
Switching Characteristics (Note 4)
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=-10V,ID=-3A,
VGS=-2.5V
Drain-Source Diode Characteristics
Diode Forward Voltage (Note 3)
VSD
Diode Forward Current (Note 2)
IS
VGS=0V,IS=1.3A
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300µs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
Rev. 00
HT2301A
TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS
ton
tr
td(on)
toff
tf
td(off)
90%
VOUT
90%
INVERTED
10%
10%
90%
VIN
50%
50%
10%
PULSE WIDTH
Figure 2:Switching Waveforms
PD Power(W)
ID- Drain Current (A)
Figure 1:Switching Test Circuit
TJ-Junction Temperature(℃)
Figure 4 Drain Current
Rdson On-Resistance(Ω)
Figure 3 Power Dissipation
Vds Drain-Source Voltage (V)
Figure 5 Output CHARACTERISTICS
Figure 6 Drain-Source On-Resistance
Rev. 00
Normalized On-Resistance
HT2301A
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
C Capacitance (pF)
Figure 7 Transfer Characteristics
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Qg Gate Charge (nC)
Figure 11 Gate Charge
Vsd Source-Drain Voltage (V)
Figure 12 Source- Drain Diode Forward
Rev. 00
HT2301A
Safe Operation Area
Transient Thermal Impedance
r(t),Normalized Effective
Figure 13
Square Wave Pluse Duration(sec)
Figure 14 Normalized Maximum Transient Thermal Impedance
Rev. 00
HT2301A
SOT-23 PACKAGE INFORMATION
Dimensions in Millimeters (UNIT:mm)
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
MIN.
MAX.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950TYP
1.800
2.000
0.550REF
0.300
0.500
0°
8°
NOTES
1. All dimensions are in millimeters.
2. Tolerance ±0.10mm (4 mil) unless otherwise specified
3. Package body sizes exclude mold flash and gate burrs. Mold flash at the non-lead sides should be less than 5 mils.
4. Dimension L is measured in gauge plane.
5. Controlling dimension is millimeter, converted inch dimensions are not necessarily exact.
Rev. 00
很抱歉,暂时无法提供与“HT2301ARTZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40328
- 100+0.32552
- 300+0.28674
- 3000+0.22518
- 6000+0.20186
- 9000+0.19019
