HSS2305A
P-Ch 20V Fast Switching MOSFETs
Description
Product Summary
The HSS2305A is the high cell density trenched Pch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
VDS
-20
V
RDS(ON),max
45
mΩ
ID
-4.9
A
converter applications.
The HSS2305A meet the RoHS and Green Product
requirement with full function reliability approved.
l
l
l
l
Super Low Gate Charge
Green Device Available
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
SOT 23s Pin Configurations
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-20
V
VGS
Gate-Source Voltage
ID@TA=25℃
Continuous Drain Current, VGS @ -4.5V
1
ID@TA=70℃
1
IDM
V
-4.9
A
-3.9
A
2
-14
A
Total Power Dissipation
3
1.31
W
PD@TA=70℃
3
0.84
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
PD@TA=25℃
Pulsed Drain Current
±12
Thermal Data
Symbol
RθJA
RθJA
www.hs-semi.cn
Parameter
Thermal Resistance Junction-Ambient
1
1
Thermal Resistance Junction-Ambient (t ≤10s)
Ver 2.0
Typ.
Max.
Unit
120
℃/W
95
℃/W
1
HSS2305A
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
2
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-20
V
Reference to 25℃ , ID=-1mA
-0.014
V/℃
VGS=-4.5V , ID=-4.9A
40
45
VGS=-2.5V , ID=-3.4A
50
60
VGS=-1.8V , ID=-2A
mΩ
65
85
-0.4
-1.0
V
3.95
mV/℃
VDS=-16V , VGS=0V , TJ=25℃
-1
VDS=-16V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
12.8
S
Qg
Total Gate Charge (-4.5V)
10.2
14.3
Qgs
Gate-Source Charge
1.89
2.6
Qgd
Gate-Drain Charge
3.1
4.3
VDS=-15V , VGS=-4.5V , ID=-3A
uA
nC
5.6
11.2
Rise Time
VDD=-10V , VGS=-4.5V ,
40.8
73
Turn-Off Delay Time
RG=3.3Ω, ID=-3A
33.6
67
Fall Time
18
36
Ciss
Input Capacitance
857
1200
Coss
Output Capacitance
114
160
Crss
Reverse Transfer Capacitance
108
151
Min.
Typ.
Max.
Unit
-4.9
A
-14
A
VGS=0V , IS=-1A , TJ=25℃
-1
V
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
Parameter
Continuous Source Current
Pulsed Source Current
2,4
2
Conditions
1,4
VG=VD=0V , Force Current
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
IF=-3A , di/dt=100A/µs ,
21.8
nS
Qrr
Reverse Recovery Charge
TJ=25℃
6.9
nC
Note :
2
1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSS2305A
Typical Characteristics
100
-ID=3A
RDSON (mΩ)
80
60
40
1
2
3
-VGS (V)
4
5
Fig.2 On-Resistance vs. G-S Voltage
Fig.1 Typical Output Characteristics
-IS Source Current(A)
4
3
TJ=150℃
TJ=25℃
2
1
0.4
0.6
0.8
-VSD , Source-to-Drain Voltage (V)
1
Fig.3 Forward Characteristics of Reverse
Fig.4 Gate-charge Characteristics
1.8
Normalized On Resistance
1.8
Normalized VGS(th)
1.4
1
0.6
1.4
1.0
0.6
0.2
0.2
-50
100
TJ ,Junction Temperature (℃ )
-50
150
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized R DSON vs. TJ
Ver 2.0
3
HSS2305A
1000
100.00
Ciss
100us
10ms
-ID (A)
C (pF)
10.00
Coss
100
100ms
1.00
Crss
1s
0.10
DC
TA=25℃
Single Pulse
F=1.0MHz
10
0.01
1
5
9
13
17
-VDS (V)
21
0.1
Fig.7 Capacitance
1
10
-VDS (V)
100
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TC + PDM x RθJC
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
HSS2305A
Ordering Information
Part Number
HSS2305A
www.hs-semi.cn
Package code
SOT-23
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS2305A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.29430
- 200+0.24182
- 600+0.21266
- 3000+0.18058
- 9000+0.16535
- 21000+0.15725
