IRLML2502
N-Ch 20V Fast Switching MOSFETs
Description
Product Summary
The IRLML2502 is the high cell density
trenched N-ch MOSFETs, which provides
excellent RDSON and efficiency for most of the
small power switching and load switch
applications.
The IRLML2502 meets the RoHS and Green
Product requirement with full function reliability
approved.
VDS
V
RDS(ON),typ
30
mΩ
ID
3.6
A
SOT23S Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
±12
V
ID@TA=25℃
Continuous Drain Current, VGS @ 4.5V1
3.6
A
ID@TA=70℃
2.8
A
IDM
Pulsed Drain Current2
14.4
A
PD@TA=25℃
Total Power Dissipation3
1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
RθJC
www.hs-semi.cn
Typ.
Max.
Unit
Thermal Resistance Junction-ambient 1
125
℃/W
Thermal Resistance Junction-Case1
80
℃/W
Ver 2.0
1
IRLML2502
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
VGS=4.5V , ID=3A
30
50
VGS=2.5V , ID=2A
40
70
VGS=VDS , ID =250uA
0.4
1.2
VDS=16V , VGS=0V , TJ=25℃
1
VDS=16V , VGS=0V , TJ=55℃
5
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=3A
10.5
S
Qg
Total Gate Charge (4.5V)
4.6
Qgs
Gate-Source Charge
0.7
Qgd
Gate-Drain Charge
1.5
VDS=15V , VGS=4.5V , ID=3A
nC
1.6
Rise Time
VDD=10V , VGS=4.5V , RG=3.3
42
Turn-Off Delay Time
ID=3A
14
Fall Time
7
Ciss
Input Capacitance
310
Coss
Output Capacitance
49
Crss
Reverse Transfer Capacitance
35
Min.
Typ.
Max.
Unit
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Conditions
Continuous Source Current1,4
VG=VD=0V , Force Current
3.6
A
Diode Forward Voltage2
VGS=0V , IS=1A , TJ=25℃
1.2
V
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
IRLML2502
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
5
IS Source Current(A)
4
3
2
TJ=150℃
TJ=25℃
1
0.6
0.9
1.2
VSD , Source-to-Drain Voltage (V)
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
1.8
Normalized On Resistance
1.8
1.4
Normalized VGS(th)
1.4
1.0
1
0.6
0.6
0.2
0.2
-50
100
150
-50
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
IRLML2502
1000
F=1.0MHz
Capacitance (pF)
Ciss
100
Coss
Crss
10
1
5
9
13
17
21
VDS , Drain to Source Voltage (V)
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TC + PDM x RθJC
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
IRLML2502
Ordering Information
Part Number
IRLML2502
www.hs-semi.cn
Package code
SOT-23
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“IRLML2502”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36710
- 100+0.29452
- 300+0.25823
- 3000+0.19300
- 6000+0.17118
- 9000+0.16028
