IRLML5203
P-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The IRLML5203 is the high cell density trenched Pch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The IRLML5203 meet the RoHS and Green
Product requirement with full function reliability
approved.
VDS
-30
V
RDS(ON),typ
43
mΩ
ID
-3.2
A
SOT23s Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @ -10V1
-3.6
-3.2
A
ID@TA=70℃
-2.9
-2.5
A
IDM
Pulsed Drain Current2
PD@TA=25℃
Total Power Dissipation3
1.32
1
W
PD@TA=70℃
0.84
0.64
W
10s
Steady State
-13
Units
A
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
RθJA
RθJC
www.hs-semi.cn
Typ.
Max.
Unit
Thermal Resistance Junction-ambient 1
125
℃/W
Thermal Resistance Junction-Ambient 1 (t ≤10s)
95
℃/W
Thermal Resistance Junction-Case1
80
℃/W
Ver 2.0
1
IRLML5203
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.02
V/℃
VGS=-10V , ID=-3A
43
60
VGS=-4.5V , ID=-1.5A
63
90
-1
-1.5
-3
V
4.32
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
4.8
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
24
48
Qg
Total Gate Charge (-4.5V)
5.22
7.3
1.25
1.8
VDS=-20V , VGS=-4.5V , ID=-3A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
2.3
3.2
Turn-On Delay Time
18.4
37
Td(on)
nC
Rise Time
VDD=-15V , VGS=-10V , RG=3.3
11.4
21
Turn-Off Delay Time
ID=-1A
39.4
79
Fall Time
5.2
10.4
Ciss
Input Capacitance
463
650
Coss
Output Capacitance
82
115
Crss
Reverse Transfer Capacitance
68
95
Min.
Typ.
Max.
Unit
-3.2
A
-13
A
-1
V
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
IS
Continuous Source Current1,4
ISM
Pulsed Source Current2,4
VSD
Diode Forward Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
IRLML5203
Typical Characteristics
14
135.0
VGS=-7V
10
115.0
VGS=-5V
8
RDSON (mΩ)
-ID Drain Current (A)
ID= -3A
VGS=-10V
12
VGS=-4.5V
6
VGS=-3V
4
95.0
75.0
2
1
1.5
2
2.5
3
3.5
4
-VDS , Drain-to-Source Voltage (V)
4.5
5
2
Fig.1 Typical Output Characteristics
4
6
-VGS (V)
8
10
Fig.2 On-Resistance vs. G-S Voltage
10
10
-VGS Gate to Source Voltage (V)
-IS Source Current(A)
VDS=-20V
7.5
5
TJ=150℃
TJ=25℃
2.5
0.6
0.9
ID=-3A
8
6
4
2
-VSD , Source-to-Drain Voltage (V)
7.5
10
Fig.4 Gate-Charge Characteristics
diode
2.0
Normalized On Resistance
Normalized VGS(th)
5
QG , Total Gate Charge (nC)
Fig.3 Forward Characteristics of Reverse
1.5
2.5
1.5
1
1.0
0.5
0.5
100
TJ ,Junction Temperature (℃ )
-50
150
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
IRLML5203
1000
100.00
F=1.0MHz
100us
10.00
-ID (A)
Capacitance (pF)
Ciss
100
Coss
10ms
1.00
100ms
Crss
1s
0.10
TA=25℃
Single Pulse
10
DC
0.01
1
5
9
13
17
21
25
0.1
1
Fig.7 Capacitance
10
-VDS (V)
-VDS , Drain to Source Voltage (V)
100
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TA + PDM x RθJA
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
Fig.11 Gate Charge Waveform
waveform
www.hs-semi.cn
Ver 2.0
4
IRLML5203
Ordering Information
Part Number
IRLML5203
www.hs-semi.cn
Package code
SOT-23
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“IRLML5203”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39064
- 100+0.31806
- 300+0.28178
- 3000+0.25456
- 6000+0.23274
- 9000+0.22194
