2N7002KT1G-MS
2N7002KT1G-MS
    MSKSEMI(美森科)
    SOT-23
    1个N沟道 耐压:60V 电流:0.3A
2N7002KT1G-MS 数据手册
2N7002KT1G-MS Product specification 2N7002KT1G-MS Features Application  60V,0.3A, RDS(ON) =2.2Ω@VGS=10V  Motor Drive  Improved dv/dt capability  Power Tools  Fast switching  LED Lighting  Green Device Available  G-S ESD Protection Diode Embedded  ESD protected up to 2KV BVDSS RDSON ID 60V 2.2Ω 0.3A Reference News Pin Configuration PACKAGE OUTLINE Marking 704* SOT-23 Absolute Maximum Ratings (TA=25℃ unless otherwise noted) Symbol Parameter Rating Units VDS Drain- Source Voltage 60 V VGS Gate- Source Voltage ± 20 V Drain Current – Continuous (TC=25 ℃ ) 0.3 A Drain Current – Continuous (TC=100 ℃ ) 0.1 A Pulsed1 0.8 A Power Dissipation (TC=25 ℃ ) 0.35 W Power Dissipation – Derate above 25 ℃ 0.003 W/ ℃ Storage Temperature Range -50 to 150 ℃ Operating Junction Temperature Range -50 to 150 ℃ ID IDM PD TSTG TJ Drain Current – Copyright© Msksemi Incorporated www.msksemi.com 2N7002KT1G-MS Thermal Characteristics Symbol RθJA Parameter Thermal Resistance Junction to ambient Typ. Max. Unit --- 357 ℃/W Electrical Characteristics (TJ=25 ℃ , unless otherwise noted) Off Characteristics Symbol BVDSS Conditions Min. Typ. Max. Unit VGS=0V , ID=250uA 60 --- --- V VDS=60V , VGS=0V , TJ=25 ℃ --- --- 1 ṷA ṳA ṳA Parameter Drain- Source Breakdown Voltage IDSS Drain- Source Leakage Current IGSS Gate- Source Leakage Current VDS=48V , VGS=0V , TJ=125 ℃ --- --- 10 VGS ± 20V , VDS=0V --- --- ± 10 VGS=10V , ID=0.3A --- 2.2 2.8 VGS=4.5V , ID=0.2A --- 24 30 1 1.6 2.5 V --- 0.5 --- S --- 3.7 5.6 --- 0.9 1.4 --- 0.4 0.6 --- 3 6 VDD=30V ,VGS=10V , RG=6Ω --- 5 10 ID=0.2A --- 14 27 = On Characteristics RDS(ON) Static Drain- Source On- Resistance VGS( th) Gate Threshold Voltage VGS=VDS , ID =250uA Forward Transconductance VDS=10V , ID=0.3A gfs Ω Ω Dynamic and switching Characteristics Qg Total Gate Charge2 , 3 Qgs Gate-Source Qgd Gate-Drain Charge2 Td(on) Turn-On Delay Time2 Tr Td(off) Charge2 , 3 , 3 , 3 Rise Time2 , 3 Turn-Off Delay VDS=30V , VGS=10V , ID=1A Time2 , 3 nC ns Tf Fall Time2 , 3 --- 9 17 Ciss Input Capacitance --- 25.5 38 Coss Output Capacitance --- 17 26 Crss Reverse Transfer Capacitance --- 7.8 12 Min. Typ. Max. Unit --- --- 0.3 A --- --- 1.2 A --- --- 1 V --- 3.4 --- ns --- 0.7 --- nC VDS=30V , VGS=0V , F=1MHz pF Drain-Source Diode Characteristics and Maximum Ratings Symbol Parameter Conditions IS Continuous Source Current ISM Pulsed Source Current VSD Diode Forward Voltage VGS=0V , IS=1A , TJ=25 ℃ trr Reverse Recovery Time VGS=50V, IS=1A , dI/dt=100A/µs Qrr Reverse Recovery Charge TJ=25 ℃ VG= VD=0 V , Force Current Note : 1.Repetitive Rating : Pulsed width limited by maximum junction temperature. 2 . The data tested by pulsed , pulse width ≦ 3 0 0 us , duty cycle ≦ 2 % . 3 . Essentially independent of operating temperature. Copyright© Msksemi Incorporated www.msksemi.com 2N7002KT1G-MS ELECTRICAL CHARACTERISTICS CURVE Copyright© Msksemi Incorporated www.msksemi.com 2N7002KT1G-MS PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 0.000 0.900 0.300 0.080 2.800 1.200 2.250 1.800 0.300 0° 0.950 TYP 0.550 REF Dimensions In Inches Min Max 1.150 0.100 1.050 0.500 0.150 3.000 1.400 2.550 0.035 0.000 0.035 0.012 0.003 0.110 0.047 0.089 2.000 0.071 0.500 8° 0.012 0° 0.037 TYP 0.022 REF 0.045 0.004 0.041 0.020 0.006 0.118 0.055 0.100 0.079 0.020 8° Suggested Pad Layout Note: 1.Controlling dimension:in millimeters. 2.General tolerance:±0.05mm. 3.The pad layout is for reference purposes only. REEL SPECIFICATION P/N 2N7002KT1G-MS Copyright© Msksemi Incorporated PKG SOT-23 QTY 3000 www.msksemi.com 2N7002KT1G-MS Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
