KY2300
KY2300
    KY(韩景元)
    SOT-23
    1个N沟道 耐压:20V 电流:5A
KY2300 数据手册
ShenZhen HanKingYuan Electronic Co.,Ltd K Y 2300 20V N-Channel Mosfet SOT-23 FEATURES ● RDS(ON) ≤ 24mΩ ( 21.6mΩ Typ.) @VGS=4.5V ● RDS(ON) ≤ 37mΩ ( 27mΩ Typ.) @VGS=2.5V 1. GATE 2. SOURCE APPLICATIONS 3. DRAIN ● PWM Applications ● Load Switch ● Power Management N-CHANNEL MOSFET MARKING 2300A 2302 2300A:Device code 2302:Device code MAXIMUM RATINGS (Ta=25°C unless otherwise noted) Symbol Parameter Value Unit VDS Drain-Source Voltage 20 V VGS Gate-Source Voltage ±12 V ID Continuous Drain Current 5 A IDM Plused Drain Current 25 A PD Power Dissipation 0.35 W Thermal Resistance from Junction to Ambient 357 ℃/W TJ Junction Temperature 150 ℃ TSTG Storage Temperature -55~ +150 ℃ RθJA www.scr-ky.com 1/4 ShenZhen HanKingYuan Electronic Co.,Ltd K Y 2300 MOSFET ELECTRICAL CHARACTERISTICS Ta=25 °C unless otherwise specified Parameter Symbol bol Test Condition Min. Typ. Max. Units 20 - - V - - 1 μA - - ±100 nA V Off Characteristic V(BR)DSS Drain-Source Breakdown Voltage IDSS Zero Gate Voltage Drain Current IGSS Gate to Body Leakage Current VGS = 0V,ID = 250μA VDS = 20V, VGS = 0V, TJ = 25℃ VGS = ±12V,VDS = 0V On Characteristics VGS(th) RDS(on) Gate Threshold Voltage Static Drain-Source On-Resistance VDS =VGS,ID = 250μA 0.5 0.66 1.2 VGS =4.5V, ID =4A - 21.6 24 VGS =2.5V, ID =3A - 27 37 - 800 - pF - 155 - pF 125 - pF - 11 - nC - 2.3 - nC - 2.5 - nC - 18 - ns - 5 - ns - 43 - ns - 20 - ns - - 1.2 V mΩ Dynamic Characteristics Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain(“Miller”) Charge VDS =10V, VGS = 0V, f = 1.0MHz VDS=10V, ID=4A, VGS=4.5V, Switching Characteristics td(on) Turn-On Delay Time tr Turn-On Rise Time td(off) Turn-Off Delay Time tf VGS = 4V, VDS=10V, RG =10Ω, ID=1A Turn-Off Fall Time Drain-Source Diode Characteristics and Maximum Ratings Drain to Source Diode Forward VGS = 0V, ISD=1.7A VSD Voltage www.scr-ky.com 2/4 ShenZhen HanKingYuan Electronic Co.,Ltd K Y 2300 TYPICAL PERFORMANCE CHARACTERISTICS www.scr-ky.com 3/4 ShenZhen HanKingYuan Electronic Co.,Ltd K Y 2300 SOT-23 PACKAGE OUTLINE DRAWING Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.900 1.150 0.035 0.045 A1 0.000 0.100 0.000 0.004 A2 0.900 1.050 0.035 0.041 b 0.300 0.500 0.012 0.020 c 0.080 0.150 0.003 0.006 D 2.800 3.000 0.110 0.118 E 1.200 1.400 0.047 0.055 E1 2.250 2.550 0.089 0.100 e e1 0.950 TYP 1.800 L 0.037 TYP 2.000 0.071 0.550 REF 0.022 REF L1 0.300 0.500 0.012 θ 0° 8° 0° www.scr-ky.com 0.079 0.020 8° 4/4
KY2300 价格&库存
很抱歉,暂时无法提供与“KY2300”相匹配的价格&库存,您可以联系我们找货
KY2300
  • 10+0.22875
  • 100+0.18134
  • 300+0.15498
  • 3000+0.13965
  • 6000+0.12593
  • 9000+0.11859
库存:4754
