AP3415AI
AP3415AI
    APM-MICROELECTRONICS(永源微)
    SOT-23
    P沟道增强型MOSFET 1个P沟道 耐压:20V 电流:4.2A
AP3415AI 数据手册
AP3415A -20V P-Channel Enhancement Mode MOSFET Description The AP3415A uses advanced trench It utilizes the latest processing techniques to achieve the high cell density and reduces the on-resistance with high repetitive avalanche rating. These features combine to make this design an extremely efficient and reliable device for use in power switching application and a wide variety of other applications General Features VDS = -20V,ID = -4.2A RDS(ON) < 37mΩ @ VGS=4.5V ESD=3000V HBM Application Advanced MOSFET process technology Special designed for PWM, load switching and general purpose applications Ultra low on-resistance with low gate charge Fast switching and reverse body recovery 150℃ operating temperature Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) AP3415A SOT-23 AP3415A 3000 Absolute max Rating: @TA=25℃ unless otherwise specified Symbol Parameter Max. Units ID @ TC = 25°C Continuous Drain Current, VGS @ 10V -4 .2① ID @ TC = 70°C Continuous Drain Current, VGS @ 10V -2.4 ① IDM Pulsed Drain Current ② -30 PD @TC = 25°C Power Dissipation ③ 1.4 W VDS Drain-Source Voltage -20 V VGS Gate-to-Source Voltage ±8 V TJ TSTG Operating Junction and Storage Temperature Range -55 to +150 °C RθJA Junction-to-ambient (t ≤ 10s) ④ 90 °C /W A 1 AP3415A Rve:1.2 臺灣永源微電子科技有限公司 AP3415A -20V P-Channel Enhancement Mode MOSFET Electrical Characterizes @TA=25℃ unless otherwise specified Symbol V(BR)DSS Parameter Drain-to-Source breakdown voltage RDS(on) Static Drain-to-Source on-resistance VGS(th) Gate threshold voltage IDSS Drain-to-Source leakage current IGSS Qg Conditions VGS = 0V, ID = -250μA VGS=-4.5V,ID = -4A VGS=-2.5V,ID = -4A VGS=-1.8V,ID = -2A VDS = VGS, ID = -250μA TJ = 125°C VDS = -16V,VGS = 0V Min. -20 — — — -0.3 — — Typ. — 37 45 56 — -0.44 — Max. — 43 54 73 -1.0 — -1 TJ = 125°C — — -50 VGS =8V — — 10 VGS = -8V — — -10 ID = -4A, — 10 — Units V mΩ V μA Gate-to-Source forward leakage μA Total gate charge VDS=-10V, nC VGS = -4.5V Qgs Qgd td(on) Gate-to-Source charge Gate-to-Drain("Miller") charge Turn-on delay time tr td(off) tf Ciss Rise time Turn-Off delay time Fall time Input capacitance Coss Crss Output capacitance Reverse transfer capacitance VGS=-4.5V, VDS =-10V, — — — 0.77 3.5 10 — — — — — — — 8.6 29 13 939 — — — — — — 130 111 — — RGEN=3Ω, VGS = 0V, VDS =-10V, ƒ = 1MHz ns pF Source-Drain Ratings and Characteristics Symbol Parameter Continuous Source Current IS ISM (Body Diode) Conditions Min. Typ. Max. Units MOSFET symbol showing the integral reverse p-n junction diode. — — -4.2A ① A — — -30 A Pulsed Source Current (Body Diode) VSD Diode Forward Voltage IS=1A, VGS=0V — -0.76 -1.0 V trr Reverse Recovery Time TJ = 25°C, IF =-4A, di/dt = 100A/μs — 8.7 — ns Qrr Notes: Reverse Recovery Charge — 2.3 — nC ①Calculated continuous current based on maximum allowable junction temperature. ②Repetitive rating; pulse width limited by max. junction temperature. ③The power dissipation PD is based on max. junction temperature, using junction-to-case thermal resistance. ④The value of RθJA is measured with the device mounted on 1 in 2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C 2 AP3415A Rve:1.2 臺灣永源微電子科技有限公司 AP3415A -20V P-Channel Enhancement Mode MOSFET Test circuits and Waveforms EAS test circuit: Switching time test circuit: Gate charge test circuit: Switch Waveforms: 3 AP3415A Rve:1.2 臺灣永源微電子科技有限公司 AP3415A -20V P-Channel Enhancement Mode MOSFET Typical electrical and thermal characteristics Figure 1: Typical Output Characteristics Figure 3. Drain-to-Source Breakdown Voltage Vs. AP3415A Rve:1.2 Figure 4: Normalized On-Resistance Vs. Case Temperature 臺灣永源微電子科技有限公司 4 Case Temperature Figure 2. Gate to source cut-off voltage AP3415A -20V P-Channel Enhancement Mode MOSFET Typical electrical and thermal characteristics Figure 5. Maximum Drain Current Vs. Case Temperature Figure 6. Typical Capacitance Vs. Drain-to-Source Voltage Figure7. Maximum Effective Transient Thermal Impedance Junction-to-Case 5 AP3415A Rve:1.2 臺灣永源微電子科技有限公司 AP3415A -20V P-Channel Enhancement Mode MOSFET Mechanical Data: 6 AP3415A Rve:1.2 臺灣永源微電子科技有限公司 AP3415A -20V P-Channel Enhancement Mode MOSFET Attention 1,Any and all APM Microelectronics products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your APM Microelectronics representative nearest you before using any APM Microelectronics products described or contained herein in such applications. 2,APM Microelectronics assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all APM Microelectronics products described or contained herein. 3, Specifications of any and all APM Microelectronics products described or contained here instipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. 4, APM Microelectronics Semiconductor CO., LTD. strives to supply high quality high reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design,and structural design. 5,In the event that any or all APM Microelectronics products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. 6, No part of this publication may be reproduced or transmitted in any form or by any means,electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of APM Microelectronics Semiconductor CO., LTD. 7, Information (including circuit diagrams and circuit parameters) herein is for example only; it is not guaranteed for volume production. APM Microelectronics believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. 8, Any and all information described or contained herein are subject to change without notice due to product/technology improvement,etc. When designing equipment, refer to the "Delivery Specification" for the APM Microelectronics product that you Intend to use. 7 AP3415A Rve:1.2 臺灣永源微電子科技有限公司
AP3415AI 价格&库存
很抱歉,暂时无法提供与“AP3415AI”相匹配的价格&库存,您可以联系我们找货
