NP2N7002VR
60V N-Channel Enhancement Mode MOSFET
Description
Schematic diagram
The NP2N7002VR uses advanced trench technology
to provide excellent RDS(ON), low gate charge and
operation with gate voltages as low as 1.8V. This device
is suitable for use as a load switch or in PWM
applications.
General Features
VDS =60V,ID =340mA
RDS(ON)(Typ.)=1.15Ω @VGS=10V
RDS(ON)(Typ.)=1.25Ω @VGS=4.5V
High power and current handing capability
Lead free product is acquired
Surface mount package
ESD Rating: 2000V HBM
Marking and pin assignment
Application
PWM applications
Load switch
Package
SOT-23-3L
Ordering Information
Part Number
Storage Temperature
Package
Devices Per Reel
NP2N7002VR-G
-55°C to +150°C
SOT-23-3L
3000
Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
parameter
symbol
limit
unit
Drain-source voltage
VDS
60
V
Gate-source voltage
VGS
±20
V
Drain current-continuousa@Tj=125℃
ID
0.34
A
-pulse db
IDM
0.3
A
PD
0.15
W
Tj
-55—150
Maximum power dissipation
TA=25℃
Operating junction Temperature range
Notes:
a.
surface mounted on FR4 board,t≤10sec
b.
pulse test: pulse width≤300μs,duty≤2%
Rev.1.1 —Oct. 26. 2017
1
www.natlinear.com
NP2N7002VR
Electrical Characteristics (TA=25℃ unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
OFF Characteristics
Drain-source breakdown voltage
BVDSS
VGS=0V, ID=250µA
60
V
Zero gate voltage drain current
IDSS
VDS=48V, VGS=0V
1
µA
Gate-body leakage
IGSS
VDS=0V, VGS=±20V
±10
µA
Gate threshold voltage
VGS(th)
VDS=VGS, ID=250µA
1
1.4
2.5
V
Drain-source on-state resistance
RDS(ON)
VGS=10V, ID=200mA
1.15
2.5
VGS=4.5V, ID=200mA
VGS=0V IS=300mA
VR=25V
dIS/dt=-100A/uS
1.25
3.5
30
14.8
3.6
2.1
10
30
15
1.3
0.4
0.1
1.5
V
Unit
ON Characteristics
Recovered charge
Qr
Ω
nC
Dynamic Characteristics
Input capacitance
CISS
Output capacitance
COSS
Reverse transfer capacitance
CRSS
VDS=30V ,VGS=0V
f=1.0MHz
pF
Switching Characteristics
Turn-on delay time
VDD=5V
VGS=10V
RL=250ohm
RGEN=50ohm
tD(ON)
Rise time
tr
Turn-off delay time
tD(OFF)
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
VDS=30V,ID=200mA
VGS=10V
ns
nC
DRAIN-SOURCE DIODE CHARACTERISTICS
Diode forward voltage
VSD
VGS=0V,Is=300mA
Thermal Characteristics
Parameter
Symbol
Typ
max
Thermal Resistance-Junction to Case
Rθjc
1.7
Thermal Resistance junction-to ambient
RθJa
62.5
2
℃/W
www.natlinear.com
NP2N7002VR
Typical Performance Characteristics
3
www.natlinear.com
NP2N7002VR
4
www.natlinear.com
NP2N7002VR
Package Information
SOT-23-3L
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
5
www.natlinear.com
很抱歉,暂时无法提供与“NP2N7002VR-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09580
- 500+0.07528
- 3000+0.06167
- 国内价格
- 20+0.24100
- 100+0.14370
- 800+0.10060
- 3000+0.07190
- 6000+0.06830
- 30000+0.06330
