S9018
S9018
    DOESHARE(德芯)
    SOT-23
    SOT-23封装NPN晶体管,适用于AM/FM放大器、FM/VHF调谐器本地振荡器,具有高电流增益带宽积
S9018 数据手册
S9018 S9018 NPN Transistors General description SOT-23 Plastic-Encapsulate Transistors FEATURES • AM/FM Amplifier, Local Oscillator of FM/VHF Tuner • High Current Gain Bandwidth Product MARKING:J8 Maximum Ratings & Thermal Characteristics Symbol TA = 25°C unless otherwise noted Parameter Value Unit VCBO Collector-Base Voltage 30 V VCEO Collector-Emitter Voltage 15 V VEBO Emitter-Base Voltage 5 V IC Collector Current -Continuous 50 mA PC Collector Power Dissipation 200 mW 5ș-$ Thermal Resistance from Junction to Ambient 625 ℃/W TJ,Tstg Operation Junction and Storage Temperature Range -55-150 ℃ Electrical Characteristics Parameter TA = 25°C unless otherwise noted Symbol Collector-base breakdown voltage V(BR)CBO Collector-emitter breakdown voltage V(BR)CEO Emitter-base breakdown voltage V(BR)EBO ICBO Collector cut-off current Collector cut-off current ICEO Emitter cut-off current IEBO DC current gain hFE(1) Collector-emitter saturation voltage Base-emitter saturation voltage Range www.doeshare.net IC= 100μA, IE=0 IC= 1mA, IB=0 IE=100μA, IC=0 Min Typ Max 30 V 15 V 5 V VCB=12V, IE=0 0.05 VCE=12V, IB=0 0.1 VEB= 3V, IC=0 0.1 VCE=5V, IC= 1mA Unit μA μA μA 200 70 VCE(sat) IC=10mA, IB= 1mA 0.5 V VBE(sat) IC=10mA, IB= 1mA 1.4 V fT Transition frequency CLASSIFICATION OF hFE(1) Rank Test conditions VCE=5V, IC= 5mA f=400MHz 800 L H 70-100 100-200 MHz S9018 Typical characteristics www.doeshare.net S9018 SOT-23 PACKAGE OUTLINE Plastic surface mounted package Recommended land dimensions for SOT-23 diode. Electrode patterns for PCBs www.doeshare.net S9018 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
S9018 价格&库存
很抱歉,暂时无法提供与“S9018”相匹配的价格&库存,您可以联系我们找货
