S9013
S9013
    DOESHARE(德芯)
    SOT-23
    NPN 25V 500mA 120-400 SOT-23
S9013 数据手册
S9013 S9013 NPN Transistors General description SOT-23 Plastic-Encapsulate Transistors FEATURES • Complementary to S9012 • Power Dissipation of 300mW • High Stability and High Reliability MECHANICAL DATA • SOT-23 Small Outline Plastic Package • Epoxy UL: 94V-0 • Mounting Position: Any Marking: J3 Maximum Ratings & Thermal Characteristics TA = 25°C unless otherwise noted Parameters Symbol Value Unit Collector-Base Voltage VCBO 40 V Collector-Emitter Voltage VCEO 25 V Emitter -Base Voltage VEBO 5 V Collector Current-Continuous IC 500 mA Collector Power Dissipation PC 300 mW Junction Temperature Tj 150 ℃ Storage Temperature Tstg -55-+150 ℃ Thermal resistance From junction to ambient RθJA 416 ℃/W Electrical Characteristics TA = 25°C unless otherwise noted Symbols Collector-base breakdown voltage Collector-emitter breakdown voltage Emitter-base breakdown voltage Collector cut-off current Collector cut-off current Emitter cut-off current V(BR)CBO IC=100uA, IE=0 40 V V(BR)CEO IC=1mA, IB=0 25 V V(BR)EBO IE=100uA, IC=0 5 V DC current gain Collector-emitter saturation voltage Base -emitter saturation voltage Base -emitter voltage Transition frequency Collector output capacitance CLASSIFICATION OF hFE(1) www.doeshare.net Test Condition Limits Parameter Min Max Unit ICEO VCE=20V, IB=0 100 nA ICBO VCB=40V, IE=0 100 nA IEBO VEB=5V, IC=0 100 nA hFE(1) VCE=1V, IC=50mA 120 40 400 hFE(2) VCE=1V, IC=500mA VCE(sat) IC=500mA, IB=50mA VBE(sat) IC=500mA, IB=50mA 1.20 V VCB=1V, IC=10mA 0.70 V VBE fT Cob VCE=6V, IC=20mA,f=30MHz VCB=6V, IE=0, f=1MHz 0.60 150 V MHz 8 pF S9013 Typical characteristics www.doeshare.net S9013 SOT-23 PACKAGE OUTLINE Plastic surface mounted package Recommended land dimensions for SOT-23 diode. Electrode patterns for PCBs www.doeshare.net S9013 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
S9013 价格&库存
很抱歉,暂时无法提供与“S9013”相匹配的价格&库存,您可以联系我们找货
