DTC113ZCA
DTC113ZCA
    PSI(宝力芯)
    SOT23-3
    数字晶体管(NPN型)
DTC113ZCA 数据手册
DATA SHEET DTC113ZCA DIGITAL TRANSISTORS (NPN) VOLTAGE 50 Volts CURRENT 100 mA FEATURES  Built-in bias resistor enable the configuration of an inverter circuit without connecting external input resistors  The bias resistors consist of thin-film resistors with complete isolation to allow negative biasing of the input. They also have the advantage of almost completely eliminating parasitic effects  Only the on/off conditions need to be set for operation, making device design easy.  Lead free and halogen-free. 3 2 1 MECHANICAL DATA  NPN digital transistor  Built-in resistor types (1) IN (2) GND (3) OUT CASE:SOT-23 MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTIC MAXIMUM RATINGES(@ TA=25°C UNLESS OTHERWISE NOTED) PARAMETER SYMBOL VALUE Supply Voltage VCC 50 Input Voltage VIN -10~30 IO 100 Output Current IC(MAX) 100 Power Dissipation PD 200 Junction Temperature TJ 150 Storage Temperature Range TSTG - 55 to + 150 ELECTRICAL CHARACTERISTICS (AT TA =25°C UNLESS OTHERWISE NOTED) PARAMETER CONDITIONS SYMBOL MIN. TYP VCC=5V, IO=100uA VI(off) Input Voltage VO=0.3V, IO=20mA VI(on) 3 Output Voltage IO/II=10mA/0.5mA VO(on) Input Current VI=5V II Output Current VCC=50V,VI=0V IO(off) DC Current Again VO=5V, IO=5mA GI 33 Resistance Ratio R2/R1 8 10 Transition Frequency VO=10V, IO=5mA, f=100MHz fT 250 Input Resistance R1 0.7 1.0 UNITS V V mA mA mW °C °C MAX. 0.3 0.3 7.2 0.5 12 1.3 UNIT V V V mA µA MHz KΩ PAGE.1 ELECTRICAL CHARACTERISTIC CURVES All figures are measured at TA = 25°C, unless otherwise noted. (1). VI(on) vs. IO (On Characteristics) (3). DC Current Gain vs. IO (2). IO vs. VI(off) (Off Characteristics) (4). VO(on) vs. IO PAGE.2 SOT-23 DIMENSION Symbol L L1 W W1 E H H1 D T θ Dimensions In Millimeters Min Max 2.80 3.10 0.30 0.50 2.25 2.54 1.20 1.40 1.80 2.00 0.90 1.15 0.40 0.80 0.30 0.50 0.08 0.15 0∘ 8∘ Dimensions In Inches Min Max 0.110 0.122 0.012 0.020 0.089 0.100 0.047 0.055 0.071 0.079 0.035 0.045 0.016 0.031 0.012 0.020 0.003 0.006 0∘ 8∘ PAGE.3
DTC113ZCA 价格&库存
很抱歉,暂时无法提供与“DTC113ZCA”相匹配的价格&库存,您可以联系我们找货
