DS14 SOD-123FL
DS14 SOD-123FL
    YINT(音特电子)
    SMF(SOD-123FL)
    电压:40V 电流:1A
DS14 SOD-123FL 数据手册
SCHOTTKY BARRIER DIODE SOD123FL Trustworthy electronic circuit protection expert DS12 thru DS120 SOD-123FL SCHOTTKY BARRIER DIODE Features ●Metal silicon junction, majority carrier conduction ●For surface mounted applications ●Low power loss, high efficiency ●High forward surge current capability 1. Cathode 2. Anode ●For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Mechanical Data Case: SOD-123FL Terminals: Solderable per MIL-STD-750, Method 2026 Absolute Maximum Ratings and Electrical characteristics Ratings at 25℃ ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols DS12 DS14 DS16 DS18 DS110 DS112 DS115 DS120 Units Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 84 105 140 V VDC 20 40 60 80 100 120 150 200 V Maximum DC Blocking Voltage Maximum Average Forward Rectified Current IF(AV) 1 A IFSM 25 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) Max Instantaneous Forward Voltage at 1 A Maximum DC Reverse Current Ta=25℃ at Rated DC Reverse Voltage Ta=100℃ Typical Junction Capacitance1 Typical Thermal Resistance2 Operating Junction Temperature Range Storage Temperature Range VF 0.55 IR Cj 0.70 0.85 0.90 0.3 0.2 0.1 10 5 2 110 80 V mA pF RθJA 100 ℃/W Tj -55 ~ +125 ℃ Tstg -55 ~ +150 ℃ 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 1 REV 21.1 SCHOTTKY BARRIER DIODE SOD123FL Trustworthy electronic circuit protection expert Fig.1 Forward Current Derating Curve Fig.2 Typical Reverse Characteristics Fig.3 Typical Forward Characteristic Fig.4Typical Junction Capacitance Fig.5 Maximum Non-Repetitive Peak Forward Surge Current Fig.1 Forward Current Derating Curve 2 REV 21.1 SCHOTTKY BARRIER DIODE SOD123FL Trustworthy electronic circuit protection expert Package Outline SOD-123FL Disclaimer Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. 3 REV 21.1
DS14 SOD-123FL 价格&库存
很抱歉,暂时无法提供与“DS14 SOD-123FL”相匹配的价格&库存,您可以联系我们找货
