SHEN ZHEN XIN FEI HONG ELECTRONICS CO.,LTD
-30V P-Channel MOSFET
FH17P03D
Description
FH17P03D series are from Advanced Power innovated design
and silicon process technology to achieve the lowest possible
on-resistance and fast switching performance. It provides the
designer with an extreme efficient device for use in a wide
range of power applications.
The TO-252 package is widely preferred for all commercial
-industrial surface mount applications using infrared reflow
technique and suited for high current application due to the
low connection resistance. The through-hole version
(FH17P03D) are available for low-profileapplications.
TO-252
BV DSS
-30V
RDS(ON MAX)
9mΩ
ID
-70A
Low On-resistance
Simple Drive Requirement
Fast Switching Characteristic
RoHS Compliant & Halogen-Free
R DS(ON) =7.5m Ω (MAX) @V GS =10V
D
D
G
G
S
S
Schematic diagram
TO-252 top view
Marking and pin assignment
Absolute Maximum Ratings@Tj=25o.C(unless otherwise specified)
Parameter
Rating
Units
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
+20
V
I D@T C=25℃
Drain Current, VGS @ 10V
-70
A
I D@T C=100℃
-40
A
-240
A
54.3
W
Symbol
VDS
1
I DM
Pulsed Drain Current
PD @T C=25℃
Total Power Dissipation
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Rthj-c
Parameter
Maximum Thermal Resistance Junction-case
3
Value
Units
2.3
℃/W
℃/W
℃/W
Rthj-a
Maximum Thermal Resistance, Junction-ambient (PCB mount)
62.5
Rthj-a
110
www.xfhong.com
1/5
Ver1.0
FH17P03D
Electrical Characteristics@Tj=25oC(unless otherwise specified)
Symbol
Parameter
Test Conditions
Min.
Typ.
Max. Units
BVDSS
Drain-Source Breakdown Voltage
VGS=0V, ID=-250uA
-30
V
RDS(ON)
Static Drain-Source On-Resistance2
VGS=-10V, ID=-40A
7.8
9
mΩ
VGS=-4.5V, ID=-30A
12
15
mΩ
-1
-1.35
-3
V
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=-250uA
gfs
Forward Transconductance
VDS=-10V, ID=-30A
60
S
IDSS
Drain-Source Leakage Current
VDS=-24V, VGS=0V
-10
uA
IGSS
Gate-Source Leakage
VGS= +20V, VDS=0V
+100
nA
ID=-30A
44
70
nC
2
Qg
Total Gate Charge
Qgs
Gate-Source Charge
VDS=-24V
6.5
nC
Qgd
Gate-Drain ("Miller") Charge
VGS=-4.5V
28.5
nC
VDS=-15V
11
ns
2
td(on)
Turn-on Delay Time
tr
Rise Time
ID=-30A
67
ns
td(off)
Turn-off Delay Time
RG=1Ω
37
ns
tf
Fall Time
VGS=-10V
22
ns
Ciss
Input Capacitance
VGS=0V
3500 5600
pF
Coss
Output Capacitance
VDS=-25V
520
pF
Crss
Reverse Transfer Capacitance
f=1.0MHz
495
pF
Rg
Gate Resistance
f=1.0MHz
2
Ω
Min.
Typ.
Source-Drain Diode
Symbol
Parameter
2
Test Conditions
Max. Units
VSD
Forward On Voltage
IS=-30A, VGS=0V
-1.2
V
trr
Reverse Recovery Time
IS=-10A, VGS=0V,
34
ns
Qrr
Reverse Recovery Charge
dI/dt=100A/µs
30
nC
Notes:
1.Pulse width limited by Max. junction temperature.
2.Pulse test
3.Surface mounted on 1 in2 copper pad of FR4 board
www.xfhong.com
2/5
Ver1.0
FH17P03D
240
160
T C = 25 o C
-ID , Drain Current (A)
200
T C = 150 o C
-10V
-7.0 V
-6.0 V
-5.0 V
160
V G = - 4.0 V
120
80
120
-10V
-7.0V
-6.0V
-5.0V
V G = - 4.0 V
80
40
40
8
12
4
6
8
10
-V DS , Drain-to-Source Voltage (V)
Fig 1. Typical Output Characteristics
Fig 2. Typical Output Characteristics
14
2.0
I D = -30 A
T C =25 ℃
I D = -40A
V G = -10V
1.8
12
1.6
10
Normalized RDS(ON)
RDS(ON) (mΩ )
2
8
1.4
1.2
1.0
0.8
0.6
0.4
6
2
4
6
8
10
-50
100
150
T j , Junction Temperature ( o C)
-V GS , Gate-to-Source Voltage (V)
Fig 3. On-Resistance v.s. Gate Voltage
Fig 4. Normalized On-Resistance
v.s. Junction Temperature
40
1.6
1.4
T j =150 o C
Normalized VGS(th)
-IS(A)
30
T j =25 o C
1
0.8
10
0.6
0.4
0.8
1.2
-50
1.6
50
100
150
o
-V SD , Source-to-Drain Voltage (V)
T j , Junction Temperature ( C)
Fig 5. Forward Characteristic of
Fig 6. Gate Threshold Voltage v.s.
Reverse Diode
www.xfhong.com
Ver1.0
FH17P03D
10
-VGS , Gate to Source Voltage (V)
8
4000
C iss
C (pF)
V DS =-24V
I D =-30A
6
3000
4
2000
2
1000
C oss
C rss
60
1
80
5
9
13
17
21
25
29
Q G , Total Gate Charge (nC)
Fig 7. Gate Charge Characteristics
Fig 8. Typical Capacitance Characteristics
1000
Operation in this area
limited by RDS(ON)
100us
1ms
10
10ms
100ms
DC
T C =25 o C
Single Pulse
1
Normalized Thermal Response (Rthjc)
1
-ID (A)
100
f=1.0MHz
5000
Duty factor=0.5
0.2
0.1
0.1
0.05
PDM
t
0.02
T
0.01
Duty factor = t/T
Peak Tj = PDM x Rthjc + T C
Single Pulse
0.01
0.1
1
10
100
0.00001
0.0001
0.001
0.01
0.1
1
10
t , Pulse Width (s)
Fig 9. Maximum Safe Operating Area
Fig 10. Effective Transient Thermal Impedance
VG
VDS
90%
QG
-4.5V
QGS
QGD
10%
VGS
td(on) tr
td(off)tf
Charge
Fig 11. Switching Time Waveform
www.xfhong.com
Q
Fig 12. Gate Charge Waveform
4/5
Ver1.0
FH17P03D
TO-252 Package Information
Symbol
Dimensions In Millimeters
Min.
Dimensions In Inches
Max.
Min.
Max.
A
2.200
2.400
0.087
0.094
A1
0.000
0.127
0.000
0.005
b
0.660
0.860
0.026
0.034
c
0.460
0.580
0.018
0.023
D
6.500
6.700
0.256
0.264
D1
5.100
5.460
0.201
0.215
4.830TYP.
D2
0.190 TYP.
E
6.000
6.200
0.236
0.244
e
2.186
2.386
0.086
0.094
L
9.800
10.400
0.386
0.409
2.900 TYP.
L1
L2
1.400
L3
0.114 TYP.
1.700
0.055
0.067
0.063 TYP.
1.600 TYP.
L4
0.600
1.000
0.024
0.039
Φ
1.100
1.300
0.043
0.051
θ
0°
8°
0°
8°
h
0.000
0.300
0.000
0.012
V
www.xfhong.com
5.350 TYP.
0.211 TYP.
5/5
Ver1.0
很抱歉,暂时无法提供与“FH17P03D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.53220
- 50+1.19999
- 150+1.05765
- 500+0.87999
- 2500+0.80093
- 5000+0.75341
