2SD965A-R-T89R
2SD965A-R-T89R
    PSI(宝力芯)
    SOT89-3
    2SD965A-R-T89R
2SD965A-R-T89R 数据手册
DATA SHEET 2SD965/965A NPN PLASTIC ENCAPSULATE TRANSISTORS VOLTAGE 20~30 V CURRENT 5 A FEATURES TO-92 SOT-89 z LOW VOLTAGE AND HIGH CURRENT z EXCELLENT hFE CHARACTERISTICS z COLLECTOR-EMITTER VOLTAGE 20V FOR 2SD965 z COLLECTOR-EMITTER VOLTAGE 30V FOR 2SD965A z LEAD FREE AND HALOGEN-FREE E C MECHANICAL DATA EC B z CASE: SOT-89, TO-92 z SOLDERABILITY: MIL-STD-202, Method 208 z APPROX. WEIGHT: 0.045 GRAMS FOR SOT-89 z APPROX. WEIGHT: 0.02 GRAMS FOR TO-92 B CASE: SOT-89, TO-92 ABSOLUTE MAXIMUM RATINGS TA = 25°C, UNLESS OTHERWISE NOTED. PARAMETER COLLECTOR-BASE VOLTAGE COLLECTOR-EMITTER VOLTAGE 2SD965 2SD965A EMITTER-BASE VOLTAGE SYMBOL VALUE UNITS VCBO 40 V VCEO VEBO 20 V 30 V 7 V COLLECTOR CURRENT-CONTINUOUS IC 5 A COLLECTOR POWER DISSIPATION PC 750 mW RθJA 167 °C/W TJ 150 °C THERMAL RESISTANCE, JUNCTION TO AMBIENT JUNCTION TEMPERATURE STORAGE TEMPERATURE RANGE TSTG - 55 to + 150 NOTE: 1. THE VALUE OF RθJA IS MEASURED WITH DEVICE MOUNTED ON 1 IN2 FR-4 BOARD WITH 2 OZ COPPER. °C PAGE.1 ELECTRICAL CHARACTERISTICS TA = 25°C, UNLESS OTHERWISE NOTED. PARAMETER COLLECTOR-BASE BREAKDOWN VOLTAGE SYMBOL TEST CONDITIONS MIN. TYP MAX. UNIT V(BR)CBO IC=0.1mA, IE=0 40 - - V 2SD965 20 - - 2SD965A 30 - - COLLECTOR-EMITTER BREAKDOWN VOLTAGE V(BR)CEO EMITTER-BASE BREAKDOWN VOLTAGE IC=1mA, IB=0 V V(BR)EBO IE=10µA, IC=0 7 - - V COLLECTOR CUT-OFF CURRENT ICBO VCB=10V, IE=0 - - 0.1 µA EMITTER CUT-OFF CURRENT IEBO µA DC CURRENT GAIN COLLECT-EMITTER SATURATION VOLTAGE TRANSITION FREQUENCY COLLECTOR OUTPUT CAPACITANCE hFE VEB=7V, IC=0 - - 0.1 VCE=2V, IC=1mA - 200 - VCE=2V, IC=500mA 230 - 800 - VCE=2V, IC=2A 150 - - VCE(SAT) IC=3A, IB=0.1A - - 1 V fT VCE=6V, IC=50mA - 150 - MHz Cob VCB=20V, IE=0, f =1MHz - - 50 pF ORDERING INFORMATION PART NUMBER 2SD965-▲-T89R 2SD965A-▲-T89R 2SD965-▲-T92 2SD965-▲-T92B 2SD965A-▲-T92 2SD965A-▲-T92B PACKAGE SOT-89 SOT-89 TO-92 TO-92 TO-92 TO-92 SHIPPING TAPE REEL TAPE REEL BULK TAPE BOX BULK TAPE BOX NOTE: 1. ▲: RANK OF hFE, SEE CLASSIFICATION OF hFE CLASSIFICATION OF hFE RANK RANGE Q 230~380 R 340~600 S 560~800 PAGE.2 TYPICAL PERFORMANCE CHARACTERISTICS PAGE.3 PAGE.4 SOT-89 DIMENSION Symbol L L1 E E1 E2 W W1 W2 H T Dimensions In Millimeters Min Max 4.40 4.70 1.55 1.75 3.00 TYP 0.40 0.58 0.32 0.52 3.94 4.25 2.30 2.60 0.90 1.20 1.45 1.60 0.35 0.44 Dimensions In Inches Min Max 0.173 0.185 0.061 0.069 0.118 TYP 0.016 0.023 0.013 0.020 0.155 0.167 0.091 0.102 0.035 0.047 0.057 0.063 0.014 0.017 PAGE.5 TO-92 DIMENSION Symbol L W W1 A B B1 B2 B3 H H1 H2 D φ Dimensions In Millimeters Min Max 4.30 4.70 4.40 4.70 3.43 13.80 14.20 0.40 0.60 0.38 0.55 1.27 TYP 2.44 2.64 3.30 3.70 1.10 1.40 0.36 0.51 0.38 1.60 - Dimensions In Inches Min Max 0.169 0.185 0.173 0.185 0.135 0.543 0.559 0.016 0.024 0.015 0.022 0.050 TYP 0.096 0.104 0.130 0.146 0.043 0.055 0.014 0.020 0.015 0.063 - PAGE.6
2SD965A-R-T89R 价格&库存
很抱歉,暂时无法提供与“2SD965A-R-T89R”相匹配的价格&库存,您可以联系我们找货
