2SD1898Q
2SD1898Q
    SK(時科)
    SOT89-3
    NPN 电流:1A 电压:32V
2SD1898Q 数据手册
2SD1898 NPN-General use transistor 1W 、1.0A、32V 4 Applications: Can be used for switching and amplifying in 1 various electrical and electronic equipments 3 SOT SOT-89 1:Base 2:Collector Collector 33:Emitter Absolute Maximum Ratings (Ta = 25℃) parameters 2 symbol rating collector-emitter voltage(IB=0) VCEO 32 unit V collector-base voltage(IE=0) VCBO 40 V emitter - base voltage(IC=0) VEBO 6 V Collector current IC 1 A Total power dissipation (TA=25℃)* Ptot 1 W Max junction temperature Tjm 150 ℃ Storage temperature Tstg -55~150 ℃ * mounted on printed circuit board. Electrical Characteristics (Ta = 25℃) (Unless otherwise specified) specified parameters symbol collector-emitter breakdown voltage V(BR)CEO collector- base breakdown voltage emitter - base breakdown voltage Forward current transfer ratio1) min typ max unit IC=2mA,IB=0 32 — — V V(BR)CBO IC=100µA,IE=0 40 — — V V(BR)EBO IE=100µA,IC=0 6 — — V 2SD1898Q 120 hFE 270 VCE=1V;IC=100mA 2SD1898R — 180 — 390 collector-base cutoff current ICBO VCB=35V,IE=0 — — 100 nA emitter-base cutoff current IEBO VEB=6V,IC=0 — — 100 nA IC=800mA,IB=80mA — — 0.5 V IC=50mA VCE=10V,f=100MHz — 100 — MHz collector-emitter saturation voltage1) VCE(sat) Transition frequency 1) Test condition fT pulse method:tw:300µs,duty ratio≤2% %. REV.08 1 of 2 2SD1898 Outline dimensions(see fig.1) unit:mm dimensions symbols A b b1 b2 c D E e e1 HE L LE α REV.08 2 of 2 min 1.4 0.35 0.4 SOT-89 typ max 1.6 0.55 0.65 1.6 0.35 4.4 2.35 0.45 4.6 2.55 1.5 3 4.15 2.7 1.0 5o
2SD1898Q 价格&库存
很抱歉,暂时无法提供与“2SD1898Q”相匹配的价格&库存,您可以联系我们找货
2SD1898Q
    • 1000+0.18645
    库存:29400
    2SD1898Q
    • 10+0.55955
    • 100+0.47164
    • 300+0.42768
    • 1000+0.37098
    • 5000+0.34463
    • 10000+0.33135
    库存:903
    2SD1898Q
      • 1000+0.18645
      库存:600
