2SD2150R
2SD2150R
    SK(時科)
    SOT89-3
    NPN 电流:3A 电压:30V
2SD2150R 数据手册
2SD2150 NPNGeneral use transistor 1.2W 3A 30V 4 Applications:Can be used for switching and amplifying in 1 various electrical and electronic equipments. 2 3 SOT-89 MAX RATING Parameters Symbol Rating Collector–emitter voltage(IB=0) VCEO 30 Unit V Collector–base voltage(IE=0) VCBO 40 V Emitter – base voltage(IC=0) VEBO 5 V IC 3 A Ptot 1.2 W Max junction temperature Tjm 150 ℃ Storage temperature Tstg -55~150 ℃ Collector current Total power (TA=25℃)* dissipation * mounted on printed circuit board. Characteristics(Unless otherwise specified,TA=25℃) Parameters symbol Collector–emitter breakdown voltage V(BR)CEO Collector–base breakdown voltage Emitter– base breakdown voltage Forward current transfer R ratio1) Collector–emitter saturation voltage1 ) Transition frequency REV.08 typ max unit IC=10mA,IB=0 30 — — V V(BR)CBO IC=1mA,IE=0 40 — — V V(BR)EBO IE=1mA,IC=0 5 — — V 180 — 390 — 270 — 560 — VCB=30V,IE=0 — — 1 μA IC=2A,IB=200mA — — 0.5 V — 90 — MHz VCE=2V;IC=1A S Collector–base cutoff current 1) min hFE Test condition ICBO VCE(sat) fT IC=100mA , VCE=5V,f=100MHz pulse method:tw:300µs,duty ratio≤2%. 1 of 2 2SD2150 Typical curve fig.1 Typical curve Outline dimensions unit:mm dimensions symbol A b b1 b2 c D E e e1 HE L LE α Fig.2 Outline dimensions REV.08 2 of 2 min 1.4 0.35 0.4 — 0.35 4.4 2.35 — — — — — — SOT-89 type — — — 1.6 — — — 1.5 3 4.15 2.7 1.0 5o max 1.6 0.55 0.65 — 0.45 4.6 2.55 — — — — — —
2SD2150R 价格&库存
很抱歉,暂时无法提供与“2SD2150R”相匹配的价格&库存,您可以联系我们找货
2SD2150R
  • 10+0.44324
  • 100+0.35543
  • 300+0.31148
  • 1000+0.25467
  • 5000+0.22832
  • 10000+0.21514
库存:446
2SD2150R
    • 1000+0.18631
    库存:17400
    2SD2150R
      • 1000+0.18631
      库存:600
