SE20P03
P-Channel MOSFET
Revision: A
General Description
Features
This series is a high voltage power MOSFET
For a single MOSFET
such as fast switching time, low gate charge,
and is designed to have better characteristics,
VDS = -30V
RDS(ON) = 50mΩ @ VGS=-10V
low on-state resistance and have a high
rugged avalanche characteristics
Pin configurations
See Diagram below
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
Drain Current
Continuous
Pulsed
-19
ID
A
-57
Power Dissipation
PD
30
W
Operating Junction Temperature Range
TJ
-55 to 150
Thermal Resistance
Symbol
RθJA
Parameter
Junction to Ambient
ShangHai Sino-IC Microelectronic Co., Ltd.
Typ
Max
Units
71.4
℃/W
1.
SE20P03
Electrical Characteristics
Symbol
(TJ=25℃ unless otherwise noted)
Parameter
Test Conditions
Min
Typ
Max
Units
OFF CHARACTERISTICS (Note 2)
BVDSS
Drain-Source Breakdown Voltage
VGS=0V, ID=-250μA
IDSS
Drain to Source Leakage Current
VDS= -30V, VGS=0V
-10
μA
IGSS
Gate-Body Leakage Current
VGS=20V
100
nA
VGS(th)
Gate Threshold Voltage
VDS= VGS, ID=-250μA
-3
V
RDS(ON)
Static Drain-Source On-Resistance
VGS=-10V, ID=-10A
50
mΩ
VGS=-4.5V, ID=-5A
90
mΩ
gFS
Forward Transconductance
VDS=-8V, ID=-9.5A
-30
V
-1
6
S
750
pF
345
pF
110
pF
DYNAMIC PARAMETERS
Ciss
Input Capacitance
VGS=0V, VDS=-25V,
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
f=1MHz
SWITCHING PARAMETERS
Qg
Total Gate Charge 2
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
Turn-On Delay Time
td(off)
Turn-Off Delay Time
td(r)
td(f)
15
VGS=-5V, VDS=-24V,
21
nC
3.4
nC
9.7
nC
VDS=-15V, RGEN=3.3Ω
16
ns
ID=-19A
25
ns
Turn-On Rise Time
125
ns
Turn-Off Fall Time
68
ns
ID=-19A
Source-Drain Diode Characteristics
VSD
Drain-Source Diode Forward Voltage
VGS=0V,IS=-19A
-3.4
V
IS
Continuous Source Current
VG=VD=0V,
-19
A
ISM
Pulsed Source Current
Force Current
-57
A
2.
SE20P03
Package Outline Dimension
TO-252
3.
SE20P03
TO-251
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics
Co., Ltd.
© 2005 SINO-IC - Printed in China - All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road,
ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China
Phone:
+86-21-33932402
33932403
33932405 33933508 33933608
Fax: +86-21-33932401
Email: webmaster@sino-ic.com
Website: http://www.sino-ic.com
4.
很抱歉,暂时无法提供与“SE20P03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.17656
- 50+0.93194
- 150+0.82718
- 500+0.69639
