PTY80N06
PTY80N06
    PUOLOP(迪浦)
    TO-263(D²Pak)
    N沟道 耐压:60V 电流:80A
PTY80N06 数据手册
PTP80N60/PTY80N60 60V/80A N-Chnnel MOSFET Features  D 60V/80A RDS(ON)=7.3mŸ @ VGS=10V ◀  Lead free and Green Device Available  Low Rds-on to Minimize Conductive Loss  High avalanche Current  100% Avalanche Tested G S D Application  Power Supply  DC-DC Converters  UPS  Battery Manageme ent System G TO-220 S TO-263 Absolute Maximum Ratings (TA=25°C unless otherwise noted) Symbol S VDSS VGSS ID3 IDP4 EAS5 PD TJ, TSTG Parame eter D Drain-to-Source Voltag ge G Gate-to-Sou urce Voltage e C Continuous Drain Curre ent P Pulsed Drain Current A Avalanche energy e M Maximum Power P Dissip pation JJunction & Storage S Tem mperature R Range TC=25°C C TC=100°°C TC=25°C C TC=25°C C Maximum m Unitt 60 ±25 80 66 320 242 125 -55~175 V V mJ W °C Typical Unit 1.0 62.5 ℃/W A Thermal Characteristics Symbol Rθ jc Rθja Parameter Thermal Resistance-Junction to Case Thermal Resistance-Junction to Ambient - 1- 2018-6-12 PTP80N60/PTY80N60 60V/80A N-Chnnel MOSFET Electrical Characteristics (TA=25°C unless otherwise noted) Symbol Parameter Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS VGS(th) Zero Gate Voltage Drain Current Gate Threshold Voltage IGSS RDS(on)1 Gate Leakage Current Drain-Source On-Resistance Test Conditions Min. Typ Max. Unit VGS=0V,ID=250uA VDS=60V,VGS=0V 60 — — — — 1 VDS=VGS,ID=250uA 2 3 4 VGS=±25V, VDS=0V VGS=10V, ID=40A — — — — 7.3 — ISD=40A, — — — — — — 70 100 1.3 — — — — — — — 3970 365 257 57 63 139 50 — — — — — — — — — — 91 19 30 — V uA V ±100 8 — nA mΩ Diode Characteristics VSD1 IS3 trr Qrr Diode Forward Voltage Diode Continuous Forward Current Reverse Recovery Time Reverse Recovery Charge Dynamic Characteristics2 Ciss Input Capacitance Output Capacitance Coss Reverse Transfer Capacitance Crss td(on) Turn-On Delay Time Rise Time tr Turn-Off Delay Time td(off) Fall Time tf Gate Charge Characteristics2 Qg Total Gate Charge Gate-to-Source Charge Qgs Qgd Gate-to-Drain Charge GS=0V IS=40A, dI/dt=100A/us VGS=0V, VDS=25V Frequency=1MHz VDD=34V,ID =40A, VGS=10V,(Note1,4) VDD=48V,ID =40A, VGS=10V,(Note1,4) 100 — — — — V A nS nC pF nS nC Note: 1: Pulse test; pulse width ≦ 300us, duty cycle ≦ 2%. 2: Guaranteed by design, not subject to production testing. 3: Package limitation current is 100A.Calculated continuous current based on maximum allowable junction temperature. 4: Repetitive rating, pulse width limited by max junction temperature. 5: Starting TJ = 25°C,L = 1mH,IAS = 22A. - 2- 2018-6-12 PTP80N60/PTY80N60 60V/80A N-Chnnel MOSFET ID- Drain Current (A) Normalized On-Resistance Typical Operating Characteristics TJ-Junction Temperature(℃) Vds Drain-Source Voltage (V) Figure 4 Rdson-JunctionTemperature ID- Drain Current (A) Vgs Gate-Source Voltage (V) Figure 1 Output Characteristics Qg Gate Charge (nC) Figure 2 Transfer Characteristics Figure 5 Gate Charge Is- Reverse Drain Current (A) Rdson On-Resistance(mΩ) Vgs Gate-Source Voltage (V) ID- Drain Current (A) Vsd Source-Drain Voltage (V) Figure 3 Rdson- Drain Current Figure 6 Source- Drain Diode Forward - 3- 2018-6-12 PTP80N60/PTY80N60 60V/80A N-Chnnel MOSFET Test Circuit 1) EAS test Circuit 2) Gate charge test Circuit 3) Switch Time Test Circuit - 4- 2018-6-12
PTY80N06
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款具有锁存功能的六进制计数器/分频器 3. 引脚分配:引脚1为Vcc,引脚2为复位,引脚3为时钟输入,引脚4为输出Q0,引脚5为输出Q1,引脚6为输出Q2,引脚7为输出Q3,引脚8为输出Q4,引脚9为输出Q5,引脚10为输出Q6,引脚11为输出Q7,引脚12为输出Q8,引脚13为输出Q9,引脚14为输出Q10,引脚15为输出Q11,引脚16为输出Q12,引脚17为输出Q13,引脚18为输出Q14,引脚19为输出Q15,引脚20为输出Q16,引脚21为输出Q17,引脚22为输出Q18,引脚23为输出Q19,引脚24为输出Q20,引脚25为输出Q21,引脚26为输出Q22,引脚27为输出Q23,引脚28为输出Q24,引脚29为输出Q25,引脚30为输出Q26,引脚31为输出Q27,引脚32为输出Q28,引脚33为输出Q29,引脚34为输出Q30,引脚35为输出Q31,引脚36为输出Q32 4. 参数特性:工作电压范围为3.3V至5.5V,工作频率最高可达100MHz 5. 功能详解:EL817具有同步复位功能,支持上升沿和下降沿触发的时钟输入 6. 应用信息:适用于频率分频、计数器、定时器等应用场景 7. 封装信息:采用TSSOP36封装
PTY80N06 价格&库存
很抱歉,暂时无法提供与“PTY80N06”相匹配的价格&库存,您可以联系我们找货
