VBL2610N
VBL2610N
    VBSEMI(微碧)
    TO-263(D²Pak)
    1个P沟道 耐压:60V 电流:30A
VBL2610N 数据手册
VBL2610N www.VBsemi.com P-Channel 60-V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) RDS(on) (Ω) - 60 ID (A) 0.064 at V GS = - 10 V - 30 0.077 at VGS = - 4.5 V - 28 • TrenchFET® Power MOSFET • 100 % UIS Tested Qg (Typ) APPLICATIONS 12 • Load Switch S D2PAK (TO-263) G G D S D P-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted Parameter Gate-Source Voltage Continuous Drain Current (TJ = 175 °C) TC = 25 °C TC = 100 °C Symbol Limit Unit VGS ± 20 V - 30 ID - 20 IDM - 90 Continuing Source Current (Diode Conduction) IS - 28 Avalanche Current IAS - 31 EAS 7.2 Pulsed Drain Current Single Pulse Avalanche Energy Maximum Power Dissipation L = 0.1 mH TC = 25 °C TA = 25 °C mJ 60 a PD W 6b TJ, Tstg Operating Junction and Storage Temperature Range A - 55 to 175 °C THERMAL RESISTANCE RATINGS Parameter Junction-to-Ambientb Junction-to-Case Symbol t ≤ 10 sec Steady State RthJA RthJC Typical Maximum 20 25 62 75 5 6 Unit °C/W Notes: a. See SOA curve for voltage derating. b. Surface Mounted on 1" x 1" FR-4 boad. 服务热线:400-655-8788 1 VBL2610N www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min V(BR)DSS VGS = 0 V, ID = - 250 µA - 60 VGS(th) VDS = VGS, ID = - 250 µA - 1.0 IGSS VDS = 0 V, VGS = ± 20 V Typa Max - 2.0 - 3.0 Unit Static Drain-Source Breakdown Voltage Gate Threshold Voltage Gate-Body Leakage Zero Gate Voltage Drain Current On-State Drain Currentb IDSS Drain-Source On-State Resistanceb b Forward Transconductance Dynamic rDS(on) ± 100 VDS = - 60 V, VGS = 0 V -1 VDS = - 60 V, VGS = 0 V, TJ = 125 °C - 50 VDS = - 60 V, VGS = 0 V, TJ = 175 °C - 150 ID(on) VDS = - 5 V, VGS = - 10 V VGS = - 10 V, ID = - 5 A, TJ = 125 °C 0.110 VGS = - 10 V, ID = - 5 A, TJ = 175 °C 0.250 VGS = - 4.5 V, ID = - 2 A 0.077 VDS = - 15 V, ID = - 5 A 8 Input Capacitance Ciss Coss Reverse Transfer Capacitance Crss 110 Total Gate Charge Qg 12.5 Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Rg td(on) Turn-Off Delay Timec td(off) Turn-On Delay Rise Timec Fall Timec tr µA A 0.064 Output Capacitance Timec nA - 10 VGS = - 10 V, ID = - 5 A gfs V Ω S 1000 VDS = - 25 V, VGS = 0 V, f = 1 MHz pF 210 VDS = - 30 V, VGS = - 10 V, ID = - 8.4 A 2.3 f = 1 MHz 8.0 19 nC 3.2 VDD = - 30 V, RL = 3.57 Ω ID ≅ - 8.4 A, VGEN = - 10 V, RG = 2.5 Ω tf Ω 5 10 14 25 15 25 7 12 - 0.9 - 1.3 ns b Source-Drain Diode Ratings and Characteristics (TC = 25 °C) Pulsed Current ISM Forward Voltageb VSD Reverse Recovery Time trr Reverse Recovery Time Qrr - 30 IF = - 2 A, VGS = 0 V IF = - 8 A, di/dt = 100 A/µs A V 50 80 ns 80 120 nC Notes: a. Guaranteed by design, not subject to production testing. b. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 VBL2610N www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C unless noted 20 30 TC = - 55 °C VGS = 10 thru 6 V 25 °C 16 ID - Drain Current (A) I D - Drain Current (A) 24 5V 18 12 4V 12 125 °C 8 4 6 3V 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 2 0 4 6 8 10 VGS - Gate-to-Source Voltage (V) VDS - Drain-to-Source Voltage (V) Output Characteristics Transfer Characteristics 12 0.150 TC = - 55 °C 0.125 25 °C rDS(on) - On-Resistance (Ω) g fs - Transconductance (S) 10 125 °C 8 6 4 2 VGS = 4.5 V 0.100 VGS = 10 V 0.075 0.050 0.025 0 0.000 0 2 4 8 6 10 0 4 8 ID - Drain Current (A) 16 20 ID - Drain Current (A) Transconductance On-Resistance vs. Drain Current 2400 20 V GS - Gate-to-Source Voltage (V) 2100 1800 C - Capacitance (pF) 12 Ciss 1500 1200 900 600 Coss 300 Crss 0 0 VDS = 30 V ID = 8.4 A 16 12 8 4 0 10 20 30 40 VDS - Drain-to-Source Voltage (V) Capacitance 50 60 0 5 10 15 20 25 Qg - Total Gate Charge (nC) Gate Charge 服务热线:400-655-8788 3 VBL2610N www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C unless noted 2.3 2.0 10 VGS = 10 V ID = 50 A TJ = 150 °C I S - Source Current (A) rDS(on) - On-Resistance (Normalized) 1 1.7 1.4 1.1 0.1 TJ = 25 °C 0.01 0.8 0.5 - 50 0.001 - 25 0 25 50 75 100 125 150 175 0.0 TJ - Junction Temperature (°C) 0.2 0.4 0.6 0.8 1.0 VSD - Source-to-Drain Voltage (V) On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage THERMAL RATINGS 10 100 8 10 I D - Drain Current (A) I D - Drain Current (A) 10 µs 6 4 1 ms 1 10 ms 100 ms, DC 0.1 TC = 25 °C Single Pulse 0.01 2 0 100 µs *Limited by rDS(on) 0.001 0 25 50 75 100 125 150 TC - Case Temperature (°C) Drain Current vs. Case Temperature 175 0.1 1 10 100 VDS - Drain-to-Source Voltage (V) *VGS minimum VGS at which rDS(on) is specified Safe Operating Area 服务热线:400-655-8788 4 VBL2610N www.VBsemi.com THERMAL RATINGS 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-−4 10- 3 10- 2 10- 1 1 10 100 600 100 600 Square Wave Pulse Duration (sec) Normalized Thermal Transient Impedance, Junction-to-Ambient 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-−4 10- 3 10- 2 10- 1 1 10 Square Wave Pulse Duration (sec) Normalized Thermal Transient Impedance, Junction-to-Case 服务热线:400-655-8788 5 VBL2610N www.VBsemi.com TO-263AB A (Datum A) 3 4 A 4 L1 B A E c2 H Gauge plane 4 0° to 8° 5 D B Detail A Seating plane H 1 2 C 3 C L L3 L4 Detail “A” Rotated 90° CW scale 8:1 L2 B A1 B A 2 x b2 c 2xb E 0.010 M A M B ± 0.004 M B 2xe Plating 5 b1, b3 Base metal c1 (c) D1 4 5 (b, b2) Lead tip MILLIMETERS DIM. MIN. 4 E1 Section B - B and C - C Scale: none View A - A INCHES INCHES MILLIMETERS MAX. MIN. MAX. DIM. MIN. MAX. MIN. MAX. A 4.06 4.83 0.160 0.190 D1 6.86 - 0.270 - A1 0.00 0.25 0.000 0.010 E 9.65 10.67 0.380 0.420 b 0.51 0.99 0.020 0.039 E1 6.22 - 0.245 - b1 0.51 0.89 0.020 0.035 e b2 1.14 1.78 0.045 0.070 H 14.61 2.54 BSC 15.88 0.575 b3 1.14 1.73 0.045 0.068 L 1.78 2.79 0.070 0.110 c 0.38 0.74 0.015 0.029 L1 - 1.65 - 0.066 c1 0.38 0.58 0.015 0.023 L2 - 1.78 - c2 1.14 1.65 0.045 0.065 L3 D 8.38 9.65 0.330 0.380 L4 0.25 BSC 4.78 5.28 0.100 BSC 0.625 0.070 0.010 BSC 0.188 0.208 ECN: S-82110-Rev. A, 15-Sep-08 DWG: 5970 Notes 1. Dimensioning and tolerancing per ASME Y14.5M-1994. 2. Dimensions are shown in millimeters (inches). 3. Dimension D and E do not include mold flash. Mold flash shall not exceed 0.127 mm (0.005") per side. These dimensions are measured at the outmost extremes of the plastic body at datum A. 4. Thermal PAD contour optional within dimension E, L1, D1 and E1. 5. Dimension b1 and c1 apply to base metal only. 6. Datum A and B to be determined at datum plane H. 7. Outline conforms to JEDEC outline to TO-263AB. 服务热线:400-655-8788 6 VBL2610N www.VBsemi.com RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead 0.420 0.355 0.635 (16.129) (9.017) (10.668) 0.145 (3.683) 0.135 (3.429) 0.200 0.050 (5.080) (1.257) Recommended Minimum Pads Dimensions in Inches/(mm) 服务热线:400-655-8788 7 VBL2610N www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBL2610N 价格&库存
很抱歉,暂时无法提供与“VBL2610N”相匹配的价格&库存,您可以联系我们找货
