VBL165R18
VBL165R18
    VBSEMI(微碧)
    TO-263(D²Pak)
    1个N沟道 耐压:650V 电流:16A
VBL165R18 数据手册
VBL165R18 www.VBsemi.com N-Channel 650 V (D-S) MOSFET PRODUCT SUMMARY FEATURES 650 VDS (V) at TJ max. RDS(on) max. () at 25 °C VGS = 10 V Qg max. (nC) • • • • • • 0.36 106 Qgs (nC) 14 Qgd (nC) 33 Single Configuration Reduced trr, Qrr, and IRRM Low figure-of-merit (FOM) Ron x Qg Low input capacitance (Ciss) Low switching losses due to reduced Qrr Ultra low gate charge (Qg) Avalanche energy rated (UIS) APPLICATIONS • Telecommunications - Server and telecom power supplies • Lighting - High-intensity discharge (HID) - Fluorescent ballast lighting • Consumer and computing - ATX power supplies • Industrial - Welding - Battery chargers • Renewable energy - Solar (PV inverters) • Switch mode power supplies (SMPS) D D2PAK (TO-263) G G D S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL LIMIT Drain-Source Voltage VDS 650 Gate-Source Voltage VGS ± 30 Continuous Drain Current (TJ = 150 °C) VGS at 10 V TC = 25 °C TC = 100 °C Pulsed Drain Current a ID UNIT V 18 16 A IDM 53 1.7 W/°C Single Pulse Avalanche Energy b EAS 367 mJ Maximum Power Dissipation PD 208 W TJ, Tstg -55 to +150 °C Linear Derating Factor Operating Junction and Storage Temperature Range Drain-Source Voltage Slope TJ = 125 °C Reverse Diode dV/dt d for 10 s Soldering Recommendations (Peak Temperature) c Notes a. Repetitive rating; pulse width limited by maximum junction temperature. b. VDD = 50 V, starting TJ = 25 °C, L = 28.2 mH, Rg = 25 , IAS = 5.1 A. c. 1.6 mm from case. d. ISD  ID, dI/dt = 100 A/μs, starting TJ = 25 °C. 服务热线:400-655-8788 dV/dt 37 31 300 V/ns °C 1 VBL165R18 www.VBsemi.com THERMAL RESISTANCE RATINGS SYMBOL TYP. MAX. Maximum Junction-to-Ambient PARAMETER RthJA - 62 Maximum Junction-to-Case (Drain) RthJC - 0.5 UNIT °C/W SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static Drain-Source Breakdown Voltage VDS Temperature Coefficient Gate-Source Threshold Voltage (N) VDS VGS = 0 V, ID = 250 μA 650 - - V VDS/TJ Reference to 25 °C, ID = 1 mA - 0.67 - V/°C VGS(th) VDS = VGS, ID = 250 μA 2 - 4 V VGS = ± 20 V - - ± 100 nA VGS = ± 30 V - - ±1 μA VDS = 650 V, VGS = 0 V - - 1 VDS = 520 V, VGS = 0 V, TJ = 125 °C - - 500 - Gate-Source Leakage IGSS Zero Gate Voltage Drain Current IDSS Drain-Source On-State Resistance Forward Transconductance μA  VDS = 30 V, ID = 11 A - 0.36 7.0 - gfs - S VGS = 0 V, VDS = 100 V, f = 1 MHz - 2322 - - 105 - - 4 - - 84 - - 293 - - 71 106 - 14 - RDS(on) VGS = 10 V ID = 11 A Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Effective Output Capacitance, Energy Related a Co(er) Effective Output Capacitance, Time Related b Co(tr) pF VDS = 0 V to 520 V, VGS = 0 V Total Gate Charge Qg Gate-Source Charge Qgs VGS = 10 V ID = 11 A, VDS = 520 V Gate-Drain Charge Qgd - 33 - Turn-On Delay Time td(on) - 22 44 Rise Time Turn-Off Delay Time tr td(off) Fall Time tf Gate Input Resistance Rg nC VDD = 520 V, ID = 11 A, VGS = 10 V, Rg = 9.1  - 34 68 - 68 102 - 42 84 f = 1 MHz, open drain - 0.78 - - - 21 - - 53 - 0.9 1.2 V - 160 - ns - 1.2 - μC - 14 - A ns  Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulsed Diode Forward Current ISM Diode Forward Voltage VSD Reverse Recovery Time trr Reverse Recovery Charge Qrr Reverse Recovery Current IRRM MOSFET symbol showing the  integral reverse p - n junction diode D A G S TJ = 25 °C, IS = 11 A, VGS = 0 V TJ = 25 °C, IF = IS = 11 A, dI/dt = 100 A/μs, VR = 25 V Notes a. Coss(er) is a fixed capacitance that gives the same energy as Coss while VDS is rising from 0 % to 80 % VDSS. b. Coss(tr) is a fixed capacitance that gives the same charging time as Coss while VDS is rising from 0 % to 80 % VDSS. 2 服务热线:400-655-8788 VBL165R18 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 50 40 TOP 15 V 14 V 13 V 12 V 11 V 10 V 9V 8V 7V 6V 5V 3 TJ = 25 °C ID = 11 A RDS(on), Drain-to-Source On Resistance (Normalized) ID, Drain-to-Source Current (A) 60 30 20 10 2.5 2 1.5 0.5 0 0 5 10 15 20 25 20 40 60 80 100 120 140 160 VDS, Drain-to-Source Voltage (V) TJ, Junction Temperature (°C) Fig. 1 - Typical Output Characteristics Fig. 4 - Normalized On-Resistance vs. Temperature 10 000 TOP 15 V 14 V 13 V 12 V 11 V 10 V 9V 8V 7V 6V 5V TJ = 150 °C Ciss ġ Capacitance (pF) ID, Drain-to-Source Current (A) 0 - 60 - 40 - 20 0 30 40 30 VGS = 10 V 1 20 1000 Coss 100 10 VGS = 0 V, f = 1 MHz Ciss = Cgs + Cgd, Cds Shorted Crss = Cgd Coss = Cds + Cgd ġ ġ Crss 10 0 ġ ġ 1 0 5 15 10 20 25 30 0 VDS, Drain-to-Source Voltage (V) 100 200 300 500 400 600 VDS, Drain-to-Source Voltage (V) Fig. 2 - Typical Output Characteristics Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage 14 5000 12 50 10 30 TJ = 150 °C Coss 8 Eoss 500 6 Eoss (μJ) 40 Coss (pF) ID, Drain-to-Source Current (A) 60 20 4 TJ = 25 °C 10 2 VDS = 29.6 V 0 0 5 10 15 20 25 VGS, Gate-to-Source Voltage (V) Fig. 3 - Typical Transfer Characteristics 服务热线:400-655-8788 50 0 0 100 200 300 VDS 400 500 600 Fig. 6 - Coss and Eoss vs. VDS 3 VBL165R18 www.VBsemi.com 25 VDS = 520 V VDS = 325 V VDS = 130 V 20 ID, Drain Current (A) VGS, Gate-to-Source Voltage (V) 24 16 12 8 4 0 20 15 10 5 0 30 0 90 60 120 150 25 Qg, Total Gate Charge (nC) 100 125 150 Fig. 10 - Maximum Drain Current vs. Case Temperature 850 100 ID = 10 mA 825 VDS, Drain-to-Source Breakdown Voltage (V) ISD, Reverse Drain Current (A) 75 TJ, Case Temperature (°C) Fig. 7 - Typical Gate Charge vs. Gate-to-Source Voltage TJ = 150 °C TJ = 25 °C 10 1 800 775 750 725 700 675 VGS = 0 V 0.1 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 VSD, Source-Drain Voltage (V) Fig. 8 - Typical Source-Drain Diode Forward Voltage 100 Fig. 11 - Temperature vs. Drain-to-Source Voltage 1 ms Operation in this Area Limited by RDS(on) 10 ms 0.1 TC = 25 °C TJ = 150 °C Single Pulse 0.01 1 20 40 60 80 100 120 140 160 TJ, Junction Temperature (°C) 100 μs Limited by RDS(on)* 1 650 - 60 - 40 - 20 0 IDM Limited 10 ID, Drain Current (A) 50 BVDSS Limited 10 100 1000 VDS, Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Fig. 9 - Maximum Safe Operating Area 4 服务热线:400-655-8788 VBL165R18 www.VBsemi.com Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 0.0001 0.001 0.01 0.1 1 Pulse Time (s) Fig. 12 - Normalized Thermal Transient Impedance, Junction-to-Case RD VDS VDS tp VGS VDD D.U.T. RG + - VDD VDS 10 V Pulse width ≤ 1 µs Duty factor ≤ 0.1 % IAS Fig. 13 - Switching Time Test Circuit Fig. 16 - Unclamped Inductive Waveforms VDS QG 10 V 90 % QGS 10 % VGS QGD VG td(on) td(off) tf tr Charge Fig. 17 - Basic Gate Charge Waveform Fig. 14 - Switching Time Waveforms Current regulator Same type as D.U.T. L Vary tp to obtain required IAS VDS 50 kΩ D.U.T RG 12 V + - IAS 0.2 µF 0.3 µF V DD + D.U.T. - VDS 10 V tp 0.01 Ω VGS 3 mA Fig. 15 - Unclamped Inductive Test Circuit IG ID Current sampling resistors Fig. 18 - Gate Charge Test Circuit 服务热线:400-655-8788 5 VBL165R18 www.VBsemi.com Peak Diode Recovery dV/dt Test Circuit + D.U.T. Circuit layout considerations • Low stray inductance • Ground plane • Low leakage inductance current transformer + - - Rg • • • • + dV/dt controlled by Rg Driver same type as D.U.T. ISD controlled by duty factor “D” D.U.T. - device under test + - VDD Driver gate drive P.W. Period D= P.W. Period VGS = 10 Va D.U.T. lSD waveform Reverse recovery current Body diode forward current dI/dt D.U.T. VDS waveform Diode recovery dV/dt Re-applied voltage Inductor current VDD Body diode forward drop Ripple ≤ 5 % ISD Note a. VGS = 5 V for logic level devices Fig. 19 - For N-Channel 6 服务热线:400-655-8788 VBL165R18 www.VBsemi.com RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead 0.420 0.635 (9.017) (16.129) 0.355 (10.668) 0.145 (3.683) 0.135 (3.429) 0.200 0.050 (5.080) (1.257) Recommended Minimum Pads Dimensions in Inches/(mm) 服务热线:400-655-8788 7 VBL165R18 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBL165R18 价格&库存
很抱歉,暂时无法提供与“VBL165R18”相匹配的价格&库存,您可以联系我们找货
