JANTX2N6287
JANTX2N6287
    MICROSEMICONDUCTOR(微半导体)
    TO-3
    TRANS PNP DARL 100V 20A TO-3
JANTX2N6287 数据手册
2N6286 & 2N6287 PNP Darlington Power Silicon Transistor Rev. V3 Features • Available in JAN, JANTX and JANTXV per MIL-PRF-19500/505 • TO-3 (TO-204AA) Package • Designed for General Purpose Amplifier and Low-Frequency Switching Applications Electrical Characteristics Parameter Test Conditions Symbol Units Min. Max. Collector - Emitter Breakdown Voltage IC = -100 mA dc 2N6286 2N6287 V(BR)CEO V dc -80 -100 — Collector - Emitter Cutoff Current VCE = -40 V dc, 2N6286 VCE = -50 V dc, 2N6287 ICEO mA dc — -1.0 Collector - Emitter Cutoff Current VCE = -80 V dc, VBE = +1.5 V dc, 2N6286 VCE = -100 V dc, VBE = +1.5 V dc, 2N6287 ICEX1 µA dc — -10 Emitter - Base Cutoff Current VEB = -7 V dc IEBO mA dc — -2.5 Forward Current Transfer Ratio VCE = -3 V dc; IC = -1 A dc VCE = -3 V dc; IC = -10 A dc VCE = -3 V dc; IC = -20 A dc hFE - 1,500 1,250 300 18,000 Collector - Emitter Saturation Voltage IC = -20 A dc; IB = -200 mA dc IC = -10 A dc; IB = -40 mA dc VCE(sat)1 V dc VCE(sat)2 — -3.0 -2.0 Base - Emitter Saturation Voltage IC = -20 A dc; IB = -200 mA dc VBE(sat) V dc — -4.0 Base - Emitter Voltage VCE = -3 V dc; IC = -10 A dc VBE V dc — -2.8 Collector - Emitter Cutoff Current TA = +150oC VCE = -80 V dc, VBE = +1.5 V dc, 2N6286 VCE = -100 V dc, VBE = +1.5 V dc, 2N6287 ICEX2 mA dc — -5.0 Collector - Emitter Saturation Voltage TA = +150oC IC = - 10 A dc; IB = -40 mA dc — -2.0 Forward Current Transfer Ratio TA = -55oC VCE = -3 V dc; IC = -10 A dc hFE4 - 150 Magnitude of Common - Emitter Small-Signal Short-Circuit Forward - Current Transfer Ratio VCE = -3 V dc; IC = -10 A dc; f = 1.0 MHz | hfe | - 8 80 Small-Signal Short-Circuit Forward - Current Transfer Ratio VCE = -3 V dc; IC = -10 A dc; f = 1.0 kHz hfe - 300 — Open Circuit Output Capacitance VCB = -10 V dc; IE = 0; 100 kHz ≤ f ≤ 1 MHz Cobo pF — 400 Turn-On Time VCC = -30 V dc; IC = -10 A dc; IB = -40 mA dc ton µs — 2.0 Turn-Off Time VCC = -30 V dc; IC = -10 A dc; IB1 = IB2 = -40 mA dc toff µs — 10 VCE(sat)3 V dc Dynamic Characteristics Switching Characteristics 1 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 11/4/2019 2N6286 & 2N6287 PNP Darlington Power Silicon Transistor Rev. V3 Absolute Maximum Ratings (TA = +25oC unless otherwise noted) Ratings Symbol 2N6286 2N6287 Units Collector - Emitter Voltage VCEO -80 -100 V dc Collector - Base Voltage VCBO -80 -100 V dc Emitter - Base Voltage VEBO -7 V dc Collector Current IC -20 A dc Base Current IB -0.5 A dc Total Power Dissipation @ TC = +25°C (1) @ TC = +100°C PT 175 87.5 W Operating & Storage Temperature Range TJ, TSTG -65 to +200 °C (1) Derate linearly @ 1.16 W/ °C above TC > +25°C. Thermal Characteristics Characteristics Symbol Max. Value Thermal Resistance, Junction to Case RθJC 0.855°C/W Safe Operating Area DC Tests: TC = +25 °C; t = 1.0 s; I Cycle Test 1: Test 2: Test 3: VCE = -8.75 V dc; IC = -20 A dc VCE = -30 V dc; IC = -5.8 A dc VCE = -80 Vdc; IC = -100 mA dc VCE = -100 Vdc; IC = -100 mA dc 2N6286 2N6287 2 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 11/4/2019 2N6286 & 2N6287 PNP Darlington Power Silicon Transistor Rev. V3 Outline Drawing (TO-3) 3 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 11/4/2019 2N6286 & 2N6287 PNP Darlington Power Silicon Transistor Rev. V3 Outline Drawing (TO-3) 4 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 11/4/2019 2N6286 & 2N6287 PNP Darlington Power Silicon Transistor Rev. V3 VPT COMPONENTS. ALL RIGHTS RESERVED. Information in this document is provided in connection with VPT Components products. These materials are provided by VPT Components as a service to its customers and may be used for informational purposes only. Except as provided in VPT Components Terms and Conditions of Sale for such products or in any separate agreement related to this document, VPT Components assumes no liability whatsoever. VPT Components assumes no responsibility for errors or omissions in these materials. VPT Components may make changes to specifications and product descriptions at any time, without notice. VPT Components makes no commitment to update the information and shall have no responsibility whatsoever for conflicts or incompatibilities arising from future changes to its specifications and product descriptions. No license, express or implied, by estoppels or otherwise, to any intellectual property rights is granted by this document. THESE MATERIALS ARE PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, RELATING TO SALE AND/OR USE OF VPT COMPONENTS PRODUCTS INCLUDING LIABILITY OR WARRANTIES RELATING TO FITNESS FOR A PARTICULAR PURPOSE, CONSEQUENTIAL OR INCIDENTAL DAMAGES, MERCHANTABILITY, OR INFRINGEMENT OF ANY PATENT, COPYRIGHT OR OTHER INTELLECTUAL PROPERTY RIGHT. VPT COMPONENTS FURTHER DOES NOT WARRANT THE ACCURACY OR COMPLETENESS OF THE INFORMATION, TEXT, GRAPHICS OR OTHER ITEMS CON-TAINED WITHIN THESE MATERIALS. VPT COMPONENTS SHALL NOT BE LIABLE FOR ANY SPECIAL, IN-DIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING WITHOUT LIMITATION, LOST REVE-NUES OR LOST PROFITS, WHICH MAY RESULT FROM THE USE OF THESE MATERIALS. VPT Components products are not intended for use in medical, lifesaving or life sustaining applications. VPT Components customers using or selling VPT Components products for use in such applications do so at their own risk and agree to fully indemnify VPT Components for any damages resulting from such improper use or sale. 5 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 11/4/2019
JANTX2N6287
物料型号:2N6286 和 2N6287 器件简介:PNP达林顿功率硅晶体管,适用于通用放大器和低频开关应用。
引脚分配:终端1是发射极,终端2是基极,集电极应电连接至外壳。
参数特性: - 集电极-发射极击穿电压:2N6286 -80Vdc,2N6287 -100Vdc - 集电极-发射极截止电流:2N6286 ≤-1.0mA,2N6287 ≤-1.0mA - 发射极-基极截止电流:≤-2.5mA - 直流电流增益:hFE 在不同条件下变化,最小值 150 - 集电极-发射极饱和电压:VCE(sat) 在不同条件下变化,最小值 -2.0V - 基极-发射极饱和电压:VBE(sat) ≤-4.0V - 基极-发射极电压:VBE ≤-2.8V - 集电极-发射极截止电流(TA=+150°C):2N6286 ≤-5.0mA,2N6287 ≤-5.0mA - 集电极-发射极饱和电压(TA=+150°C):VCE(sat)3 ≤-2.0V - 动态特性:共射小信号短路前向电流转换比(f=1.0MHz):hte 8-80 - 开路输出电容:Cabo ≤400pF - 存储温度范围:TJ, TSTG -65至+200°C 功能详解:文档中未提供详细的功能描述,但通常达林顿晶体管用于放大微弱信号或作为开关使用。
应用信息:适用于通用放大器和低频开关应用。
封装信息:TO-3(TO-204AA)封装,符合MIL-PRF-19500/505标准。
封装尺寸图和物理尺寸数据已提供。
JANTX2N6287 价格&库存
很抱歉,暂时无法提供与“JANTX2N6287”相匹配的价格&库存,您可以联系我们找货
