JANTX2N3055
JANTX2N3055
    MICROSEMICONDUCTOR(微半导体)
    TO-3
    TRANS NPN 70V 15A TO204AA
JANTX2N3055 数据手册
2N3055 NPN Power Silicon Transistor Rev. V4 Features • Available in JAN, JANTX, JANTXV per MIL-PRF-19500/407 • TO-3 (TO-204AA) Package • Designed for General Purpose Switching and Amplifier Applications Electrical Characteristics (TA = +25oC unless otherwise noted) Parameter Test Conditions Symbol Units Min. Max. Collector - Emitter Breakdown Voltage IC = 200 mA dc IC = 200 mA dc, RBE = 100 Ω VBE = -1.5 V dc, IC = 200 mA dc V(BR)CEO V(BR)CER V dc V(BR)CEX 70 80 90 — Collector - Emitter Cutoff Current VCE = 60 Vdc VBE = -1.5 V dc, VCE = 100 V dc ICEO ICEX1 mA dc — 1 1 Emitter - Base Cutoff Current VEB = 7.0 V dc IEBO mA dc — 1 Forward Current Transfer Ratio IC = 0.5 A dc, VCE = 4.0 V dc IC = 4.0 A dc, VCE = 4.0 V dc IC = 10.0 A dc, VCE = 4.0 V dc hFE - 40 20 5 — 60 — Collector - Emitter Saturation Voltage IC = 4.0 A dc, IB = 0.4 A dc IC = 10.0 A dc, IB = 3.3 A dc VCE(SAT) V dc — 0.75 2.0 Emitter - Base Saturation Voltage IC = 4.0 A dc, VCE = 4.0 V dc VBE(SAT) V dc — 1.4 8 40 Off Characteristics On Characteristics Dynamic Characteristics Magnitude of Common Emitter Small-Signal Short-Circuit Forward Current Transfer Ratio IC = 1 A dc, VCE= 4.0 Vdc, f = 100 kHz | hfe | Output Capacitance VCB = 10 Vdc, IE = 0, 100 kHz ≤ f ≤ 1 MHz Cobo pF — 700 Turn-On Time VCC = 30 Vdc; IC = 4.0 A dc; IB1 = 0.4 A dc ton µs — 6 Turn-Off Time IC = 4.0 A dc; IB1= -IB2= 0.4 A dc toff µs — 12 Switching Characteristics Safe Operating Area DC Tests: Test 1: Test 2: TC = +25 °C, I Cycle, t = 1.0 s VCE = 7.8 V dc, IC = 15 A dc VCE = 70.0 V dc, IC = 1.67 A dc 1 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 2N3055 NPN Power Silicon Transistor Rev. V4 Parameter Test Conditions Symbol Units Base Emitter Voltage (unsaturated) VCE = 4 V dc, IC = 4 A dc VBE V dc Collector - Emitter Cutoff Current TA = +150oC VCE = 100 Vdc VBE = -1.5 V dc ICEX2 mA dc Forward - Current Transfer Ratio TA = -55oC VCE = 4 V dc, IC = 4 A dc hFE4 Collector—Emitter Saturated Voltage IC = 10 A dc, IB = 3.3 A dc Min. VCE(sat)2 V dc Ratings Symbol Value Collector - Emitter Voltage VCEO 70 V dc Collector - Base Voltage VCBO 100 V dc Emitter - Base Voltage VEBO 7 V dc Base Current IB 7 V dc Total Power Dissipation @ TA = +25°C IC 15 A dc 1, 2 PT 6W 3 PT 117 W TJ, TSTG -65°C to +200°C Symbol Max. Value RθJC 1.5°C/W Total Power Dissipation @ TC = +25°C Operating & Storage Temperature Range Thermal Characteristics Characteristics Thermal Resistance, Junction to Case 1. 2. 3. 4. 4 TA = room ambient as defined in the general requirements of 4.5 of MIL-STD-750 Derate linearly @ 34.2 mW / °C for TA = 25 °C See figure 2 of MIL-PRF-19500/407 for temperature-power derating curves. See figure 3 for transient thermal impedance graph. 2 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 1.4 — 10 15 Absolute Maximum Ratings (TA = +25oC unless otherwise noted) Collector Current Max. 2 2N3055 NPN Power Silicon Transistor Rev. V4 Outline Drawing (TO-3) 3 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com 2N3055 NPN Power Silicon Transistor Rev. V4 VPT COMPONENTS. ALL RIGHTS RESERVED. Information in this document is provided in connection with VPT Components products. These materials are provided by VPT Components as a service to its customers and may be used for informational purposes only. Except as provided in VPT Components Terms and Conditions of Sale for such products or in any separate agreement related to this document, VPT Components assumes no liability whatsoever. VPT Components assumes no responsibility for errors or omissions in these materials. VPT Components may make changes to specifications and product descriptions at any time, without notice. VPT Components makes no commitment to update the information and shall have no responsibility whatsoever for conflicts or incompatibilities arising from future changes to its specifications and product descriptions. No license, express or implied, by estoppels or otherwise, to any intellectual property rights is granted by this document. THESE MATERIALS ARE PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, RELATING TO SALE AND/OR USE OF VPT COMPONENTS PRODUCTS INCLUDING LIABILITY OR WARRANTIES RELATING TO FITNESS FOR A PARTICULAR PURPOSE, CONSEQUENTIAL OR INCIDENTAL DAMAGES, MERCHANTABILITY, OR INFRINGEMENT OF ANY PATENT, COPYRIGHT OR OTHER INTELLECTUAL PROPERTY RIGHT. VPT COMPONENTS FURTHER DOES NOT WARRANT THE ACCURACY OR COMPLETENESS OF THE INFORMATION, TEXT, GRAPHICS OR OTHER ITEMS CON-TAINED WITHIN THESE MATERIALS. VPT COMPONENTS SHALL NOT BE LIABLE FOR ANY SPECIAL, IN-DIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING WITHOUT LIMITATION, LOST REVE-NUES OR LOST PROFITS, WHICH MAY RESULT FROM THE USE OF THESE MATERIALS. VPT Components products are not intended for use in medical, lifesaving or life sustaining applications. VPT Components customers using or selling VPT Components products for use in such applications do so at their own risk and agree to fully indemnify VPT Components for any damages resulting from such improper use or sale. 4 VPT Components and its affiliates reserve the right to make changes to the product(s) or information contained herein without notice. Visit www.vptcomponents.com for additional data sheets and product information. For further information and support please visit: info@vptcomponents.com
JANTX2N3055 价格&库存
很抱歉,暂时无法提供与“JANTX2N3055”相匹配的价格&库存,您可以联系我们找货
