RS0108S-U
RS0108S-U
    RICKY(浩瑞佳)
    TO92-3
RS0108S-U 数据手册
Shenzhen RICKY Electronic Technology Co.,Ltd RS0108 Series 1A TRIACs Rev:1.0 DESCRIPTION: With low holding and latching current, RS 0108 series triacs provide high dv/dt rate, and are 1 especially recommended for use on middle and 2 3 SOT-223 small resistance type powerload. 12 MAIN FEATURES Symbol Value Unit IT(RMS) 1 A ITSM 12 A VTM ≤1.5 V 1 3 2 3 SOT-89 TO-92 T1(1) T2(2) G(3) ABSOLUTE MAXIMUM RATINGS Parameter Symbol Value Unit Tstg -40 - 150 ℃ Tj -40 - 125 ℃ Repetitive peak off-state voltage (Tj=25℃) VDRM 600/800 V Repetitive peak reverse voltage (Tj=25℃) VRRM 600/800 V Non repetitive surge peak off-state voltage VDSM VDRM + 100 V Non repetitive peak reverse voltage VRSM VRRM + 100 V IT(RMS) 1 A Non repetitive surge peak on-state current (full cycle, F=50Hz) ITSM 12 A I2t value for fusing (tp=10ms) I 2t 0.72 A2s dI/dt 50 A/μs Storage junction temperature range Operating junction temperature range TO-92 (TC=51℃) RMS on-state current SOT-89/ SOT-223/ SOT-223-2L (TC=70℃) Critical rate of rise of on-state current (IG=2×I GT) TEL:+86-0755-89519740 -1/5- www.sika-wen.com RS0108 Series Shenzhen RICKY Electronic Technology Co.,Ltd Peak gate current Average gate power dissipation Peak gate power IGM 2 A PG(AV) 0.5 W PGM 5 W ELECTRICAL CHARACTERISTICS (Tj =25℃ unless otherwise specified) Symbol IGT Test Condition VD=12V RL=33Ω VGT VGD VD=VDRM Tj=125℃ RL=3.3KΩ Value Quadrant S Unit Ⅰ-Ⅱ-Ⅲ MAX 5 mA ALL MAX 1.3 V ALL MIN 0.2 V Ⅰ-Ⅲ IG=1.2IGT IH IT=200mA MAX 5 mA VD=2/3VDRM Gate Open Tj=125℃ MIN 100 V/μs Value(MAX) Unit Tj =25℃ 1.5 V Tj =25℃ 5 μA Tj =125℃ 500 μA Value Unit dV/dt Ⅱ MAX 5 IL mA 10 STATIC CHARACTERISTICS Symbol VTM IDRM IRRM Parameter ITM=1.4A tp=380μs VD=VDRM VR=VRRM THERMAL RESISTANCES Symbol Rth(j-c) Parameter junction to case(AC) TEL:+86-0755-89519740 TO-92 60 SOT-89/SOT-223/ SOT-223-2L 31 -2/5- ℃/W www.sika-wen.com RS0108 Series Shenzhen RICKY Electronic Technology Co.,Ltd ORDERING INFORMATION R S 01 08 S - U U:TO-92 W:SOT-223-2L V:SOT-223 E:SOT-89 SIKA CO.,LIMITED TRIAC SERIES S:IGT: 5mA 1 PACKAGE MECHANICAL DATA TEL:+86-0755-89519740 -3/5- www.sika-wen.com RS0108 Series Shenzhen RICKY Electronic Technology Co.,Ltd PACKAGE MECHANICAL DATA TEL:+86-0755-89519740 -4/5- www.sika-wen.com RS0108 Series Shenzhen RICKY Electronic Technology Co.,Ltd PACKAGE MECHANICAL DATA FIG.1: Maximum power dissipation versus RMS on-state current FIG.2: RMS on-state current versus case temperature IT(RMS) (A) 1.2 P(w) 1.6 α=180° TO-92 1.0 SOT-89 SOT-223/SOT-223-2L 1.2 0.8 0.6 0.8 0.4 0.4 0.2 0 0 IT(RMS) (A) 0.4 0.6 0.2 0.8 FIG.3: Surge peak on-state current versus number of cycles 15 C 0 0 1.0 25 T (℃) 50 75 100 125 FIG.4: On-state characteristics (maximum values) ITM (A) 20 ITSM (A) t=20ms 10 One cycle 12 9 Tj=Tjmax 1 6 Tj=25℃ 3 0 1 Number of cycles 100 10 0.1 0 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
RS0108S-U 价格&库存
很抱歉,暂时无法提供与“RS0108S-U”相匹配的价格&库存,您可以联系我们找货
