NSiP83086C-DSWTR
NSiP83086C-DSWTR
    NOVOSENSE(纳芯微)
    SOICW20
    直流转换器 SOICW20
NSiP83086C-DSWTR 数据手册
NSiP83086 Signal Isolated RS-485 Transceiver With Integrated DC to DC Converter Datasheet (EN) 1.0 Product Overview NSiP83086 series are high reliability isolated full duplex RS-485 transceiver with integrated DC to DC converter. The NSiP83086 isolated DC to DC converter uses on-chip transformer. The feedback PWM signal is sent to primary side(Isolator Side1) by a digital isolator based on Novosense capacity isolation technology. The NSiP83086 series are safety certified by UL1577 supporting 5kVrms insulation withstand voltage, while the high integrated solution can help to simplify system design and improve reliability. The Bus pins of NSiP83086 are protected from ±8kV system level ESD to GND2. The device features a fail-safe circuitry, which guarantees a logic-high receiver output when the receiver inputs are open or shorted. The device have 96k Ω input impedance that allows up to 256 transceivers on the bus. Key Features  Up to 5000Vrms Insulation voltage Safety Regulatory Approvals  UL recognition: up to 5000VRMS for 1 minute per UL1577  CQC certification per GB4943.1-2022  CSA component notice 5A  DIN VDE V 0884-11:2017-01 Applications  Industrial automation system  Isolated RS-485 communication  Smart electric meter and water meter  Security and protection monitoring Device Information Part Number NSiP83086(C)(V)-DSWTR Package SOW20 Body Size 12.80mm × 7.50mm NSiP83086(V)-DSWR SOW16 10.30mm x 7.50mm Note: (C), (V) could be empty representing 5V output version. V represents 3.3V output version, C version has SEL pin whichcanchoose3.3/5Voutput  ISO-Power integrated isolated DC-to-DC converter  I/O voltage range supports 1.8~5.5V MCU  Power supply voltage: Functional Block Diagrams VDD: 4.5V to 5.5V for NSiP83086 3V to 5.5V for NSiP83086C and NSiP83086V VDDL: 1.8V to 5.5V  Over current and over temperature protection  High CMTI: ±150kV/us  Data rate: 16Mbps  Up to 256 transceivers on the bus  High system level EMC performance: NSiP83086(V)-DSWTR NSiP83086C-DSWTR NSiP83086(V)-DSWR Figure 1. NSiP83086 Block Diagrams BUS Pins meet IEC61000-4-2 ±8kV ESD Other Pins meet IEC61000-4-2 ±7kV ESD  Operation temperature: -40℃~105℃  RoHS-compliant packages: SOW20 SOW16 Copyright © 2023, NOVOSENSE Page 1 NSiP83086 Datasheet (EN) 1.0 INDEX 1. PIN CONFIGURATION AND FUNCTIONS....................................................................................................................................... 3 2. ABSOLUTE MAXIMUM RATINGS.................................................................................................................................................... 7 3. RECOMMENDED OPERATING CONDITIONS................................................................................................................................. 7 4. THERMAL INFORMATION.............................................................................................................................................................. 7 5. SPECIFICATIONS........................................................................................................................................................................... 8 5.1. DC ELECTRICAL CHARACTERISTICS....................................................................................................................................... 8 5.2. NSIP83086 SWITCHING ELECTRICAL CHARACTERISTICS....................................................................................................10 5.3. TYPICAL PERFORMANCE CHARACTERISTICS.......................................................................................................................11 5.4. PARAMETER MEASUREMENT INFORMATION...................................................................................................................... 12 6. HIGH VOLTAGE FEATURE DESCRIPTION.....................................................................................................................................14 6.1. INSULATION AND SAFETY RELATED SPECIFICATIONS........................................................................................................ 14 6.2. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS............................................................... 14 6.3. REGULATORY INFORMATION............................................................................................................................................... 16 7. FUNCTION DESCRIPTION........................................................................................................................................................... 16 7.1. TRUE FAIL-SAFE RECEIVER INPUTS......................................................................................................................................16 7.2. TRUTH TABLES..................................................................................................................................................................... 17 7.3. EMI CONSIDERATIONS.........................................................................................................................................................17 7.4. OUTPUT SHORT AND OVER TEMPERATURE PROTECTION..................................................................................................17 8. APPLICATION NOTE.................................................................................................................................................................... 18 8.1. 256 TRANSCEIVERS ON THE BUS.........................................................................................................................................18 8.2. ESD PROTECTION.................................................................................................................................................................18 8.3. LAYOUT CONSIDERATIONS..................................................................................................................................................18 8.4. TYPICAL APPLICATION......................................................................................................................................................... 18 9. PACKAGE INFORMATION.............................................................................................................................................................20 10. ORDER INFORMATION.............................................................................................................................................................. 21 11. DOCUMENTATION SUPPORT.................................................................................................................................................... 21 12. TAPE AND REEL INFORMATION.................................................................................................................................................22 13. REVISION HISTORY.................................................................................................................................................................... 24 Copyright © 2023, NOVOSENSE Page 2 NSiP83086 Datasheet (EN) 1.0 1. Pin Configuration and Functions Figure 1.1 NSiP83086(V)-DSWTR Package Table1.1 NSiP83086(V)-DSWTR Pin Configuration and Description PIN NO. SYMBOL FUNCTION 1 GND1 Ground 1, the ground reference for Isolator Side 1 2 VDD1 Power Supply for Isolator Side 1 ,It is recommended this pin have a 0.1μF + 10 μF capacitor to GND1 (Pin1,Pin3 ) 3 GND1 Ground 1, the ground reference for Isolator Side 1 4 R Receiver output 5 /RE Receiver enable input, this is an active low input 6 DE Driver enable input, this is an active high input 7 D Driver transmit data input 8 VDDL I/O Power Supply input, Side1 I/O logic level 9 GND1 Ground 1, the ground reference for Isolator Side 1 10 GND1 Ground 1, the ground reference for Isolator Side 1 11 GND2 Ground 2, the ground reference for Isolator Side 2 12 VISOIN Isolated power supply input. This pin must be connected externally to VISOOUT. It is recommended this pin have a 0.1 μF capacitor to GND2 (Pin11). Connect this pin to VISOOUT through a ferrite bead and short trace length for operation. 13 Y Non-inverting Driver Output. When the driver is disabled, or when VDDL is powered down, Pin Y is put into a high impedance state to avoid overloading the bus. 14 GND2 Ground 2, the ground reference for Isolator Side 2 15 Z Inverting Driver Output. When the driver is disabled, or when VDD is powered down, Pin Z is put into a high impedance state to avoid overloading the bus. 16 GND2 Ground 2, the ground reference for Isolator Side 2 17 B Inverting Receiver Input Copyright © 2023, NOVOSENSE Page 3 NSiP83086 Datasheet (EN) 1.0 18 A Non-inverting Receiver Input 19 VISOOUT Isolated Power Supply Output. This pin must be connected externally to VISOIN. It is recommended this pin have a 0.1 μF and 10μF capacitor to GND2 (Pin20). Connect this pin through a ferrite bead and short trace length to VISOIN for operation. 20 GND2 Ground 2, the ground reference for Isolator Side 2 Figure 1.2 NSiP83086C-DSWTR Package Table1.2NSiP83086C-DSWTR Pin Configuration and Description PIN NO. SYMBOL FUNCTION 1 GND1 Ground 1, the ground reference for Isolator Side 1 2 VDD1 Power Supply for Isolator Side 1 ,It is recommended this pin have a 0.1μF + 10 μF capacitor to GND1 (Pin1,Pin3 ) 3 GND1 Ground 1, the ground reference for Isolator Side 1 4 R Receiver output 5 /RE Receiver enable input, this is an active low input 6 DE Driver enable input, this is an active high input 7 D Driver transmit data input 8 VDDL I/O Power Supply input, Side1 I/O logic level 9 GND1 Ground 1, the ground reference for Isolator Side 1 10 GND1 Ground 1, the ground reference for Isolator Side 1 11 SEL 12 VISOIN VISO output voltage select, VISOOUT =5V when SEL is floating or connect to VISOIN, VISOOUT =3.3V when SEL short to GND2 Isolated power supply input. This pin must be connected externally to VISOOUT. It is recommended this pin have a 0.1 μF capacitor to GND2 . Connect this pin to VISOOUT through a ferrite bead and short trace length for operation. 13 Y Non-inverting Driver Output. When the driver is disabled, or when VDDL is powered down, Pin Y is put into a high impedance state to avoid overloading the bus. 14 GND2 Ground 2, the ground reference for Isolator Side 2 Copyright © 2023, NOVOSENSE Page 4 NSiP83086 Datasheet (EN) 1.0 15 Z Inverting Driver Output. When the driver is disabled, or when VDD is powered down, Pin Z is put into a high impedance state to avoid overloading the bus. 16 GND2 Ground 2, the ground reference for Isolator Side 2 17 B Inverting Receiver Input 18 A Non-inverting Receiver Input 19 VISOOUT Isolated Power Supply Output. This pin must be connected externally to VISOIN. It is recommended this pin have a 0.1 μF and 10μF capacitor to GND2 (Pin20). Connect this pin through a ferrite bead and short trace length to VISOIN for operation. 20 GND2 Ground 2, the ground reference for Isolator Side 2 Figure 1.3 NSiP83086(V)-DSWR Package Table1.3NSiP83086(V)-DSWR Pin Configuration and Description PIN NO. SYMBOL FUNCTION 1 GND1 Ground 1, the ground reference for Isolator Side 1 2 VDD1 Power Supply for Isolator Side 1. It is recommended this pin have a 0.1 μF + 10 μF capacitor to GND1 (Pin1) 3 R Receiver output 4 /RE Receiver enable input, this is an active low input 5 DE Driver enable input, this is an active high input 6 D Driver transmit data input 7 VDDL I/O Power Supply input, Side1 I/O logic level 8 GND1 Ground 1, the ground reference for Isolator Side 1 9 GND2 Ground 2, the ground reference for Isolator Side 2 10 NC Not Connected Copyright © 2023, NOVOSENSE Page 5 NSiP83086 Datasheet (EN) 1.0 11 Y Non-inverting Driver Output. When the driver is disabled, or when VDD is powered down, Pin Y is put into a high impedance state to avoid overloading the bus. 12 Z Inverting Driver Output. When the driver is disabled, or when VDD is powered down, Pin Z is put into a high impedance state to avoid overloading the bus. 13 B Inverting Receiver Input 14 A Non-inverting Receiver Input 15 VISOOUT Isolated Power Supply Output. It is recommended this pin have a 0.1 μF and 10μF capacitor to GND2 (Pin16). 16 GND2 Ground 2, the ground reference for Isolator Side 2. Copyright © 2023, NOVOSENSE Page 6 NSiP83086 Datasheet (EN) 1.0 2. Absolute Maximum Ratings Parameters Symbol Min Typ Max Unit Power Supply Voltage VDD,VDDL -0.5 6 V Maximum Input Voltage /RE, DE, D -0.4 VDDL+0.4 V VA, VB, VY, VZ -7 12 V IO -15 15 mA Operating Temperature Topr -40 105 ℃ Storage Temperature Tstg -40 150 ℃ HBM ±8000 V CDM ±2000 V Driver Output/Receiver Input Voltage R output current Electrostatic discharge Comments 3. Recommended Operating Conditions Parameters Symbol Min Typ Max Unit NSiP83086 VDD 4.5 5 5.5 V VDD 3 3.3/5 5.5 V Topr -40 105 ℃ Side1 High Level Input Voltage VIH 0.7*VDDL VDDL V Side1 Low Level Input Voltage VIL 0 0.3*VDDL V Data rate DR Power Supply Voltage NSiP83086C and NSiP83086V Power Supply Voltage Operating Temperature 16 Mbps 4. Thermal Information Parameters Symbol SOW20 SOW16 Unit IC Junction-to-Air Thermal Resistance θJA 68.5 61 °C/W Junction-to-top characterization parameter ψJT 17.1 10.2 °C/W Junction-to-board characterization parameter ψJB 50.9 37.2 °C/W Copyright © 2023, NOVOSENSE Page 7 NSiP83086 Datasheet (EN) 1.0 5. Specifications 5.1. DC Electrical Characteristics (VDD=4.5V~5.5V, VDDL=1.8~5.5V, Ta=-40℃ to 105 ℃. Unless otherwise noted, Typical values are at VDD=VDDL=5V,VISOOUT=5V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Power supply voltage VDD1 4.5 5.5 V NSiP83086 VDDL 1.8 5.5 V Power supply voltage VDD1 3 5.5 V NSiP83086C/NSiP83086V VDDL 1.8 5.5 V Comments Supply current condition: VDD=4.5V~5.5V, VDDL=1.8~5.5V, Ta=-40℃ to 105℃. IDD 72 90 mA VDD=5V VDDL=3.3V RL=120Ω (500kbps) 118 140 mA VDD=5V VDDL=3.3V RL=54Ω IDD 100 130 mA VDD=5V VDDL=3.3V RL=120Ω (16Mbps) 130 160 mA VDD=5V VDDL=3.3V RL=54Ω 5 mA Supply current VISOOUT = 5V IDDL Supply current condition: VDD=3~5.5V, VDDL=1.8~5.5V, Ta=-40℃ to 105℃. Supply current VISOOUT = 3.3V IDD 40 55 mA VDD=5V VDDL=3.3V RL=120Ω (500kbps) 61 80 mA VDD=5V VDDL=3.3V RL=54Ω IDD 45 65 mA VDD=5V VDDL=3.3V RL=120Ω (16Mbps) 60 80 mA VDD=5V VDDL=3.3V RL=54Ω 5 mA IDDL Isolated supply voltage VISOOUT 5 V NSiP83086 VISOOUT 3.3/5 V NSiP83086C VISOOUT 3.3 V NSiP83086V Thermal-Shutdown Threshold TTS 165 ℃ Thermal-Shutdown Hysteresis TTSH 15 ℃ Common Immunity CMTI 100 150 kV/us Figure 5.12 Input High Voltage VIH 0.7*VDDL V DE, D, /RE Input Low Voltage VIL 0.3*VDDL V DE, D, /RE Input Current II 20 uA D, DE, /RE Mode Transient Side1 Copyright © 2023, NOVOSENSE -20 Page 8 NSiP83086 Datasheet (EN) 1.0 Output Voltage High VOH 0.8*VDDL V IOH = -4mA Output Voltage Low VOL 0.2*VDDL V IOL = 4mA Output Short-Circuit Current IOSR 150 mA 0 ≤ VR ≤VDDL Three-State Output Current IOZR 15 uA 0 ≤ VR ≤ VDDL , /RE = high Input Capacitance CIN pF DE, D, /RE 5.5 V No Load,VISOOUT=5V 2.7 5.5 V Figure 5.7,RL=120Ω VIsoout=5V 2.1 5.5 V Figure 5.7,RL=54Ω (RS-485) 2 Driver Differential Output Voltage | VOD | VIsoout=5V Change in magnitude of the Δ|VOD | 0.2 V differential output voltage Common-Mode Voltage VIsoout=5V Output Change in Magnitude of , RL=120Ω or RL=54Ω | VOC | 3 V , RL=120Ω or RL =54Ω VIsoout=5V Δ|VOC | 0.2 V Common-Mode Voltage Driver Short-Circuit Output Current Output Leakage Current (Y and Z) Full-Duplex , RL=120Ω or RL =54Ω VIsoout=5V IOSD IO 200 -200 200 -200 mA 0 ≤ VTest ≤ 12 V mA −7V ≤ VTest ≤ 0V uA DE=0V, VTest=12V uA DE=0V, VTest=-7V uA DE=0V, VISOIN=0V, VTest=12V uA DE=0V, VISOIN=0V, VTest=-7V mV VCM=0V mV VA+VB=0 kΩ −7V ≤ VCM ≤ 12V, DE=0V Receiver Input Current (A and B) Receiver Differential Threshold Voltage IA , IB VTH Receiver Input Hysteresis ΔVTH Receiver Input Resistance RIN Copyright © 2023, NOVOSENSE 200 -200 -200 -125 15 96 -10 Page 9 NSiP83086 Datasheet (EN) 1.0 5.2. Switching Electrical Characteristics (VDD=3V~5.5V,VDDL=1.8~5.5V, Ta=-40℃ to 105℃. Unless otherwise noted, Typical values are at VDD=VDDL = 5V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments Driver Maximum Data Rate fMAX Driver Propagation Delay tPLH Driver Pulse Width Distortion, 16 Mbps 22 60 ns See Figure 5.8,RL=54Ω, CL=50pF tPHL 21 60 ns See Figure 5.8,RL=54Ω, CL=50pF tskew 1 8 ns See Figure 5.8,RL=54Ω, CL=50pF tF 15 ns See Figure 5.8,RL=54Ω, CL=50pF tR 15 ns See Figure 5.8,RL=54Ω, CL=50pF |t PHL – t PLH | Driver Output Falling Time or Rising time Driver Enable to Output High tZH 22.8 50 ns See Figure 5.9,RL=120Ω, CL=50pF Driver Enable to Output Low tZL 19.1 50 ns See Figure 5.9,RL=120Ω, CL=50pF Driver Disable to Output High tHZ 28 50 ns See Figure 5.9,RL=120Ω, CL=50pF Driver Disable to Output Low tLZ 27.1 50 ns See Figure 5.9,RL=120Ω, CL=50pF Receiver Maximum Data Rate fMAX 16 Mbps Receiver Propagation Delay tPLH 65.8 140 ns See Figure 5.10,CL=15pF tPHL 71.4 140 ns See Figure 5.10, CL=15pF Receiver Pulse Width Distortion, |t PHL – t PLH | tskew 5.6 12 ns See Figure 5.10,CL=15pF Receiver Output Falling Time or Rising time tF 15 ns See Figure 5.10,CL=15pF tR 15 ns See Figure 5.10, CL=15pF Receiver Enable to Output High tZH 6 15 ns See Figure 5.11, RL=1kΩ,CL=15pF Receiver Enable to Output Low tZL 6 15 ns See Figure 5.11, RL=1kΩ,CL=15pF Receiver Disable to Output High tHZ 8 15 ns See Figure 5.11, Copyright © 2023, NOVOSENSE Page 10 NSiP83086 Datasheet (EN) 1.0 RL=1kΩ,CL=15pF Receiver Disable to Output Low tLZ 8 15 ns See Figure 5.11, RL=1kΩ,CL=15pF 5.3. Typical Performance Characteristics Figure 5.1 NSiP83086 supply current vs Temperature (Data Rate=16MHz,DE=VDDL,/RE=GND,VDD=5V,VISOOUT=3.3V) Figure 5.3 NSiP83086 supply current vs Temperature (Data Rate=16MHz,DE=VDDL,/RE=GND,VDD=5V,VISOOUT=5V) Copyright © 2023, NOVOSENSE Figure 5.2 NSiP83086 supply current vs Temperature (Data Rate=500KHz,DE=VDDL,/RE=GND,VDD=5,VISOOUT=3.3V) Figure 5.4 NSiP83086 supply current vs Temperature (Data Rate=500KHz,DE=VDDL,/RE=GND,VDD=5V,VISOOUT=5V) Page 11 NSiP83086 Datasheet (EN) 1.0 Figure 5.5 Driver Propagation Delay vs Temperature Figure 5.6 Receiver Propagation Delay vs Temperature 5.4. Parameter Measurement Information Figure 5.7 Driver DC Test Load Figure5.8 Driver Timing Test Circuit and waveform Copyright © 2023, NOVOSENSE Page 12 NSiP83086 Datasheet (EN) 1.0 Figure5.9 Driver Enable Disable Timing Test Circuit and waveform Figure 5.10 Receiver Propagation Delay Test Circuit and waveform Figure 5.11 Receiver Enable Disable Timing Test Circuit and waveform Figure5.12 Common-Mode Transient Immunity Test Circuit Copyright © 2023, NOVOSENSE Page 13 NSiP83086 Datasheet (EN) 1.0 6. High Voltage Feature Description 6.1. Insulation and Safety Related Specifications Parameters Symbol Value Unit Comments Minimum External Air Gap (Clearance) CLR 8.0 mm Shortest terminal-to-terminal distance through air Minimum External Tracking (Creepage) CPG 8.0 mm Shortest terminal-to-terminal distance across the package surface Distance through the insulation um Minimum internal gap (internal clearance – capacitive signal isolation) 100 um Minimum internal gap (internal clearance – transformer power isolation) >600 V 16 DTI Tracking Resistance (Comparative Tracking Index) CTI Material Group DIN EN 60112 (VDE 0303-11); IEC 60112 I 6.2. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS Description Test Condition Symbol Value Unit Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150Vrms Ⅰto Ⅳ For Rated Mains Voltage ≤ 600Vrms Ⅰto Ⅲ For Rated Mains Voltage ≤ 300Vrms Ⅰto Ⅳ Climatic Classification 40/105/21 Pollution Degree per DIN VDE 0110, Table 1 2 Maximum repetitive peak isolation voltage AC voltage(bipolar) VIORM 1166 Vpeak Maximum working isolation voltage AC voltage(TDDB) test VIOWM 824 Vrms DC Voltage VIOWM 1166 VDC V IORM × 1. 5 = V pd (m), 100%production test, Vpd (m) 1749 Vpeak Vpd (m) 1399 Vpeak Input to Output Test Voltage, Method B1 t ini = t m = 1 sec, partial discharge < 5 pC Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 Copyright © 2023, NOVOSENSE V IORM × 1.2 = V pd (m), t ini = 60 sec, t m = 10 sec, partial Page 14 NSiP83086 Datasheet (EN) 1.0 discharge < 5 pC After Input and /or Safety Test Subgroup 2 and Subgroup 3 V IORM × 1.2= V pd (m), t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC Vpd (m) 1399 Vpeak Maximum transient isolation voltage VTEST = VIOTM; t = 60 s (qualification); VIOTM 7000 Vpeak VIOSM 5384 Vpeak VTEST = 1.2 × VIOTM; t = 1 s (100% production) Maximum Surge Isolation Voltage Test method per IEC60065,1.2/50us waveform, VTEST = 1.3xVISOM Isolation resistance VIO =500V RIO >1012 Ω Isolation capacitance f = 1MHz CIO 0.6 pF PS 1459 mW Is 265 mA PS 1639 IS 298 mA Ts 125 ℃ Total Power Dissipation at 25℃ for SOW20 Package Safety input, output, or supply current for SOW20 Package θJA = 68.5°C/W, V I = 5.5 V, T J = 125 °C, TA = 25 °C Total Power Dissipation at 25℃ for SOW16 Package Safety input, output, or supply current for SOW16 Package Safety Temperature θJA = 61°C/W, V I = 5.5 V, T J = 125 °C, TA = 25 °C mW Figure 6.1NSiP83086 Thermal Derating Curve for SOW20 package, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Copyright © 2023, NOVOSENSE Page 15 NSiP83086 Datasheet (EN) 1.0 Figure 6.2NSiP83086 Thermal Derating Curve for SOW16 package, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 6.3. Regulatory Information The NSiP83086 are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program1 VDE CQC Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11(VDE V 0884-11):2017-012 Certified by CQC11471543-2012 Single Protection, 5000VRMS Isolation voltage Single Protection, 5000VRMSIsolation voltage Basic Insulation 1166Vpeak, VIOSM=5384VPEAK Basic insulation File (pending) File (pending) File (pending) File (pending) GB4943.1-2022 7. Function Description NSiP83086 is a high reliability isolated full duplex RS-485 transceiver. Data isolation is achieved using Novosense integrated capacitive isolation that allows data transmission between the logic side and the Bus side. The 83086 series are safety certified by UL1577 supporting 5kVRMS insulation withstand voltage. 7.1. True Fail-Safe Receiver Inputs The devices feature fail-safe circuitry, which guarantees a logic-high receiver output when the receiver inputs are open or shorted. The receiver threshold is fixed between -10mV and -200mV, which meets EIA/TIA-485 standard. If the differential input voltage (VAVB) is greater than or equal to -10mV, receiver output R is logic high. In the case of a terminated bus with all transmitters disabled, the differential input voltage is pulled to zero by the termination resistors. Due to the receiver threshold, the receiver output R is logic high. Copyright © 2023, NOVOSENSE Page 16 NSiP83086 Datasheet (EN) 1.0 7.2. Truth Tables Table 7.1 Driver Function Table VDD1 status Input Enable Input Outputs (D) (DE) Y Z PU H H H L PU L H L H PU X L Z Z PU X OPEN Z Z PU OPEN H H L PD X X Z Z Table 7.2 Receiver Function Table1 VDD status Differential Input Enable Input Output (VA-VB) (/RE) (R) L/Open H PU ≥-10mV L/Open L PU ≤-200mV Open/Short L/Open H PU X H Z PU Idle L H PD X X Z PU 1 PD= Powered down; PU= Powered up; H= Logic High; L= Logic Low; X= Irrelevant; Z= High Impedance; 7.3. EMI Considerations NSIP83086 use a small on-chip transformer to provide power for RS485 Transceiver. The on-chip transformer operates at high frequency, which may degrade EMI performance, to achieve better EMI performance, special considerations must be taken during PCB layout. Please see the application note if needed. 7.4. Output Short and Over Temperature Protection The NSiP83086 series are protected against output short for VISOOUT. When short on VISOOUT occurs, the device will be in Hiccup mode and the power transferred will be limit, which will limit the temperature of the device to protect the device. The NSiP83086 series also protected against over temperature. When the chip is over 165 ℃ , it will be shut down until the temperature of below 145℃. Copyright © 2023, NOVOSENSE Page 17 NSiP83086 Datasheet (EN) 1.0 8. Application Note 8.1. 256 Transceivers on the Bus The devices have a 1/8-unit-load receiver input impedance (96kΩ) that allows up to 256 transceivers on the bus. Connect any combination of these devices, and/or other RS-485 devices, for a maximum of 32 unit-loads to the line. 8.2. ESD Protection ESD protection structures are enhanced on all pins to protect against electrostatic discharge encountered during handing and assembly. The Bus pins have extra protection against static electricity to bus side (VISOOUT side). ESD protection can be tested in various ways. Below is the ESD spec of the devices. Bus pins:  ±8kV using the Contact Discharge method specified in IEC 61000-4-2 Other pins except bus pins:  ±7kV using the Contact Discharge method specified in IEC 61000-4-2 8.3. Layout Considerations The NSiP83086 requires a 10µF+0.1µF bypass capacitor between VDD1 and GND1, 10uF+0.1uF bypass capacitor between VISOOUT and GND2. The capacitor should be placed as close as possible to the package. To eliminate line reflections, each cable end (A-B, Y-Z) is terminated with a resistor, whose value matches the characteristic impedance of the cable(54Ω/120Ω). It’s good practice to place the bus connectors and termination resistor as close as possible to the A and B, Y and Z pins. 8.4. Typical Application Figure 8.1 NSiP83086 in Half-Duplex RS-485 Mode Copyright © 2023, NOVOSENSE Page 18 NSiP83086 Datasheet (EN) 1.0 Figure 8.2 NSiP83086 typical application circuit Figure 8.3 Typical isolated Full-Duplex RS-485 application Copyright © 2023, NOVOSENSE Page 19 NSiP83086 Datasheet (EN) 1.0 9. Package Information Figure 9.1 SOW20 Package Shape and Dimension in millimeters and inches Figure 9.2 SOW16 Package Shape and Dimension in millimeters Copyright © 2023, NOVOSENSE Page 20 NSiP83086 Datasheet (EN) 1.0 10. Ordering Information MSL Temperature No. of Nodes Package Type Package Drawing SPQ Full Max Data Rate (Mbps) 16 3 -40 to 105℃ 256 SOP20(300mil) SOW20 1000 5/3.3V Full 16 3 -40 to 105℃ 256 SOP20(300mil) SOW20 1000 5 3.3V Full 16 3 -40 to 105℃ 256 SOP20(300mil) SOW20 1000 5 5V Full 16 3 -40 to 105℃ 256 SOP16(300mil) SOW16 1000 5 3.3V Full 16 3 -40 to 105℃ 256 SOP16(300mil) SOW16 1000 Part Number Isolation Rating (kVRMS) VISOOUT Duplex NSiP83086DSWTR NSiP83086CDSWTR NSiP83086VDSWTR NSiP83086DSWR NSiP83086VDSWR 5 5V 5 NOTE: All packages are RoHS-compliant with peak reflow temperatures of 260 °C according to the JEDEC industry standard classifications and peak solder temperatures. 11. Documentation Support Part Number Product Folder Datasheet Application Note NSiP83086 tbd tbd tbd Copyright © 2023, NOVOSENSE Page 21 NSiP83086 Datasheet (EN) 1.0 12. Tape And Reel Information Figure 12.1 Tape and Reel Information of SOW20 Copyright © 2023, NOVOSENSE Page 22 NSiP83086 Datasheet (EN) 1.0 Figure 12.2 Tape and Reel Information of SOW16 Copyright © 2023, NOVOSENSE Page 23 NSiP83086 Datasheet (EN) 1.0 13. Revision History Revision 1.0 Description Initial Version Copyright © 2023, NOVOSENSE Date 2022/11/30 Page 24 NSiP83086 Datasheet (EN) 1.0 IMPORTANT NOTICE The information given in this document shall in no event be regarded as any warranty or authorization of, express or implied, including but not limited to accuracy, completeness, merchantability, fitness for a particular purpose or infringement of any third party’s intellectual property rights. You are solely responsible for your use of Novosense’ products and applications, and for the safety thereof. You shall comply with all laws, regulations and requirements related to Novosense’s products and applications, although information or support related to any application may still be provided by Novosense. The resources are intended only for skilled developers designing with Novosense’ products. Novosense reserves the rights to make corrections, modifications, enhancements, improvements or other changes to the products and services provided. Novosense authorizes you to use these resources exclusively for the development of relevant applications designed to integrate Novosense’s products. Using these resources for any other purpose, or any unauthorized reproduction or display of these resources is strictly prohibited. Novosense shall not be liable for any claims, damages, costs, losses or liabilities arising out of the use of these resources. For further information on applications, products and technologies, please contact Novosense (www.novosns.com ). Suzhou Novosense Microelectronics Co., Ltd Copyright © 2023, NOVOSENSE Page 25
NSiP83086C-DSWTR 价格&库存
很抱歉,暂时无法提供与“NSiP83086C-DSWTR”相匹配的价格&库存,您可以联系我们找货
NSiP83086C-DSWTR
  • 1+27.83200
  • 10+23.43180
  • 30+20.81520
库存:464
