KIRFR9024NTRTBF
P-Channel 60-V(D-S) Enhancement Mode Field Effect Transistor
V(BR)DSS
-60 V
RDS(on)MAX
200mΩ@ -10 V
ID
Equivalent Circuit:
-8.8A
General Description:
Third generation Power MOSFETs from Vishay provide
the designer with the best combination of fast switching,
ruggedized device design, low on-resistance and
cost-effectiveness.
The is designed for surface mounting using vapor
phase, infrared, or wave soldering techniques. The straight
lead version (IRFR series) is for through-hole
mounting applications. Power dissipation levels up to 1.5 W
are possible in typical surface mount applications.
FEATURE:
※ Surface Mount
※ Straight Lead
※ Available in Tape and Reel
※ Fast Switching
※ Repetitive Avalanche Rated
※ Simple Drive Requirements
※ Lead (Pb)-free Available.
※ Dynamic dV/dt Rating
※ Ultra Low On-Resistance
SYMBOL :
1/9
1.GATE
2.DRAIL
3.SOURCF
KIRFR9024NTRTBF
Maximum ratings ( Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source Voltage
VDS
-60
Gate-Source Voltage
VGS
±20
ID
-8.8
IDM
-35
Continuous Drain Current
Pulsed Diode Curren
Unit
V
A
Linear Derating Factor
0.33
W/°C
Linear Derating Factor (PCB Mount)
0.02
W/°C
PD
50
W
Thermal Resistance from Junction to Ambient (t≤10s)
RθJA
45
℃/W
Single Pulse Avalanche Energy
EAS
300
mJ
Repetitive Avalanche Current
I AR
-8.8
A
Repetitive Avalanche Energy
EAR
5.0
mJ
Peak Diode Recovery dV/dt
dV/dt
-4.5
V/ns
Maximum Junction-to-Ambient
RthJA
110
℃/W
TJ
150
TSTG
-55~+155
Power Dissipation
Operating Junction
Storage Temperature
Notes :
1.Repetitive rating; pulse width limited by maximum junction temperature
2.VDD = 25 V, starting TJ = 25 °C, L = 4.5 µH, RG = 25 Ω, IAS = -8.8 A
3.ISD ≤ -11 A, dI/dt ≤ 140 A/µs, VDD ≤ VDS, TJ ≤ 150 °C.
4.1.6 mm from case.
5.When mounted on 1" square PCB (FR-4 or G-10 material).
2/9
KIRFR9024NTRTBF
MOSFET ELECTRICAL CHARACTERISTICS
Static Electrical Characteristics (Ta = 25 ℃ Unless Otherwise Noted)
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
Static
Drain-source breakdown voltage V(BR)DSS VGS = 0V, ID = - 250µA
-60
VGS(th) VDS =VGS, ID = -250µA
-2
Gate-source threshold voltage
V
-4
V
Gate-source leakage
IGSS
VDS =0V, VGS = ±20V
±100
nA
Zero gate voltage drain current
IDSS
VDS = -60V, VGS =0V
-100
µA
200
mΩ
Drain-source on-state resistancea
RDS(on) VGS = -10V, ID = -5.3A
Forward transconductancea
gfs
VDS = -25V, ID = -5.3A
Diode forward voltage
VSD
IS= -7.2A, VGS=0V
75
2.9
S
-1.8
V
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitanceb
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Gate resistance
Rg
VDS = -25V, VGS =0V,
f=1MHz
570
pF
360
pF
65
pF
VDS = -48V, VGS = 10V,
ID = -11A
19
nC
5.4
nC
11
nC
f=1MHz
Ω
Switchingb
Turn-on delay time
td(on)
tr
Rise time
Turn-off delay time
td(off)
VDD= -30V
RD=3Ω, ID = -11A,
VGEN= -10V,Rg= 18Ω
tf
Fall time
Internal Drain Inductance
LD
Internal Source Inductance
LS
Between lead,
6 mm (0.25") from
package and center of
die contact
13
ns
68
ns
15
ns
29
ns
4.5
nH
7.5
nH
Drain-Source Diode Characteristics
Reverse Recovery Time
trr
IF= -11A, dl/dt=100A/s
100
200
ns
Reverse Recovery Charde
Qrr
0.32
0.64
µC
-8.8
A
-35
A
Continuous Source-Drain Diode Current
Pulsed Diode Forward Current
IS
ISM
MOSFET symbol
showing the
integral reverse
p - n junction diode
3/9
KIRFR9024NTRTBF
TYPICAL CHARACTERISTICS :
4/9
KIRFR9024NTRTBF
5/9
KIRFR9024NTRTBF
6/9
KIRFR9024NTRTBF
7/9
KIRFR9024NTRTBF
8/9
KIRFR9024NTRTBF
PACKAGE OUTLINE DIMENSIONS :
9/9
很抱歉,暂时无法提供与“KIRFR9024NTRTBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.12512
- 50+1.69290
- 150+1.50768
- 500+1.27656
- 2500+1.06089
- 5000+0.99911
