A4~A7
1A, 400V - 1000V Surface Mount Rectifier
FEATURES
● Glass passivated junction chip
SOD-123F L
● Ideal for automated placement
● Low forward voltage drop
● High surge current capability
● Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
MECHANICAL DATA
● Case: SOD-123FL
● Molding compound meets UL 94 V-0 flammability rating
● Moisture sensitivity level: level 1, per J-STD-020
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Meet JESD 201 class 1A whisker test
● Polarity: As marked
● Weight: 16 mg (approximately)
T
VWXYZ[\
U
]^Z[\
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SYMBOL
A4
A5
A7
UNIT
Repetitive peak reverse voltage
VRRM
400
600
1000
V
Reverse voltage, total rms value
VRMS
280
420
700
V
Maximum DC blocking voltage
VDC
400
600
1000
Forward current
Surge peak forward current, 8.3 ms single half sinewave superimposed on rated load per diode
IF(AV)
1
A
IFSM
30
A
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
PARAMETER
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction to Lead Thermal Resistance
RӨJL
25
°C/W
Junction to Ambient Thermal Resistance
RӨJA
85
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR per diode
Junction capacitance
IF = 1A, TJ = 25°C
(2)
TJ = 25°C
TJ = 125°C
1 MHz, VR=4V
SYMBOL
TYP
MAX
UNIT
VF
1.1
V
1
µA
50
µA
7
pF
IR
CJ
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
0571-87006810
www.dowosemi.cn
1/2
A4~A7
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1
16
14
0.8
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
1.2
0.6
0.4
0.2
12
10
Resistive or
inductive load
8
6
4
2
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
150
0.1
1
LEAD TEMPERATURE (°C)
TJ=125°C
1
0.1
TJ=25°C
0.01
40
60
80
10010
Pulse width=300μs
1% duty cycle
10
TJ=125°C
TJ=25°C
0.1
1
0.01
S1JFL
Pulse width
0.001
0.3
0.1
UF1DLW
1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
10
0.4
0.2
0.4
0.5
0.6
0.6
0.8
0.7
1
0.8
1.2
0.9
1.4
1
1.6
1.1
1.8
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
30
8.3ms single half sine wave
25
10
5
10
100
NUMBER OF CYCLES AT 60 Hz
0571-87006810
www.dowosemi.cn
2/2
1.2
2
很抱歉,暂时无法提供与“A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.04979
- 1000+0.03899
- 3000+0.03230
- 9000+0.02862
- 42000+0.02560
- 105000+0.02387
- 国内价格
- 1+0.12980
- 200+0.04290
- 1500+0.02684
- 3000+0.02123
