SODS1M
SODS1M
    DOESHARE(德芯)
    SMF(SOD-123FL)
SODS1M 数据手册
SODS1A THRU SODS1M SODS1A THRU SODS1M 1.0Amp Standard Surface Mounted Rectifiers General description 1.0Amp Standard Surface Mounted Rectifiers FEATURES • For surface mounted applications • The plastic package carries Underwriters Laboratory • • • • • • Flammability Classification 94V-0 Idea for printed circuit board Glass passivated Junction chip Low reverse leakage High forward surge current capability High temperature soldering guaranteed 250 C/10 seconds at terminals MECHANICAL DATA • Case: Molded plastic body • Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 • Polarity: Polarity symbol marking on body • Mounting Position: Any • Weight: 0.0007 ounce, 0.02 grams Absolute Maximum Ratings(Ta=25℃ unless otherwise specified) Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter SYMBOLS SOD S1A SOD S1B SOD S1D SOD S1G SOD S1J SOD S1J SOD S1M UNITS Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current at TL=100℃ I(AV) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM Maximum instantaneous forward voltage at 1.0A VF Maximum DC reverse current T A =25℃ at rated DC blocking voltage TA=125℃ Typical junction capacitance (Note2) Typical thermal resistance A 35 A 1.1 V IR 5.0 500 uA CJ 18.0 pF RqJA 85.0 C/W -55 to +150 C Operating junction and storage temperature TJ,TSTG range NOTES: 1. Measured at 1 MHz and applied Vr = 4.0 volts www.doeshare.net 1.0 SODS1A THRU SODS1M Ratings And Characteristic Curves Suggested Soldering Temperature Profile www.doeshare.net SODS1A THRU SODS1M Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
SODS1M 价格&库存
很抱歉,暂时无法提供与“SODS1M”相匹配的价格&库存,您可以联系我们找货
