SL80N03
N-Channel Enhancement Mode Field Effect Transistor
Product Summary
● VDS
● ID
● RDS(ON)( at VGS= 10V)
● RDS(ON)( at VGS= 5V)
30V
80A
<6.5mohm
<10mohm
Features
● High density cell design for ultra low Rdson
● Fully characterized avalanche voltage and current
● Good stability and uniformity with high EAS
● Excellent package for good heat dissipation
Application
● Power switching application
● Hard switched and high frequency circuits
● Uninterruptible power supply
■ Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Limit
Drain-source Voltage
VDS
30
V
Gate-source Voltage
VGS
±20
V
Drain Current
ID
80
A
Pulsed Drain Current A
IDM
170
A
Single Pulse Avalanche Energy B
EAS
306
mJ
Total Power Dissipation
PD
83
W
RθJC
1.74
℃/ W
TJ ,TSTG
-55~+150
Thermal Resistance Junction-to-Case
Junction and Storage Temperature Range
www.slkormicro.com
1
Unit
SL80N03
■ Electrical Characteristics (TJ=25℃ unless otherwise noted)
Parameter
Symbol
Conditions
Min
Typ
Max
Units
Static Parameter
30
Drain-Source Breakdown Voltage
BVDSS
VGS= 0V, ID=250μA
Zero Gate Voltage Drain Current
IDSS
VDS=30V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS= ±20V, VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS= VGS, ID=250μA
1.6
2.5
V
VGS= 10V, ID=30A
4.5
6.5
Static Drain-Source On-Resistance
RDS(ON)
VGS= 5V, ID=24A
6.8
10
Diode Forward Voltage
Maximum Body-Diode Continuous Current
1.0
V
mΩ
IS=24A,VGS=0V
VSD
IS
1.3
V
80
A
Dynamic Parameters
2015
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
230
Total Gate Charge
Qg
61
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Reverse Recovery Charge
Qrr
VDS=15V,VGS=0V,f=1MHZ
250
pF
Switching Parameters
VGS=10V,VDS=10V,ID=30A
8.2
nC
7.8
32
IF=80A, di/dt=100A/us
trr
12
Turn-on Delay Time
tD(on)
Turn-on Rise Time
tr
Turn-off Delay Time
tD(off)
60
tf
10
Reverse Recovery Time
Turn-off fall Time
A.
B.
VGS=10V,VDD=10V,RG=2.7Ω ,
ID =30A
Pulse Test: Pulse Width≤300us,Duty cycle ≤2%.
EAS condition:Tj=25℃,VDD=15V,VG=10V,L=0.5mH,Rg=25Ω,IAS=35A
www.slkormicro.com
2
15
ns
SL80N03
ID- Drain Current (A)
Normalized On-Resistance
■ Typical Performance Characteristics
TJ-Junction Temperature(℃)
Vds Drain-Source Voltage (V)
Figure 2 Rdson-JunctionTemperature
Vgs Gate-Source Voltage (V)
Figure 1 Output Characteristics
Qg Gate Charge (nC)
Figure 3 Transfer Characteristics
Figure 4 Gate Charge
Is- Reverse Drain Current (A)
Rdson On-Resistance Normalized
Vsd Source-Drain Voltage (V)
Figure 5 Rdson- Drain Current
www.slkormicro.com
Figure 6 Source- Drain Diode Forward
3
Normalized BVdss
C Capacitance (pF)
SL80N03
Figure 7 Capacitance vs Vds
Figure 8 BVDSS vs Junction Temperature
Figure 9 Safe Operation Area
Figure 10 VGS(th) vs Junction Temperature
www.slkormicro.com
4
SL80N03
■ TO-252 Package information
www.slkormicro.com
5
很抱歉,暂时无法提供与“SL80N03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.41783
- 50+1.13476
- 150+1.01348
- 500+0.86206
- 2500+0.79467
- 5000+0.75428
