NJU77251F-TE1
NJU77251F-TE1
    NISSHINBO(日清纺)
    SC-74A(SOT-753)
    HIGH-SPEED, RAIL-TO-RAIL INPUT,
NJU77251F-TE1 数据手册
Datasheet PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE NJU7725x / NJU7726x High-Speed, Rail-to-Rail Input, CMOS Comparator FEATURES DESCRIPTION (V+ = 5V, Typical value, Ta = 25°C)  Propagation Delay (TPLH / TPHL) - NJU7725x 42ns / 35ns - NJU7726x 125ns / 32ns  Rail-to-Rail Common-Mode Input Voltage Range 0.2V beyond Supply Rails  Dynamic Transient Stabilizer TM - Rail-to-Rail Input with less propagation delay fluctuation  Push-Pull Output (NJU7725x)  Open-Drain Output (NJU7726x)  Output Drive Current -Sink (VO = 1V) 40mA -Source (VO = 4V, NJU7725x) 37mA  Supply Current 140μA/ch  Supply Voltage 2.7V to 5.5V  Operating Temperature -40°C to 125°C  Lead-less Small Package DFN6-G1 (ESON6-G1) (1.6 x 1.6 mm) DFN8-U1 (ESON8-U1) (2.0 x 2.0 mm)  Standard Small Package SOT-23-5, SC-88A MSOP8 (VSP8) The NJU7725x, NJU7726x series are Rail-to-Rail Input CMOS comparators featuring High-Speed. These comparators operate from 2.7V to 5.5V and low supply current of 140μA/ch. typ. This feature is suitable for battery powered application. NJU7725x, NJU7726x series features the newly developed circuit technology Dynamic Transient Stabilizer TM realizes full swing input with suppressed fluctuation of propagation delay time. In addition, the common mode input voltage range that exceeds the power supply voltage range is specified, and voltage detection near the power supply voltage is supported. NJU7725x, NJU7726x series are available in ultrasmall, leadless package measuring 1.6 mm x 1.6 mm (DFN6-G1) and 2.0 mm x 2.0 mm (DFN8-U1), and industrial standard leaded packages SOT-23-5, SC-88A, and MSOP8 (VSP8). Dynamic Transient Stabilizer TM It is a circuit technology that suppresses fluctuations in propagation delay time even if the reference voltage for voltage detection fluctuates. APPLICATIONS  Protection circuit for overvoltage detection, overcurrent detection, overheat detection, etc.  Window comparators  LED drivers  Relay drivers  Electronic and electrical equipment in general  Voltage Level Translators Rail-to-Rail Input with no propagation delay fluctuation V+ V+ = 5V, V− = 0V, CL = 15pF, Ta = 25°C 300 VO VO VREF VOH Propagation Delay [ns] 250 R1 200 VIN Rise (NJU7726x) R2 VOL VTHL VTLH VIN 150 100 Rise (NJU7725x) Fall 50 0 0 Ver.0.3 1 2 3 4 Common-Mode Input Voltage [V] 5 Noninverting Comparator with Hysteresis -1- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ PRODUCT NAME INFORMATION NJU772XX a (bbb) Description of configuration Suffix a bbb Item Package code Packing Description Indicates the package. Refer to the order information. Refer to the packing specifications. ■ ORDER INFORMATION Product Name (Insert direction) NJU77250F (TE1) NJU77250F3 (TE1) NJU77251F (TE1) NJU77251F3 (TE1) NJU77251KG1 (TE3) NJU77260F (TE1) NJU77260F3 (TE1) NJU77261F (TE1) NJU77261F3 (TE1) NJU77261KG1 (TE3) NJU77252R (TE1) NJU77252KU1 (TE3) NJU77262R (TE1) NJU77262KU1 (TE3) Ver.0.3 Package RoHS HalogenFree Terminal Finish Marking Weight (mg) MOQ (pcs) SOT-23-5 SC-88A SOT-23-5 SC-88A DFN6-G1 (ESON6-G1) SOT-23-5 SC-88A SOT-23-5 SC-88A DFN6-G1 (ESON6-G1) MSOP8 (VSP8) DFN8-U1 (ESON8-U1) MSOP8 (VSP8) DFN8-U1 (ESON8-U1) Yes Yes Yes Yes Yes Yes Yes Yes Sn2Bi Sn2Bi Sn2Bi Sn2Bi 1S F5 1U F6 15 7.5 15 7.5 3000 3000 3000 3000 Yes Yes Sn2Bi 77251 3.5 3000 Yes Yes Yes Yes Yes Yes Yes Yes Sn2Bi Sn2Bi Sn2Bi Sn2Bi 1V F7 1W F8 15 7.5 15 7.5 3000 3000 3000 3000 Yes Yes Sn2Bi 77261 3.5 3000 Yes Yes Sn2Bi 77252 21 2000 Yes Yes Sn2Bi 77252 5.3 3000 Yes Yes Sn2Bi 77262 21 2000 Yes Yes Sn2Bi 77262 5.3 3000 -2- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ PIN DESCRIPTIONS Product Name NJU77250F NJU77260F NJU77250F3 NJU77260F3 NJU77251F NJU77261F NJU77251F3 NJU77261F3 NJU77251KG1 NJU77261KG1 Package SOT-23-5 SC-88A SOT-23-5 SC-88A DFN6-G1 (ESON6-G1) (Top View) OUTPUT Pin Functions 1 V- 2 +INPUT 3 (Top View) (Top View) 5 4 V+ +INPUT -INPUT 1 V- 2 -INPUT 3 5 4 V+ V+ OUTPUT 1 N.C. 2 OUTPUT 3 Exposed Pad on Underside 8 +INPUT 7 V- 6 -INPUT *Connect to exposed pad to V− Product Name NJU77252R NJU77252KU1 Package MSOP8 (VSP8) DFN8-U1 (ESON8-U1) (Top View) (Top View) Pin Functions A OUTPUT 1 8 V+ A -INPUT 2 7 B OUTPUT A OUTPUT 1 A -INPUT 2 A +INPUT 3 6 B -INPUT A +INPUT 3 V- 4 5 B +INPUT V- 4 Exposed Pad on Underside 8 V+ 7 B OUTPUT 6 B -INPUT 5 B +INPUT *Connect to exposed pad to V− Product Name NJU77262R NJU77262KU1(U.D.) Package MSOP8 (VSP8) DFN8-U1 (ESON8-U1) (Top View) (Top View) Pin Functions A OUTPUT 1 8 V+ A -INPUT 2 7 B OUTPUT A OUTPUT 1 A -INPUT 2 A +INPUT 3 6 B -INPUT A +INPUT 3 V- 4 5 B +INPUT V- 4 Exposed Pad on Underside 8 V+ 7 B OUTPUT 6 B -INPUT 5 B +INPUT *Connect to exposed pad to V− ■ BLOCK DIAGRAM V+ V+ -INPUT OUTPUT +INPUT -INPUT OUTPUT +INPUT V- Open-Drain Output Ver.0.3 V- Push-Pull Output -3- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ ABSOLUTE MAXIMUM RATINGS Parameter Symbol V+ Supply Voltage Input Voltage (*1) Input Current (*1) Differential Input Voltage (*2) − V− Unit 7 V VIN V− − 0.3 to V+ + 0.3 V IIN ±10 mA VID Output Terminal Input Voltage (*3) Rating ±7 V− VO − 0.3 to V+ V + 0.3*3 V− − 0.3 to V- + 7*4 Power Dissipation (Ta = 25°C) V 2-Layer / 4-Layer D 480*5 / 650*5 360*5 / 490*5 330*6 / 1200*6 500*5 / 660*5 450*6 / 1200 *6 mW Storage Temperature Tstg -65 to 150 °C Junction Temperature Tj 150 °C SOT-23-5 SC-88A DFN6-G1 (ESON6-G1) MSOP8 (VSP8) DFN8-U1 (ESON8-U1) P *1 Input voltages outside the supply voltage will be clamped by ESD protection diodes. If the input voltage exceeds the supply voltage, the current must be limited 10 mA or less by using a restriction resistance. Input current inflow is positive and Input current outflow is negative. The input voltage is limited at 7V. *2 Differential voltage is the voltage difference between +INPUT and −INPUT. The absolute maximum input voltage is limited at 7V. *3 Rating of NJU7725X series. The output terminal input voltage is limited at 7V. *4 Rating of NJU7726X series. The output terminal input voltage is limited at 7V. *5 2-Layer: Mounted on glass epoxy board (76.2 mm × 114.3 mm × 1.6 mm: based on EIA/JEDEC standard, 2-layer FR-4). 4-Layer: Mounted on glass epoxy board (76.2 mm × 114.3 mm × 1.6 mm: based on EIA/JEDEC standard, 4-layer FR-4), internal Cu area: 74.2 mm × 74.2 mm. *6 2-Layer: Mounted on glass epoxy board (101.5 mm × 114.5 mm × 1.6 mm: based on EIA/JEDEC standard, 2-layer FR-4) with exposed pad. 4-Layer: Mounted on glass epoxy board (101.5 mm × 114.5 mm × 1.6 mm: based on EIA/JEDEC standard, 4-layer FR-4) with exposed pad. (For 4-layer: Applying 99.5 mm × 99.5 mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5.) ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the lifetime and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. ■ THERMAL CHARACTERISTICS Package Measurement Result Thermal Resistance (Θja) Thermal Characterization Parameter (ψjt) 260*7/192*7 347*7/255*7 379*8/104 *8 250*7/189*7 278*8/104*8 67*7 / 58*7 91*7 / 73*7 64*8 / 26*8 62*7 / 53*7 42*8 / 25*8 SOT-23-5 SC-88A DFN6-G1 (ESON6-G1) MSOP8 (VSP8) DFN8-U1 (ESON8-U1) Unit °C/W Θja :Junction-to-Ambient Thermal Resistance ψjt:Junction-to-Top Thermal Characterization Parameter *7 2-Layer: Mounted on glass epoxy board (76.2 mm × 114.3 mm × 1.6 mm: based on EIA/JEDEC standard, 2-layer FR-4). 4-Layer: Mounted on glass epoxy board (76.2 mm × 114.3 mm × 1.6 mm: based on EIA/JEDEC standard, 4-layer FR-4), internal Cu area: 74.2 mm × 74.2 mm. *8 2-Layer: Mounted on glass epoxy board (101.5 mm × 114.5 mm × 1.6 mm: based on EIA/JEDEC standard, 2-layer FR-4) with exposed pad. 4-Layer: Mounted on glass epoxy board (101.5 mm × 114.5 mm × 1.6 mm: based on EIA/JEDEC standard, 4-layer FR-4) with exposed pad. (For 4-layer: Applying 99.5 mm × 99.5 mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5.) Ver.0.3 -4- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ ELECTROSTATIC DISCHARGE (ESD) PROTECTION VOLTAGE Parameter Conditions Protection Voltage HBM C = 100 pF, R = 1.5 kΩ ±1000 V CDM Direct CDM ±1000 V ELECTROSTATIC DISCHARGE RATINGS The electrostatic discharge test is done based on JEITA ED-4701. In the HBM method, ESD is applied using the power supply pin and GND pin as reference pins. ■ RECOMMENDED OPERATING CONDITIONS Parameter Supply Voltage Symbol Conditions V+ − V− Input Voltage VIN Output Terminal Input Voltage VO Operating Temperature Topr Rating Unit 2.7 to 5.5 − 0.2 to V+ + 0.2 (MAX 5.5) V− − 0.2 to V− + 5.5 V -40 to 125 °C V− NJU7726x V V RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. Ver.0.3 -5- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ ELECTRICAL CHARACTERISTICS V+ = 5V, V− = 0V, RL = Open , Ta = 25°C, unless otherwise specified. Parameter Symbol Test Conditions Min Typ Max Unit VCOM = -0.2V - 1 7 mV VCOM = 5.2V INPUT CHARACTERISTICS*1 Input Offset Voltage VIO - 1 9 mV Input Bias Current IB - 1 - pA Input Offset Current Common-Mode Input Voltage Range Common-Mode Rejection Ratio OUTPUT CHARACTERISTICS IIO - 1 - pA -0.2 - 5.2 V High-level Output Voltage VICM CMR ≥ 55dB CMR VICM = -0.2V to 5.2V 55 70 - dB VOH ISOURCE = 4mA 4.8 4.9 - V VOL ISINK = 4mA - 0.1 0.2 V ILEAK VO = 5V - 1 700 nA ISC ISOURCE, VO = 0V - 85 - mA ISC ISINK, VO = 5V - 65 - mA VCOM = -0.2V - 140 210 μA VCOM = 5.2V - 200 300 μA 60 85 - dB tPLH - 42 - ns tPHL - 35 - ns tTLH - 4.0 - ns tTHL - 3.5 - ns tPLH - 125 - ns tPHL - 32 - ns tTLH - 250 - ns tTHL - 2 - ns (NJU7725x) Low-level Output Voltage Output Leakage Current (NJU7726x) Output Short-Circuit Current (NJU7725x) Output Short-Circuit Current POWER SUPPLY Supply Current per Comparator Supply Voltage Rejection Ratio ISUPPLY SVR V+ = 2.7V to 5.5V Transient Response (RL = 5.1kΩ、CL = 15pF, Overdrive = 100mV) (NJU7725x) Propagation Delay (Low to High) Propagation Delay (High to Low) Rise Time Fall Time (NJU7726x) Propagation Delay (Low to High) Propagation Delay (High to Low) Rise Time Fall Time *1 Input offset voltage and drift, Input bias and offset current are positive or negative, its absolute values are listed in electrical characteristics. Ver.0.3 -6- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ APPLICATION NOTE Single and Dual Supply Voltage Operation Single and Dual Supply Voltage Operation The NJU7725x, NJU7726x series works with both single supply and dual supply when the voltage supplied is between V+ and V−. These comparators operate from single 2.7V to 5.5V supply and dual ±1.35V to ±2.75V supply. The power supply pin should have bypass capacitor (i.e. 0.1µF). Dynamic Transient Stabilizer TM The NJU7725x and NJU7726x series use the new circuit technology Dynamic Transient Stabilizer TM to realize a rail-to-rail input that suppresses fluctuations in propagation delay. A general rail-to-rail input comparator operates within the supply rails, but when the input signal level is close to the supply voltage, the propagation delay will decrease and may not be as designed. Input Voltage The NJU7725x, NJU7726x series are Rail-to-Rail input comparators. The common mode input voltage range is V− − 0.2V to V+ + 0.2V, and the differential input voltage can be any voltage within supply voltage. No phase inversion of the comparator output occurs when the input range of V− − 0.2V to V+ + 0.2V. Inputs of the NJU7725x, NJU7726x series are protected by ESD diodes (shown in Figure 1) that will conduct if the input voltages exceed the power supplies by more than approximately 300mV. Momentary voltages greater than 300mV beyond the power supply, inputs can be tolerated if the current is limited to 10mA. Figure 3 compares the NJU7725x and NJU7726x with a conventional rail-to-rail input comparators. Conventional comparators have a delay of 20 ns close to the supply voltage. This change in propagation delay requires a review of the design margin, which increases the design period. By using the NJU7725x and NJU7726x series with Dynamic Transient Stabilizer TM, stable response can be obtained in any voltage within supply voltage. Propagation Delay vs. Threshold Voltage V+ = 5V, Ta = 25°C 100 V+ +INPUT Input Stage -INPUT Propagation Delay [ns] 90 Figure 2 is simple accomplished with an input resistor. If the input voltage exceeds the supply voltage, the input current must be limited 10mA or less by using a restriction RLIMIT as shown in figure 2. 80 Conventional model 70 60 50 40 30 NJU7725x, NJU7726x 20 10 0 V- 0 Figure 1. Simplified Schematic 0.5 1 1.5 2 2.5 3 3.5 4 Threshold Voltage [V] 4.5 5 Figure 3. Propagation delay vs. Threshold Voltage V+ VIN+ RLIMIT Vout VINRLIMIT V- Figure 4 shows a window comparator circuit using the NJU7726x series. Even if the threshold setting is set near the power supply voltage, stable operation can be performed without delay in response time. Upper limit detection Figure 2. Input Current Protection for Voltages exceeding the Supply Voltage. Output Voltage The NJU7725x series features a push-pull output. The output logic level is the same as the supply rail. The circuit can be simplified without the need for an external pull-up resistor. The NJU7726x series has an open drain output. It can be pulled up to an external power supply up to V− + 5.5V independent of supply voltage. It can be applied to window comparators and logic level converter. Ver.0.3 Lower limit detection In conventional comparators, the upper limit detection was changed. -> Lower limit detection and upper limit detection are different. Figure 4. Level detection circuit using window comparator -7- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ APPLICATION NOTE Terminating unused comparators Inverting Comparator with Hysteresis Examples of common methods of terminating an uncommitted comparator are shown in Figure 5. Improper termination can be result increase supply current, heating and noise in comparators. Figure7 shows a hysteresis comparator circuit with three resistors. V+ VO VIN VO V+ VOH R1 R3 VOL R2 Figure 5. Terminating unused comparators The comparator can change the threshold by using positive feedback. The difference in threshold voltage is called hysteresis, which can improve noise immunity and operation for low-speed signals. V+ R1//R2 VO VTHL = VOH R1R2 R1+R2 R2 VREF = V+ R1+R2 R1∥R2= R3 VREF VTLH = VO R2 VO VIN Figure 6 shows a hysteresis comparator circuit with two resistors. Assuming that the threshold at which the comparator output is Low-High is VTLH and the threshold at which the comparator output is High-Low is VTHL, to achieve the following hysteresis are below. R1 VIN If R1 and R2 of the circuit in Figure 7 are represented by equivalent resistors, the circuit will be as shown in Figure 8. Since this circuit is the same as the noninverting hysteresis comparator, VTLH and VTHL can be calculated by rearranging the equations. Noninverting Comparator with Hysteresis V+ VTLH Figure 7. Inverting Comparator with Hysteresis External Hysteresis VREF VTHL R1∥R2 R1∥R2+R3 R1∥R2 R1∥R2+R3 VREF + VREF + R1∥R2 R1∥R2+R3 R1∥R2 R1∥R2+R3 VOL VOH VOL VIN VTHL VTLH VIN R1+R2 R1 VTLH = VREF V R2 R2 OL R1+R2 R1 VTHL = VREF V R2 R2 OH Figure 8. Noninverting hysteresis comparator as equivalent circuits Figure 6. Noninverting Comparator with Hysteresis Ver.0.3 -8- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ APPLICATION NOTE Window Comparator Square Wave Oscillator By using the open drain type NJU7726x in parallel, it is achieve to detect whether the signal is between two reference voltages. This circuit is commonly called a window comparator and can be used for monitoring the reference voltage and monitoring abnormal voltages such as signal voltage drop or overvoltage. Figure 9 shows a simple window comparator circuit. The comparator output VO is High only when VIN is between VREF1 and VREF2, and Low otherwise. If chattering occurs during the output shift period, connect capacitors in parallel with R1 and R3. V+ R2 = R3 = R4 R4 V1 R2 VO V+ V+ R3 Time C1 VO R1 V1 V+ Time Figure 11. Square Wave Oscillator VO R1 Figure 11 shows a simple square wave oscillator circuit. It can be used to digital circuits such as microcomputers, oscillation circuits, timing waveforms, and driver circuits for electronic buzzers. R4 VO VREF2 V+ When R2 = R3, the oscillator circuit has 50% duty, and the oscillation frequency is as follows. VIN R2 VOL 0V VREF1 VREF1 VREF2 V+ VIN R3 R3 V+ R1+R2+R3 R2+R3 VREF2 = V+ R1+R2+R3 f= 1 R4 2R1C1 ln (1+ ) R3 R2=R3 [Hz] VREF1 = R4 sets the threshold of the comparator that switches between charging and discharging to C1. If R2 = R3 = R4, the oscillation frequency is as follows. f= Figure 9. Window Comparator with NJU7726x 1 [Hz] 2R1C1 ln 2 R2=R3=R4 Example) Assuming V+ = 3.3V, R1 = R2 = R3 = 1MΩ, R4 = 10kΩ, the thresholds from the formula in Figure 9 are VREF1 = 1.1V, VREF2 = 2.2V. VO is Low when VIN < 1.1V or VIN > 2.2V, and VO is High when VIN is between1.1V and 2.2V (Figure 10). VIN VREF2 VREF1 Time High VO Low Time Figure 10. Window comparator output results Ver.0.3 -9- Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. Supply Current per Amplifier vs. Supply Voltage V− = 0V, VCOM = 0V, RL = Open 200 Ta = 25°C 150 100 Ta = 125°C 50 V− = 0V, VCOM = 0V, RL = Open 250 Supply Current per Amplifier [μA] 250 Supply Current per Amplifier [μA] Supply Current per Amplifier vs. Temperature Ta = −40°C 0 200 V+ = 5V 150 100 V+ = 3V 50 0 0 1 2 3 4 5 Supply Voltage [V] 6 7 -50 Supply Current per Amplifier vs. Common-Mode Input Voltage Input Offset Voltage [mV] Supply Current per Amplifier [μA] 300 Ta = 25°C Ta = −40°C 200 V− = 0V, VICM = −0.2V 3 350 250 0 25 50 75 100 125 150 Ambient Temperature [°C] Input Offset Voltage vs. Supply Voltage V+ = 5V, V− = 0V, RL = Open 400 -25 150 100 50 2 Ta = 125°C 1 0 -1 Ta = 25°C Ta = −40°C -2 Ta = 125°C 0 -3 0 1 2 3 4 Common-Mode Input Voltage [V] 5 2 Input Offset Voltage vs. Input Common Mode Voltage 3 4 5 Supply Voltage [V] V+ = 2.7V, V− = 0V V+ = 5V, V− = 0V 5 4 4 3 Ta = 125°C Ta = 25°C 2 1 0 -1 -2 Ta = −40°C -3 -4 Input Offset Voltage [mV] Input Offset Voltage [mV] 7 Input Offset Voltage vs. Input Common Mode Voltage 5 3 Ta = 125°C 2 1 0 -1 Ta = 25°C -2 Ta = −40°C -3 -4 -5 -5 -0.3 Ver.0.3 6 0.3 0.9 1.5 2.1 2.7 Input Common Mode Voltage [V] -0.5 0.5 1.5 2.5 3.5 4.5 Input Common Mode Voltage [V] 5.5 - 10 - Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. Input Offset Voltage Distribution CMR and SVR vs. Temperature V+ = 5V, V− = 0V, VCM = −0.2V, n = 54, Ta = 25°C V− = 0V 140 Common Mode and Supply Voltage Rejection Ratio [dB] 12 Number of Amplifiers 10 8 6 4 2 0 120 SVR (VCOM = −0.2V, V+ = 2.7 to 5.5V) 100 80 60 CMR (V+ = 5V, VCOM = −0.2V to 5.2V) 40 20 0 -5 -4 -3 -2 -1 0 1 2 3 Input Offset Voltage [mV] 4 5 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [°C] NJU7726x Output Leak Current vs. Temperature Input Bias Current vs. Temperature V+ = 5V, V− = 0V, VO = 5V V+ = 5V, V− = 0V 10 1 Output Leak Current [nA] Input Bias Current [nA] 10 VCOM = 5V 0.1 VCOM = 0V 0.01 1 0.1 Leak current< 0.1nA; measuament uncertainly 0.001 0.01 25 50 75 100 125 Ambient Temperature [°C] 150 -50 Low-level Output Voltage vs. Output Sink Current -25 0 25 50 75 100 125 150 Ambient Temperature [°C] NJU7725x High-level Output Voltage vs. Output Source Current V+ = 2.7V, V− = 0V V+ − = 2.7V, V− = 0V 2.7 2.7 2.4 2.4 Ta = 125°C Ta = −40°C 2.1 Output Voltage [V] Output Voltage [V] 2.1 1.8 Ta = 25°C 1.5 1.2 0.9 0.6 1.5 Ta = 125°C 1.2 0.9 Ta = 25°C 0.6 0.3 0.3 Ta = −40°C 0 0 0 Ver.0.3 1.8 5 10 15 20 25 30 Output Sink Current [mA] 35 0 5 10 15 20 25 30 Output Source Current [mA] 35 - 11 - Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. Low-level Output Voltage vs. Output Sink Current NJU7725x High-level Output Voltage vs. Output Source Current V+ = 5V, V− = 0V 5 2.5 4.5 Output Voltage [V] Output Voltage [V] V+ = 5V, V− = 0V 3 Ta = 125°C 2 1.5 Ta = 25°C Ta = −40°C 1 0.5 4 Ta = 125°C 3.5 Ta = 25°C 3 Ta = −40°C 2.5 0 2 0 5 10 15 20 25 30 35 40 45 50 Output Sink Current [mA] 0 NJU7725x Propagation Delay (Low to High) vs. Common-Mode Input Voltage 10 15 20 25 30 35 40 45 50 Output Source Current [mA] NJU7726x Propagation Delay (Low to High) vs. Common-Mode Input Voltage V+ = 5V, V− = 0V, CL = 15pF 100 5 V+ = 5V, V− = 0V, RL = 5.1kΩ, CL = 15pF 300 250 80 70 Ta = 25°C Propagation Delay [ns] Propagation Delay [ns] 90 Ta = 125°C 60 50 40 30 20 Ta = 125°C 150 100 0 0 0 1 2 3 4 Common-Mode Input Voltage [V] 5 0 Propagation Delay (High to Low) vs. Common-Mode Input Voltage 5 V+ = 5V, V− = 0V, VCOM = 2.5V, CL = 15pF 160 90 140 80 Propagation Delay [ns] Propagation Delay [ns] 1 2 3 4 Common-Mode Input Voltage [V] NJU7725x Propagation Delay (Low to High) vs. Overdrive Voltage V+ = 5V, V− = 0V, VCOM = 0V, CL = 15pF 100 70 Ta = 125°C 60 Ta = 25°C 50 40 30 20 10 120 Ta = −40°C 100 Ta = 25°C 80 Ta = 125°C 60 40 20 Ta = −40°C 0 0 0 Ver.0.3 Ta = −40°C 50 Ta = −40°C 10 Ta = 25°C 200 1 2 3 4 Common-Mode Input Voltage [V] 5 0 50 100 Overdrive Voltage [mV] 150 - 12 - Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. NJU7726x Propagation Delay (Low to High) vs. Overedrive Voltage Propagation Delay (High to Low) vs. Overdrive Voltage V+ = 5V, V− = 0V, VCOM = 2.5V, RL = 5.1kΩ, CL = 15pF 300 V+ = 5V, V− = 0V, VCOM = 2.5V, CL = 15pF 100 90 Ta = 25°C 200 Propagation Delay [ns] Propagation Delay [ns] 250 Ta = 125°C 150 100 50 Ta = −40°C 70 60 Ta = 25°C Ta = 125°C 50 40 30 20 Ta = −40°C 10 0 0 0 140 50 100 Overdrive Voltage [mV] 150 0 50 100 Overdrive Voltage [mV] 150 Propagation Delay vs. Supply Voltage NJU7725x Transient Response (Low to High) V− = 0V, VCOM = 0V, Overdrive = 100mV, Ta = 25°C V+ = 5V, V− = 0V, VCOM = 0V, Ta = 25°C 120 Propagation Delay [ns] 80 INPUT [0.1V / div] 100 Rise (NJU7726x) 80 Overdrive = 100mV Rise (NJU7725x) 60 Overdrive = 50mV 40 Overdrive = 20mV 20 OUTPUT [1V / div] Fall 0 2.5 3 3.5 4 4.5 5 Supply Voltage [V] 5.5 6 50ns / div NJU7726x Transient Response (Low to High) Transient Response (High to Low) V+ = 5V, V− = 0V, VCOM = 0V, RL = 5.1kΩ, Ta = 25°C V+ = 5V, V− = 0V, VCOM = 0V, Ta = 25°C INPUT [0.1V / div] INPUT [0.1V / div] OUTPUT [1V / div] Overdrive = 100mV Overdrive = 100mV Overdrive = 50mV Overdrive = 50mV Overdrive = 20mV Overdrive = 20mV OUTPUT [1V / div] 200ns / div Ver.0.3 50ns / div - 13 - Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ TEST CIRCUITS ● ISUPPLY VID = 100mV V+ A Open VID VCOM ● VOH ● VOL VID = 100mV VID = 100mV V+ V+ ISOURCE ISINK V V VID VID ● Propagation Delay RL = 5.1kΩ, VCOM = 0V, V+ V+ Overdrive VCOM (NJU7726x only) RL TPLH 90% CL 90% 50% VO Ver.0.3 TPHL VO VIN VCOM Overdrive VIN 50% 10% 10% TTLH TTHL - 14 - Datasheet NJU7725x / NJU7726x PRELIMINARY SPECIFICATIONS SUBJECT TO CHANGE ■ REVISION HISTORY Ver.0.3 Date Revision changes August 31, 2020 Ver.0.0 Initial Release August 19, 2021 Ver.0.1 Added NJU7726x series Added Application Note. September 22, 2021 Ver.0.2 Updated Descriptions. June 30, 2022 Ver.0.3 Updated Format Development status update - 15 - Package Information SOT-23-5 PI-SOT-23-5-E-A ■ PACKAGE DIMENSIONS UNIT: mm 2.9 ± 0.2 0 ~ 15 ° 1.9 ±0.2 4 0.6 2. 8 ±0 .2 1 .6 +0.2 -0.1 0 .2 5 2 1 3 0.1 0.95 ±0.1 0.4 ± 0.1 0.1 0 .1 m ax 1 .1 ±0 .1 0.6max +0.1 -0.03 Package Information SOT-23-5 PI-SOT-23-5-E-A ■ EXAMPLE OF SOLDER PADS DIMENSIONS UNIT: mm 2. 4 1 .0 0.7 0 . 95 0 . 95 Package Information SOT-23-5 PI-SOT-23-5-E-A ■ PACKING SPEC UNIT: mm TAPING DIMENSIONS SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 Feed direction P0 φD0 T B W1 W F E P2 A K0 φ D1 P1 T2 DIMENSION 3.3±0.1 3.2±0.1 1.55 1.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.82 1.5±0.1 8.0±0.3 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1MAX REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel PACKING STATE Label Label Put a reel into a box Empty tape Covering tape more than 20pitch reel more than 1 round Package Information SC-88A PI-SC-88A-E-A ■ PACKAGE DIMENSIONS 0. 4 25 ± 0. 2 UNIT: mm 2.0 ±0.2 1.3 ±0.2 5 (0 .2 45 ) 2. 1 ± 0. 2 1 . 25 ± 0 .1 3 0 .4 25 ± 0 .2 0.65 ±0.07 0 ~ 10 ° +0.05 -0.15 0 . 9 ±0 . 1 +0.2 0.1 0 .9 5 2 +0.1 -0.05 0. 2 -0.1 0.23 +0.1 -0.03 4 0. 05 ±0 .0 5 1 0.13 Package Information SC-88A PI-SC-88A-E-A ■ EXAMPLE OF SOLDER PADS DIMENSIONS UNIT: mm 1 .9 0. 8 0.3 0.65 0.65 Package Information SC-88A PI-SC-88A-E-A ■ PACKING SPEC UNIT: mm TAPING DIMENSIONS Feed direction P0 φ D0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A P1 T2 φD1 DIMENSION 2.3±0.1 2.5±0.1 1.55±0.05 1.05±0.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.3±0.1 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel PACKING STATE Label Label Put a reel into a box Empty tape Covering tape more than 20pitch reel more than 1 round Package Information DFN6-G1 (ESON6-G1) PI-DFN6-G1-E-A ■ PACKAGE DIMENSIONS UNIT: mm 0.10 M A S 0. 39 7 ±0 . 03 0 0.05 0. 10 S 0.075 0. 01 +0.01 -0.008 S M 1. 60 ±0 .0 5 S B 1.60 ±0.05 S A 1.20 +0.06 -0.04 C0 .2 0.5 0.5 0.26 +0.06 -0.04 +0.06 0 .2 1-0.04 3- R0 .2 +0.06 0. 68 -0.04 B φ0.05 M S AB Package Information DFN6-G1 (ESON6-G1) PI-DFN6-G1-E-A ■ EXAMPLE OF SOLDER PADS DIMENSIONS UNIT: mm 1.28 1 .8 0. 62 0 .3 1 0.28 1.14 Package Information DFN6-G1 (ESON6-G1) PI-DFN6-G1-E-A ■ PACKING SPEC UNIT: mm TAPING DIMENSIONS Feed direction φD0 P0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A P1 φD1 T2 DIMENSION 1.85±0.05 1.85±0.05 1.5 +0.1 0 0.5±0.1 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 0.65±0.05 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 E SYMBOL A B C D E W W1 D A B C DIMENSION 0 φ180 -1.5 φ 60 +10 φ 13±0.2 φ 21±0.8 2±0.5 9 +0.3 0 1.2 W TAPING STATE Insert direction Sealing with covering tape (TE3) Feed direction Empty tape Devices more than 40 pitch 3000pcs/reel PACKING STATE Label Label Put a reel into a box Empty tape Covering tape more than 25 pitch reel more than 1 round Package Information MSOP8 MEET JEDEC MO-187-DA (VSP8) PI-MSOP8-E-A ■ PACKAGE DIMENSIONS UNIT: mm 0 ~10゚ 1 4 +0.1 0.127 -0.05 0.65 +0.1 0.1 -0.05 1.1 ± 0.1 0.6max 0.1 0.2 ±0.1 0.1 0.55 ± 0.2 5 2.8 ± 0.2 8 4.0 ±0.3 2.9 +0.3 -0.1 M Package Information MSOP8 MEET JEDEC MO-187-DA (VSP8) PI-MSOP8-E-A ■ EXAMPLE OF SOLDER PADS DIMENSIONS UNIT: mm 0.65 3 .5 1 .0 0.23 1.95 Package Information MSOP8 MEET JEDEC MO-187-DA (VSP8) PI-MSOP8-E-A ■ PACKING SPEC UNIT: mm TAPING DIMENSIONS F e ed d i r e c ti o n P0 φ D0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A P1 T2 φD 1 DIMENSION 4.4 3.2 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 2.0 (MAX.) 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Devices Empty tape Feed direction more than 20pitch 2000pcs/reel PACKING STATE Label Label Put a reel into a box Empty tape Covering tape more than 20pitch reel more than 1round Package Information DFN8-U1 (ESON8-U1) PI-DFN8-U1-E-A ■ PACKAGE DIMENSIONS UNIT: mm 0.075 0.01 +0.010 -0.008 S 0.397 ±0.03 2.0 ± 0.05 2.0 ±0.05 S S 0.05 A 0.21 -0.04 +0.06 1.6 +0.06 -0.04 0.25 C0 .3 +0.06 3- R0 .3 1.08 -0.04 B 0.5 0.26 +0.06 -0.04 φ0.05 M S AB Package Information DFN8-U1 (ESON8-U1) PI-DFN8-U1-E-A ■ EXAMPLE OF SOLDER PADS DIMENSIONS UNIT: mm 0.28 1.54 1.78 2. 20 1 .0 2 0. 31 0.5 Package Information DFN8-U1 (ESON8-U1) PI-DFN8-U1-E-A ■ PACKING SPEC UNIT: mm TAPING DIMENSIONS Feed direct ion P0 φ D0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 T B W1 W F E P2 K0 A T2 φD1 P0 DIMENSION 2.25±0.05 2.25±0.05 1.5 +0.1 0 0.5±0.1 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.00±0.07 0.65±0.05 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 E D A B C SYMBOL A B C D E W W1 DIMENSION 0 φ180 -1.5 φ 60 +10 φ 13±0.2 φ 21±0.8 2±0.5 9 +0.3 0 1.2 W TAPING STATE Insert direction Sealing with covering tape (TE3) Feed direction Empty tape Devices more than 40 pitch 3000pcs/reel PACKING STATE Label Label Put a reel into a box Empty tape Covering tape more than 25 pitch reel more than 1 round 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. The materials in this document may not be copied or otherwise reproduced in whole or in part without the prior written consent of us. This product and any technical information relating thereto are subject to complementary export controls (so-called KNOW controls) under the Foreign Exchange and Foreign Trade Law, and related politics ministerial ordinance of the law. (Note that the complementary export controls are inapplicable to any application-specific products, except rockets and pilotless aircraft, that are insusceptible to design or program changes.) Accordingly, when exporting or carrying abroad this product, follow the Foreign Exchange and Foreign Trade Control Law and its related regulations with respect to the complementary export controls. The technical information described in this document shows typical characteristics and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our or any third party's intellectual property rights or any other rights. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death should first contact us. • Aerospace Equipment • Equipment Used in the Deep Sea • Power Generator Control Equipment (nuclear, steam, hydraulic, etc.) • Life Maintenance Medical Equipment • Fire Alarms / Intruder Detectors • Vehicle Control Equipment (automotive, airplane, railroad, ship, etc.) • Various Safety Devices • Traffic control system • Combustion equipment In case your company desires to use this product for any applications other than general electronic equipment mentioned above, make sure to contact our company in advance. Note that the important requirements mentioned in this section are not applicable to cases where operation requirements such as application conditions are confirmed by our company in writing after consultation with your company. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. The products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. We shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. Quality Warranty 8-1. Quality Warranty Period In the case of a product purchased through an authorized distributor or directly from us, the warranty period for this product shall be one (1) year after delivery to your company. For defective products that occurred during this period, we will take the quality warranty measures described in section 8-2. However, if there is an agreement on the warranty period in the basic transaction agreement, quality assurance agreement, delivery specifications, etc., it shall be followed. 8-2. Quality Warranty Remedies When it has been proved defective due to manufacturing factors as a result of defect analysis by us, we will either deliver a substitute for the defective product or refund the purchase price of the defective product. Note that such delivery or refund is sole and exclusive remedies to your company for the defective product. 8-3. Remedies after Quality Warranty Period With respect to any defect of this product found after the quality warranty period, the defect will be analyzed by us. On the basis of the defect analysis results, the scope and amounts of damage shall be determined by mutual agreement of both parties. Then we will deal with upper limit in Section 8-2. This provision is not intended to limit any legal rights of your company. Anti-radiation design is not implemented in the products described in this document. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. Warning for handling Gallium and Arsenic (GaAs) products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
NJU77251F-TE1 价格&库存
很抱歉,暂时无法提供与“NJU77251F-TE1”相匹配的价格&库存,您可以联系我们找货
NJU77251F-TE1
  • 1+7.486271+0.97184
  • 10+5.3458210+0.69398
  • 25+4.8116625+0.62464
  • 100+4.22437100+0.54840
  • 250+3.94381250+0.51197
  • 500+3.77470500+0.49002
  • 1000+3.637861000+0.47226
库存:2809
NJU77251F-TE1
  • 3000+3.463323000+0.44960
  • 6000+3.379106000+0.43867
  • 9000+3.336919000+0.43319
  • 15000+3.2901915000+0.42712
  • 21000+3.2629021000+0.42358
库存:2809
