www.msksemi.com
BCP51-MS BCP52-MS BCP53-MS
Semiconductor
Compiance
BCP51-MS.52-MS,53-MS TRANSISTOR (PNP)
SOT-223
FEATURES
2. COLLECTOR
For AF driver and output stages
High collector current
Low collector-emitter saturation voltage
Complementary types: BCP54...BCP56 (NPN)
z
1
1. BASE
z
2
z
3
3. EMITTER
z
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
VCBO
Collector-Base Voltage
-45
-60
-100
V
VCEO
Collector-Emitter Voltage
-45
-60
-80
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-1
A
PC
Collector Power Dissipation
1.5
W
RθJA
Thermal Resistance Junction to Ambient
94
℃/W
Tstg
Storage Temperature Range
Unit
-65~+150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Symbol
Parameter
Collector-base breakdown voltage
BCP51
BCP52
Collector-emitter breakdown voltage
Test conditions
V(BR)CBO
IC=- 0.1mA,IE=0
-60
-100
BCP51
-45
V(BR)CEO
IC= -10mA,IB=0
BCP53
Collector cut-off current
Max
Unit
-45
BCP53
BCP52
Base-emitter breakdown voltage
Min
V
-60
V
-80
V(BR)EBO
IE = -10μA,IC=0
-5
V
ICBO
VCB= -30 V, IE=0
hFE(1)
VCE=-2V, IC=-5mA
25
hFE(2)
VCE= -2V, IC=-150m A
63
hFE(3)
VCE= -2V, IC=-500m A
25
VCE(sat)
IC=-500mA,IB=-50mA
-0.5
V
Base-emitter voltage
VBE
VCE=-2V, IC=-500m A
-1
V
Transition frequency
fT
DC current gain
Collector-emitter saturation voltage
VCE=-10V,IC=-50mA,f=100MHz
-100
100
nA
250
MHz
CLASSIFICATION OF hFE(2)
TypE
BCP51-10,BCP52-10,BCP53-10
BCP51-16,BCP52-16,BCP53-16
Range
63-160
100-250
www.msksemi.com
Semiconductor
hTypical Characteristics ha
Static Characteristic
IC
COMMON EMITTER
VCE= -2V
Ta=100℃
-1mA
hFE
(mA)
COMMON
EMITTER
Ta=25℃
-200
DC CURRENT GAIN
IC
-0.9mA
-0.8mA
-150
COLLECTOR CURRENT
hFE
1000
-250
Compiance
-0.7mA
-0.6mA
-100
-0.5mA
-0.4mA
Ta=25℃
100
-0.3mA
-50
-0.2mA
IB=-0.1mA
-0
10
-0
-1
-2
-3
-4
COLLECTOR-EMITTER VOLTAGE
VBEsat ——
-1000
-5
-1
IC
VCEsat
-1000
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-800
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
-100
IC
-1000
(mA)
IC
β=10
β=10
Ta=25℃
-600
Ta=100 ℃
-400
-200
-0
-0.1
-1
-10
-100
COLLECTOR CURREMT
IC
-1000
IC
Ta=100 ℃
-100
Ta=25℃
-10
-0.1
-1000
-1
-10
COLLECTOR CURREMT
(mA)
VBE
fT
300
-1000
(mA)
IC
Ta=25℃
T =2
5℃
a
-10
TRANSITION FREQUENCY
100
T =1
00℃
a
COLLECTOR CURRENT
IC
fT
-100
-100
IC
COMMON EMITTER
VCE=-10V
(MHz)
COMMON EMITTER
VCE=-2V
(mA)
-10
COLLECTOR CURRENT
VCE (V)
-1
-0.1
-0
-200
-400
-600
-800
-1000
10
-3
-1200
-10
-20
1000
Cob/Cib
VCB/VEB
IC
-50
-60
125
150
(mA)
Ta
COLLECTOR POWER DISSIPATION
PC (mW)
1200
100
C
(pF)
-40
1500
Ta=25 ℃
Cib
CAPACITANCE
PC
1800
f=1MHz
IE=0/IC=0
Cob
10
1
-0.1
-30
COLLECTOR CURRENT
BASE-EMMITER VOLTAGE VBE (mV)
900
600
300
REVERSE VOLTAGE
-10
V
(V)
-30
50
75
AMBIENT TEMPERATURE
100
Ta
www.msksemi.com
Semiconductor
PACKAGE MECHANICAL DATA
Symbol
A
A1
A2
b
b1
c
D
E
E1
e
L
θ
Dimensions In Millimeters
Min.
Max.
1.800
0.020
0.100
1.500
1.700
0.660
0.840
2.900
3.100
0.230
0.350
6.300
6.700
6.700
7.300
3.300
3.700
2.300(BSC)
0.750
0°
10°
Dimensions In Inches
Min.
Max.
0.071
0.001
0.004
0.059
0.067
0.026
0.033
0.114
0.122
0.009
0.014
0.248
0.264
0.264
0.287
0.130
0.146
0.091(BSC)
0.030
0°
10°
REEL SPECIFICATION
P/N
PKG
QTY
SOT-223
1000
Compiance
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“BCP52-16-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.59649
- 100+0.49281
- 300+0.44097
- 1000+0.32649
- 5000+0.29538
- 10000+0.27972
