PS1117-5.0
PS1117-5.0
    PSI(宝力芯)
    SOT-223-3
    5V 1A 15V
PS1117-5.0 数据手册
DATA SHEET PS1117 1.0A LOW DROPOUT POSITIVE VOLTAGE REGULATOR DESCRIPTION The PS1117 series of positive adjustable and fixed regulators are designed to provide 1A with high efficiency. All internal circuitry is designed to operate down to 1.3V input to output differential. On-chip trimming adjusts the reference voltage to 1%. FEATURES „ „ „ „ „ „ „ „ Adjustable or Fixed Output Output Current of 1A Low Dropout, 1.5V max at 1A Output Current 0.04% Line Regulation 0.2 % Load Regulation 100% Thermal Limit Burn-In Fast Transient Response Lead Free And Halogen-Free PIN CONFIGURATION PIN CONFIGURATION 1 ADJ/GND 2 OUTPUT SOT-223 INPUT TO-263 2 TO-220 2 3 2 3 TO-252 1 1 3 1 3 1 23 PAGE.1 ORDERING INFORMATION Part Number PS1117-X.X-T43 PS1117-X.X-TC2 PS1117-X.X-TC2R PS1117-X.X-TA2 PS1117-X.X-TA2R PS1117-X.X-TB3 Package SOT-223 TO-252 TO-252 TO-263 TO-263 TO-220 Shipping Tape Reel Tube Tape Reel Tube Tape Reel Tube Marking Information: AMS1117 SXX ***** Marking Code: AMS1117 Output Voltage Code: XX EX: 5.0V, XX=50 Date Code: ***** INNER CODE SCHEMATIC DIAGRAM PAGE.2 TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS (TA=25°C,unless otherwise specified.) PARAMETER SYMBOL RATING UNIT Input-to-output Differential Voltage, VIN-VOUT VIN 15 V Power Dissipation PD Internal limited W Operating Junction Temperature Range TOPR -20 ~ +125 °C Storage Temperature Range TSTG -65 ~ +150 °C Lead Temperature (Soldering 10 sec) TLEAD 300 °C Note: Absolute Maximum Ratings are stress ratings only and functional device operation is not implied. The device could be permanently damaged beyond absolute maximum ratings. PAGE.3 ELECTRICAL CHARACTERISTICS ILOAD = 0mA and TJ = 25°C (unless otherwise noted) PARAMETER TEST CONDITIONS Reference Voltage (Note.1) Output Voltage (Note.1) VIN =5V, ILOAD = 10mA VIN – VOUT = 1.5V~10V, ILOAD = 10mA~1A VIN – VOUT = 1.5V, Variation from nominal VOUT Line Regulation (Note.1) Load Regulation (Note.1) VIN – VOUT = 1.5V~10V ILOAD = 0mA~1A, Variation from nominal VOUT ILOAD = 10mA, VIN – VOUT = 1.5V ~ 10V VIN – VOUT = 1.5V ILOAD = 10mA ~ 1A Minimum Load Current MIN TYP MAX UNIT 1.238 1.25 1.262 1.225 1.25 1.275 -1 - +1 V % -2 - +2 - 0.04 0.2 % - 0.2 0.4 VIN =5V, VADJ = 0V - 3 7 mA Ground Pin Current VIN – VOUT = 1.5V ILOAD = 10mA ~ 1A - 7 10 mA Adjust Pin Current VIN – VOUT = 1.5V ~ 10V ILOAD = 10mA - 40 90 uA Current Limit VIN – VOUT = 1.5V 1 1.4 - A Ripple Rejection (Note.2) Dropout Voltage (Note.1,3) VIN – VOUT = 3V ILOAD = 1A 60 65 - dB - 1.3 1.5 V ILOAD = 1A VIN – VOUT = 1.5V, 0.005 %/°C ILOAD = 10mA The * denotes the specifications which apply over the full temperature range (see previous table, TJ) Notes: 1: Low duty pulse testing with Kelvin connections required. 2: 120Hz input ripple (CADJ for ADJ = 25μF, COUT = 25μF) 3: ΔVOUT, ΔVREF = 1% Temperature Coefficient PAGE.4 SOT-223 DIMENSION Symbol L L1 W W1 E E1 H H1 D T θ Dimensions In Millimeters Min Max 6.30 6.71 2.90 3.15 6.70 7.30 3.33 3.71 2.30 BSC 0.60 0.84 1.52 1.80 1.50 1.70 0.90 1.15 0.25 0.35 0∘ 10∘ Dimensions In Inches Min Max 0.248 0.264 0.114 0.124 0.264 0.287 0.131 0.146 0.091 BSC 0.024 0.033 0.060 0.071 0.059 0.067 0.035 0.045 0.010 0.014 0∘ 10∘ PAGE.5 TO-252(DPAK) DIMENSION Symbol L L1 D D1 W W1 E E1 H H1 H2 T Dimensions In Millimeters Min Max 8.00 10.00 5.30 5.70 0.77 1.60 0.51 1.78 6.30 6.80 4.45 5.50 2.3 Nominal 0.97 2.03 2.53 0.40 1.01 1.30 1.80 0.43 0.60 Dimensions In Inches Min Max 0.315 0.394 0.209 0.224 0.030 0.063 0.020 0.070 0.248 0.268 0.175 0.217 0.091 Nominal 0.038 0.080 0.100 0.016 0.040 0.051 0.071 0.017 0.024 PAGE.6 TO-263 DIMENSION Symbol L L1 D D1 W E1 E H H1 H2 T Dimensions In Millimeters Min Max 14.60 15.88 8.25 9.25 1.14 1.40 2.29 2.79 9.65 10.69 2.29 2.79 0.51 1.14 4.37 4.83 1.40 1.41 2.03 2.92 0.30 0.64 Dimensions In Inches Min Max 0.575 0.625 0.325 0.364 0.045 0.055 0.090 0.110 0.380 0.421 0.090 0.110 0.020 0.045 0.172 0.190 0.055 0.056 0.080 0.115 0.012 0.025 PAGE.7 TO-220 DIMENSION Symbol L L1 L2 L3 W W1 W2 H H1 T φ Dimensions In Millimeters Min Max 9.65 10.67 1.14 1.78 0.50 1.15 2.28 2.80 14.22 16.51 12.70 14.74 5.58 7.49 2.03 4.83 0.50 1.40 0.30 1.15 0.36 0.64 Dimensions In Inches Min Max 0.380 0.420 0.045 0.070 0.020 0.045 0.090 0.110 0.560 0.650 0.500 0.580 0.220 0.295 0.080 0.190 0.020 0.055 0.012 0.045 0.014 0.025 PAGE.8
PS1117-5.0 价格&库存
很抱歉,暂时无法提供与“PS1117-5.0”相匹配的价格&库存,您可以联系我们找货
