AP20N06D
AP20N06D
    APM-MICROELECTRONICS(永源微)
    TO-252(DPAK)
    60V N沟道增强型MOSFET,电流:20A,耐压:60V
AP20N06D 数据手册
AP20N06D 60V N-Channel Enhancement Mode MOSFET Description The AP20N06D uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 4.5V. This device is suitable for use as a Battery protection or in other Switching application. General Features VDS = 60V ID =20 A RDS(ON) < 40mΩ @ VGS=10V Application Battery protection Load switch Uninterruptible power supply Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) AP20N06D TO-252-3L AP20N06D XXXX YYYY 2500 Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter Rating Units VDS Drain-Source Voltage 60 V VGS Gate-Source Voltage ID@TC=25℃ ID@TC=100℃ ID@TA=25℃ ID@TA=70℃ IDM EAS ±20 V Continuous Drain Current, VGS @ 10V1 20 A Continuous Drain Current, VGS @ 10V1 13 A Continuous Drain Current, VGS @ 10V1 5 A Continuous Drain Current, VGS @ 10V1 4 A 40 A 22 mJ Pulsed Drain Current2 Single Pulse Avalanche Energy3 IAS Avalanche Current 21 A PD@TC=25℃ Total Power Dissipation4 31.3 W PD@TA=25℃ Total Power Dissipation4 2 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ 62 ℃/W 4 ℃/W RθJA Thermal Resistance Junction-ambient RθJC Junction-Case1 Thermal Resistance 1 1 AP20N06D Rve3.8 臺灣永源微電子科技有限公司 AP20N06D 60V N-Channel Enhancement Mode MOSFET Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Conditions Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient Min. Typ. Max. Unit VGS=0V , ID=250uA 60 --- --- V Reference to 25℃ , ID=1mA --- 0.044 --- V/℃ VGS=10V , ID=15A --- 33 40 RDS(ON) VGS(th) Static Drain-Source Gate Threshold Voltage VGS=4.5V , ID=7A --1.0 40 --- 50 2.5 mΩ V △VGS(th) VGS(th) Temperature Coefficient ----- -4.8 --- --1 mV/℃ IDSS Drain-Source Leakage Current VGS=VDS , ID =250uA VDS=48V , VGS=0V , TJ=25℃ VDS=48V , VGS=0V , TJ=55℃ --- --- 5 IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA gfs Forward Transconductance VDS=5V , ID=15A --- 25.3 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 2.5 --- Ω Qg Total Gate Charge (10V) --- 19 --- Qgs Gate-Source Charge --- 2.5 --- Qgd Gate-Drain Charge --- 5 --- Td(on) Turn-On Delay Time --- 2.8 --- --- 16.6 --- --- 21.2 --- --- 5.6 --- --- 1027 --- --- 65 --- --- 46 --- --- --- 20 A --- --- 40 A --- --- 1.2 V --- 12.2 --- nS --- 7.3 --- nC Tr Td(off) Tf On-Resistance2 VDS=48V , VGS=10V , ID=15A VDD=30V , VGS=10V , RG=3.3 Rise Time Turn-Off Delay Time ID=15A Fall Time Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance IS ISM VSD Continuous Source Current Pulsed Source Current2,6 Diode Forward Voltage2 trr Reverse Recovery Time Qrr Reverse Recovery Charge VDS=15V , VGS=0V , f=1MHz 1,6 VG=VD=0V , Force Current VGS=0V , IS=1A , TJ=25℃ IF=15A , TJ=25℃ dI/dt=100A/µs , uA nC ns pF Note : 1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=21A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. 2 AP20N06D Rve3.8 臺灣永源微電子科技有限公司 AP20N06D 60V N-Channel Enhancement Mode MOSFET Typical Characteristics 60 ID=12A RDSON (mΩ) 53 45 38 30 2 4 6 8 10 VGS (V) Fig.1 Typical Output Characteristics Fig.2 On-Resistance vs. Gate-Source Voltage 10 IS -Source Current(A) 8 6 TJ=150℃ TJ=25℃ 4 2 0 0 0.3 0.6 0.9 VSD , Source-to-Drain Voltage (V) Fig.3 Forward Characteristics Of Reverse Fig.4 Gate-Charge Characteristics diode 2.2 Normalized On Resistance 1.8 1.8 Normalized VGS(th) 1.4 1.4 1 1.0 0.6 0.6 0.2 0.2 -50 0 50 100 Fig.5 Normalized VGS(th) vs. TJ AP20N06D Rve3.8 -50 0 50 100 150 TJ , Junction Temperature (℃) Fig.6 Normalized RDSON vs. TJ 臺灣永源微電子科技有限公司 3 TJ ,Junction Temperature (℃) 150 AP20N06D 60V N-Channel Enhancement Mode MOSFET 100.00 10000 Capacitance(pF) F=1.0MHz 10.00 Ciss 10us ID (A) 1000 100 1ms 10ms 100ms DC 1.00 Coss 0.10 TC=25℃ Single Pulse Crss 0.01 10 1 5 9 13 17 21 0.1 25 1 10 100 1000 VDS (V) VDS Drain to Source Voltage(V) Fig.7 Capacitance Fig.8 Safe Operating Area Normalized Thermal Response (RθJC) 1 DUTY=0.5 0.2 0.1 0.01 0.1 0.05 0.02 0.01 P DM SINGLE T ON T D = TON/T TJpeak = TC+P DMXRθJC 0.001 0.00001 0.0001 0.001 0.01 0.1 1 t , Pulse Width (s) Fig.9 Normalized Maximum Transient Thermal Impedance EAS= VDS 90% BVDSS 1 L x IAS2 x 2 BVDSS BVDSS-VDD VDD IAS 10% VGS Td(on) Tr Ton Td(off) Tf Toff Fig.10Mechanical Switching Time Waveform Package Data VGS Fig.11 Unclamped Inductive Switching Waveform 4 AP20N06D Rve3.8 臺灣永源微電子科技有限公司 AP20N06D 60V N-Channel Enhancement Mode MOSFET E Dimensions A B2 Ref. C2 H D L V1 C B DETAIL A V1 V2 A2 V1 E1 Typ. Min. Typ. Max. 2.10 2.50 0.083 0.098 A2 0 0.10 0 0.004 B 0.66 0.86 0.026 0.034 B2 5.18 5.48 0.202 0.216 C 0.40 0.60 0.016 0.024 C2 0.44 0.58 0.017 0.023 D 5.90 6.30 0.232 E 6.40 E1 4.63 0.248 0.209REF 5.30REF 6.80 0.252 0.268 0.182 G 4.47 4.67 H 9.50 10.70 0.374 0.421 L 1.09 1.21 0.043 0.048 L2 1.35 1.65 0.176 0.053 7° V1 L2 Inches Max. A D1 G D1 Millimeters Min. V2 0° 0.184 0.065 7° 0° 6° 6° DETAIL A TO-252 Reel Spectification-TO-252 B D 0 P0 P2 Dimensions T E Ref. A B0 A D1 W F t1 K0 P1 A0 B B B 5° 20 Φ3 29 A A Φ13 Millimeters Inches Min. Typ. Max. Min. Typ. Max. W 15.90 16.00 16.10 0.626 0.630 0.634 E 1.65 1.75 1.85 0.065 0.069 0.073 F 7.40 7.50 7.60 0.291 0.295 0.299 D0 1.40 1.50 1.60 0.055 0.059 0.063 D1 1.40 1.50 1.60 0.055 0.059 0.063 P0 3.90 4.00 4.10 0.154 0.157 0.161 P1 7.90 8.00 8.10 0.311 0.315 0.319 P2 1.90 2.00 2.10 0.075 0.079 0.083 0.276 A0 6.85 6.90 7.00 0.270 0.271 B0 10.45 10.50 10.60 0.411 0.413 0.417 K0 2.68 2.78 2.88 0.105 0.109 0.113 T 0.24 t1 0.10 10P0 39.80 0.27 0.009 0.011 0.004 40.00 40.20 1.567 1.575 1.583 5 AP20N06D Rve3.8 臺灣永源微電子科技有限公司 AP20N06D 60V N-Channel Enhancement Mode MOSFET Attention 1,Any and all APM Microelectronics products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your APM Microelectronics representative nearest you before using any APM Microelectronics products described or contained herein in such applications. 2,APM Microelectronics assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all APM Microelectronics products described or contained herein. 3, Specifications of any and all APM Microelectronics products described or contained here instipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. 4, APM Microelectronics Semiconductor CO., LTD. strives to supply high quality high reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives that could give rise to smoke or fire, or that could cause damage to other property. Whendesigning equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design,and structural design. 5,In the event that any or all APM Microelectronics products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. 6, No part of this publication may be reproduced or transmitted in any form or by any means,electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of APM Microelectronics Semiconductor CO., LTD. 7, Information (including circuit diagrams and circuit parameters) herein is for example only; it is not guaranteed for volume production. APM Microelectronics believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. 8, Any and all information described or contained herein are subject to change without notice due to product/technology improvement,etc. When designing equipment, refer to the "Delivery Specification" for the APM Microelectronics product that you Intend to use. 6 AP20N06D Rve3.8 臺灣永源微電子科技有限公司
AP20N06D
1. 物料型号:型号为STM32F407IGT6,是一款基于ARM Cortex-M4的32位微控制器。
2. 器件简介:该器件是高性能微控制器,具有1MB的闪存和192KB的RAM,适用于工业控制、消费电子等。
3. 引脚分配:共有216个引脚,包括GPIO、电源、地、晶振等。
4. 参数特性:主频高达168MHz,支持多种通信接口,如I2C、SPI、UART等。
5. 功能详解:详细介绍了各功能模块,如ADC、DAC、定时器等。
6. 应用信息:适用于需要高性能处理和丰富外设的应用场景。
7. 封装信息:封装为LQFP216,适用于表面贴装技术。
AP20N06D 价格&库存
很抱歉,暂时无法提供与“AP20N06D”相匹配的价格&库存,您可以联系我们找货
