AP6N40D
AP6N40D
    APM-MICROELECTRONICS(永源微)
    TO-252(DPAK)
    400V,6A,400V N沟道 ENHANCEMENT MODE MOSFET
AP6N40D 数据手册
AP6N40D 400V N-Channel Enhancement Mode MOSFET Description The AP6N40D is silicon N-channel Enhanced VDMOSFETs, is obtained by the self-aligned planar Technology which reduce the conduction loss, improve switching performance and enhance the avalanche energy. The transistor can be used in various power switching circuit for system miniaturization and higher efficiency. General Features VDS = 400V ID =6A RDS(ON) < 1.0Ω @ VGS=10V (Type:0.8Ω) Application Uninterruptible Power Supply(UPS) Power Factor Correction (PFC) Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) AP6N40D TO-252-3L AP6N40D XXX YYYY 2500 Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter Value Unit VDSS Drain-Source Voltage (VGS = 0V) 400 V ID Continuous Drain Current 6 A 28 A IDM Pulsed Drain Current (note1) VGS Gate-Source Voltage ±30 V EAS Single Pulse Avalanche Energy (note2) 176 mJ IAR Avalanche Current (note1) 7 A EAR Repetitive Avalanche Energy note1) 18 mJ PD Power Dissipation (TC = 25ºC) 32.9 W -55~+150 ºC TJ, Tstg Operating Junction and Storage Temperature Range RthJC Thermal Resistance, Junction-to-Case 3.8 ºC/W RthJA Thermal Resistance, Junction-to-Ambient 13.3 ºC/W 1 AP6N40D RVE1.0 永源微電子科技有限公司 AP6N40D 400V N-Channel Enhancement Mode MOSFET Electrical Characteristics (TJ=25℃, unless otherwise noted) Symbol Parameter Test Conditions Min Typ Max Unit V(BR)DSS Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA 400 440 -- V IDSS Zero Gate Voltage Drain Current VDS= 650V, VGS= 0V, TJ=25ºC -- -- 1 μA IGSS Gate-Source Leakage VGS = ±30V -- -- ±100 nA VGS(th) Gate-Source Threshold Voltage VDS = VGS, ID = 250µA 2.0 3.5 4.0 V RDS(on) Drain-Source On-Resistance (Note3) VGS = 10V, ID = 3.5A -- 0.8 1.0 Ω Ciss Input Capacitance -- 700 -- Coss Output Capacitance -- 94 -- Crss Reverse Transfer Capacitance -- 12 -- Qg Total Gate Charge -- 19 -- Qgs Gate-Source Charge -- 3.7 -- Qgd Gate-Drain Charge -- 11 -- td(on) Turn-on Delay Time -- 13 -- tr Turn-on Rise Time -- 20 -- VGS = 0V, VDS = 25V, f = 1.0MHz VDD=520V, ID = 7A, VGS = 10V VDD=325V, ID = 7A, RG = 25Ω pF nC ns td(off) Turn-off Delay Time -- 76 -- tf Turn-off Fall Time -- 40 -- IS Continuous Body Diode Current -- -- 7.0 A ISM Pulsed Diode Forward Current -- -- 28 A VSD Body Diode Voltage -- -- 1.4 V trr Reverse Recovery Time -- 260 -- ns Qrr Reverse Recovery Charge -- 3.8 -- μC TC = 25 ºC TJ = 25ºC, ISD = 7A, VGS = 0V VGS = 0V,IS = 7A, diF/dt =100A /μs Note : 1、The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2、The EAS data shows Max. rating . IAS = 4.5A, VDD = 50V, RG = 25 Ω, Starting TJ = 25 ºC 3、The test condition is Pulse Test: Pulse width ≤ 300μs, Duty Cycle ≤ 1% 4、The power dissipation is limited by 150℃ junction temperature 5、The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. 2 AP6N40D RVE1.0 永源微電子科技有限公司 AP6N40D 400V N-Channel Enhancement Mode MOSFET Typical Characteristics Figure 1. Output Characteristics (T J = 25ºC) Figure 3. Drain Current vs. Temperature AP6N40D RVE1.0 Figure 4. BV DSS Variation vs. Temperature Figure 6. On-Resistance vs. Temperature 永源微電子科技有限公司 3 Figure 5. Transfer Characteristics Figure 2. Body Diode Forward Voltage AP6N40D 400V N-Channel Enhancement Mode MOSFET Figure 7. Capacitance Figure 8. Gate Charge Figure 9. Transient Thermal Impedance 4 AP6N40D RVE1.0 永源微電子科技有限公司 AP6N40D 400V N-Channel Enhancement Mode MOSFET Package Mechanical Data:TO-252-3L E Dimensions A B2 C2 Ref. L V1 Min. 0.083 0.098 A2 0 0.10 0 0.004 B 0.66 0.86 0.026 0.034 B2 5.18 5.48 0.202 0.216 C 0.40 0.60 0.016 0.024 C2 0.44 0.58 0.017 0.023 D 5.90 6.30 0.232 0.248 6.80 0.252 D H DETAIL A V1 A2 V1 0.209REF 6.40 E1 4.63 G 4.47 4.67 H 9.50 10.70 0.374 0.421 L 1.09 1.21 0.043 0.048 L2 1.35 1.65 0.053 V2 0.268 0.182 0.176 7° V1 L2 Max. E V2 D1 5.30REF D1 G Typ. Max. 2.50 Min. C E1 Typ. Inches 2.10 A B Millimeters 0.184 0.065 7° 0° 6° 0° 6° DETAIL A TO-252 Reel Spectification-TO-252 B D 0 P0 P2 Dimensions T E Ref. A B0 A D1 W F t1 K0 P1 A0 B B B 5° Φ3 29 A A 20 Φ13 Millimeters Inches Min. Typ. Max. Min. Typ. Max. W 15.90 16.00 16.10 0.626 0.630 0.634 E 1.65 1.75 1.85 0.065 0.069 0.073 F 7.40 7.50 7.60 0.291 0.295 0.299 D0 1.40 1.50 1.60 0.055 0.059 0.063 0.063 D1 1.40 1.50 1.60 0.055 0.059 P0 3.90 4.00 4.10 0.154 0.157 0.161 P1 7.90 8.00 8.10 0.311 0.315 0.319 P2 1.90 2.00 2.10 0.075 0.079 0.083 A0 6.85 6.90 7.00 0.270 0.271 0.276 B0 10.45 10.50 10.60 0.411 0.413 0.417 K0 2.68 2.78 2.88 0.105 0.109 0.113 T 0.24 t1 0.10 10P0 39.80 0.27 0.009 0.011 0.004 40.00 40.20 1.567 1.575 1.583 5 AP6N40D RVE1.0 永源微電子科技有限公司 AP6N40D 400V N-Channel Enhancement Mode MOSFET Attention 1,Any and all APM Microelectronics products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your APM Microelectronics representative nearest you before using any APM Microelectronics products described or contained herein in such applications. 2,APM Microelectronics assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all APM Microelectronics products described or contained herein. 3, Specifications of any and all APM Microelectronics products described or contained here instipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. 4, APM Microelectronics Semiconductor CO., LTD. strives to supply high quality high reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives that could give rise to smoke or fire, or that could cause damage to other property. Whendesigning equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design,and structural design. 5,In the event that any or all APM Microelectronics products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. 6, No part of this publication may be reproduced or transmitted in any form or by any means,electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of APM Microelectronics Semiconductor CO., LTD. 7, Information (including circuit diagrams and circuit parameters) herein is for example only; it is not guaranteed for volume production. APM Microelectronics believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. 8, Any and all information described or contained herein are subject to change without notice due to product/technology improvement,etc. When designing equipment, refer to the "Delivery Specification" for the APM Microelectronics product that you Intend to use. 6 AP6N40D RVE1.0 永源微電子科技有限公司 AP6N40D 400V N-Channel Enhancement Mode MOSFET Edition Date Change Rve1.0 2021/1/31 Initial release Copyright Attribution“APM-Microelectronice” 7 AP6N40D RVE1.0 永源微電子科技有限公司
AP6N40D 价格&库存
很抱歉,暂时无法提供与“AP6N40D”相匹配的价格&库存,您可以联系我们找货
