WR0332-33A50R
WR0332-33A50R
    WAYON(上海维安)
    SOT23-5
    3.3V 300MA 5.5V
WR0332-33A50R 数据手册
WR0332 High PSRR, High speed, CMOS LDO General Description Features The WR0332 series is a high accuracy, low noise, ⚫ Input Voltage: 2.0V~5.5V high speed, low dropout CMOS Linear regulator with ⚫ Output Voltage: 1.0V~3.3V high ripple rejection. The devices offer a new level of ⚫ Output Current: 300mA cost-effective performance in cellular phones, laptop ⚫ PSRR: 70dB@1KHz and notebook computers, and other portable devices. ⚫ Dropout Voltage: 220mV @ IOUT = 300mA ⚫ Operating Temperature: -40~+125ºC ⚫ Shut-down Current: < 1μA ⚫ Quiescent Current: 60μA Typ. ⚫ Recommend Capacitor: 1μF The WR0332 has the fold-back maximum output current which depends on the output voltage. So the current limit functions both as a short circuit protection and as an output current limiter. Applications The WR0332 regulators are available in standard SOT23-3 package、SOT23-5 package and DFN1x14 Package. Standard products are Pb-free and Halogen-free. ⚫ MP3/MP4 Players ⚫ Cellphones, radiophone, digital cameras ⚫ Bluetooth, wireless handsets ⚫ Others portable electronic device Typical Application W02040004 – Rev1.5 www.way-on.com 1 WR0332 Pin Configuration (Top View) 5 3 1 1 2 SOT23-3 2 4 4 3 3 1 2 SOT23-5 DFN-4 Pin Description Pin Number Pin Description SOT23-3 SOT23-5 DFN-4 Name 3 1 4 IN Input Voltage 1 2 2 GND Ground - 3 3 EN Enable, Active High - 4 - NC NC 2 5 1 OUT Output Voltage - EPAD Exposed pad should be connected directly to the GND pin. Soldered to a large ground copper plane allows for effective heat removal. www.way-on.com March 2021 – Rev1.5 2 WR0332 Absolute Maximum Ratings Parameter Rating Unit Input voltage range -0.3 ~ 6.5 V EN Input voltage range -0.3 ~ VIN V Output voltage range -0.3 ~ VIN V SOT23-3 & SOT23-5 500 mW DFN-4 500 mW SOT23-3 & SOT23-5 250 ºC/W DFN-4 250 ºC/W Junction Temperature 150 ºC Lead Temperature Range 260 ºC Storage Temperature Range -55 ~ 150 ºC ±4000 V Parameter Rating Unit Operating Supply voltage 2.0 ~ 5.5 V Operating Temperature Range -40 ~ 125 ºC Power Dissipation PD @TA = 25ºC Thermal Resistance, θJA HBM ESD Susceptibility Recommended Operating Conditions March 2021 – Rev1.5 www.way-on.com 3 WR0332 Electrical Characteristics (TA=25 ºC, VIN=VOUT+1V, CIN=COUT=1μF, unless otherwise noted) symbol VOUT VDO Parameter Output Voltage Dropout Voltage1 Test Condition Min Typ Max VOUT ≤1.5V, VIN=2.7V, IOUT=1mA 0.97 VOUT VOUT 1.03 VOUT VOUT>1.5V, IOUT=1mA 0.98 VOUT VOUT 1.02 VOUT VOUT=3.3V, IOUT=300mA 220 330 VOUT=3.0V, IOUT=300mA 240 360 VOUT=2.8V, IOUT=300mA 250 375 VOUT=2.5V, IOUT=300mA 280 420 VOUT=2.2V, IOUT=300mA 310 465 VOUT=1.8V, IOUT=300mA 400 600 V mV IOUT Maximum Output Current2 VEN=VIN LNR Line Regulation VOUT=3.3V, VIN=4.3~5.5V, IOUT=1mA 0.05 LDR Load Regulation3 VOUT=3.3V, IOUT=1~300mA 15 IQ Quiescent Current VOUT=3.3V, IOUT=0mA 60 80 μA ISHDN Shut-down Current VEN = 0V 0.1 1.0 μA ISHORT Short Current VEN=VIN, VOUT Short to GND 150 VIN=(VOUT+1V) DC+0.5VP-P F=1KHz, IOUT=10mA, @VOUT=3.3V 70 VIN=(VOUT+1V) DC+0.5VP-P F=10KHz, IOUT=10mA, @VOUT=3.3V 55 140 PSRR Power Supply Ripple Rejection 300 Unit mA 0.1 %/V mV mA dB VNO Output noise voltage 10Hz to 100KHz, COUT=1μF VIH EN logic high voltage VIN=5.5V, IOUT=1mA VIL EN logic low voltage VIN=5.5V, IOUT=1mA TSD Thermal shutdown threshold 165 ºC ΔTSD Thermal shutdown hysteresis 30 ºC RDIS Output Discharge resistance 150 Ω VIN=4.0V, VEN=0V µVRMS 1.2 V 0.4 V Note1: The dropout voltage is defined as (VIN-VOUT) when VOUT is 100mV below the target value of VOUT. VDO is measured for devices with VOUT(nom) ≥ 1.8 V. Note2: Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal layers, ambient temperature and the other environment factors of system. Attention should be paid to the dropout voltage when VIN < VOUT + VDROP. Note3: The Load regulation is measured using pulse techniques with duty cycle < 5%. www.way-on.com March 2021 – Rev1.5 4 WR0332 Typical Characteristics (Ta=25ºC, VIN=VOUT+1V, CIN=COUT=1µF, unless otherwise noted) Quiescent Current vs. Supply Voltage Quiescent Current vs. Supply Voltage Output Voltage vs. Supply Voltage Output Voltage vs. Supply Voltage Output Voltage vs. Output Current Output Voltage vs. Output Current March 2021 – Rev1.5 www.way-on.com 5 WR0332 Quiescent Current vs. Temperature Output Voltage vs. Temperature Dropout Voltage vs. Output Current Power Supply Rejection Ratio vs. Frequency www.way-on.com March 2021 – Rev1.5 6 WR0332 Soft Start from EN EN Shutdown Soft Start from EN EN Shutdown Line Transient Load Transient Line Transient Load Transient March 2021 – Rev1.5 www.way-on.com 7 WR0332 Block Diagram OUT IN Current Limit VREF EN Enable Control OTP GND www.way-on.com March 2021 – Rev1.5 8 WR0332 Package Information SOT 23-3 SYMBOL DIMENSIONS IN MILLIMETERS MIN NOM MAX A 2.60 2.80 3.00 A1 1.50 1.60 1.70 B 0.95BSC C 0.25 0.40 0.50 D 2.82 2.92 3.02 E 0.10 0.15 0.20 L 0.59REF L1 0.30 0.45 0.60 F1 0.90 1.10 1.30 F 0.00 0.08 0.15 March 2021 – Rev1.5 www.way-on.com 9 WR0332 SOT 23-5 SYMBOL DIMENSIONS IN MILLIMETERS MIN NOM MAX A 2.60 2.80 3.00 A1 1.50 1.60 1.70 B 0.95BSC B1 1.90BSC C 0.25 0.40 0.50 D 2.82 2.92 3.02 E 0.10 0.15 0.20 F 0.00 0.08 0.15 L 0.59REF F1 0.90 1.10 1.30 L1 0.30 0.45 0.60 www.way-on.com March 2021 – Rev1.5 10 WR0332 A E D C DETAIL A Pin 1 ID and Tie Bar Mark Options F Pin1 Note: The configuration of the Pin 1 identifier Top View Bottom View is optional, but must be located within the zone indicated. B Side View DFN-4 SYMBOL DIMENSIONS IN MILLIMETERS MIN NOM MAX A 0.950 1.000 1.050 B 0.320 0.370 0.420 C 0.950 1.000 1.050 D 0.650BSC E 0.170 0.270 0.370 F 0.130 0.235 0.300 G 0.430 0.485 0.540 H 0.430 0.485 0.540 I 0.200REF March 2021 – Rev1.5 www.way-on.com 11 WR0332 Ordering Information Packing Part Number Output Voltage Package WR0332-10A30R 1.0V SOT23-3 3K/Reel WR0332 10 (J)XXXX WR0332-105A30R 1.05V SOT23-3 3k/Reel WR0332 105 (J)XXXX WR0332-11A30R 1.1V SOT23-3 3k/Reel WR0332 11 (J)XXXX WR0332-12A30R 1.2V SOT23-3 3K/Reel WR0332 12 (J)XXXX WR0332-15A30R 1.5V SOT23-3 3k/Reel WR0332 15 (J)XXXX WR0332-18A30R 1.8V SOT23-3 3k/Reel WR0332 18 (J)XXXX WR0332-20A30R 2.0V SOT23-3 3k/Reel WR0332 20 (J)XXXX WR0332-22A30R 2.2V SOT23-3 3k/Reel WR0332 22 (J)XXXX WR0332-25A30R 2.5V SOT23-3 3k/Reel WR0332 25 (J)XXXX WR0332-28A30R 2.8V SOT23-3 3k/Reel WR0332 28 (J)XXXX WR0332-30A30R 3.0V SOT23-3 3k/Reel WR0332 30 (J)XXXX WR0332-33A30R 3.3V SOT23-3 3k/Reel WR0332 33 (J)XXXX WR0332-10A50R 1.0V SOT23-5 3K/Reel WR0332 10 (J)XXXX WR0332-105A50R 1.05V SOT23-5 3k/Reel WR0332 105 (J)XXXX WR0332-11A50R 1.1V SOT23-5 3k/Reel WR0332 11 (J)XXXX WR0332-12A50R 1.2V SOT23-5 3k/Reel WR0332 12 (J)XXXX WR0332-15A50R 1.5V SOT23-5 3k/Reel WR0332 15 (J)XXXX WR0332-18A50R 1.8V SOT23-5 3k/Reel WR0332 18 (J)XXXX WR0332-20A50R 2.0V SOT23-5 3k/Reel WR0332 20 (J)XXXX WR0332-22A50R 2.2V SOT23-5 3k/Reel WR0332 22 (J)XXXX WR0332-25A50R 2.5V SOT23-5 3k/Reel WR0332 25 (J)XXXX WR0332-27A50R 2.7V SOT23-5 3k/Reel WR0332 27 (J)XXXX WR0332-28A50R 2.8V SOT23-5 3k/Reel WR0332 28 (J)XXXX WR0332-29A50R 2.9V SOT23-5 3k/Reel WR0332 29 (J)XXXX WR0332-30A50R 3.0V SOT-23-5 3k/Reel WR0332 30 (J)XXXX WR0332-33A50R 3.3V SOT-23-5 3k/Reel WR0332 33 (J)XXXX WR0332-10FF4R 1.0V DFN-4 10k/Reel 332 10 WR0332-105FF4R 1.05V DFN-4 10k/Reel 332 105 WR0332-11FF4R 1.1V DFN-4 10k/Reel 332 11 WR0332-12FF4R 1.2V DFN-4 10k/Reel 332 12 WR0332-15FF4R 1.5V DFN-4 10k/Reel 332 15 WR0332-18FF4R 1.8V DFN-4 10k/Reel 332 18 WR0332-185FF4R 1.85V DFN-4 10k/Reel 332 185 www.way-on.com Quantity Marking* March 2021 – Rev1.5 12 WR0332 Packing Part Number Output Voltage Package WR0332-20FF4R 2.0V DFN-4 10k/Reel 332 20 WR0332-21FF4R 2.1V DFN-4 10k/Reel 332 21 WR0332-22FF4R 2.2V DFN-4 10k/Reel 332 22 WR0332-25FF4R 2.5V DFN-4 10k/Reel 332 25 WR0332-27FF4R 2.7V DFN-4 10k/Reel 332 27 WR0332-28FF4R 2.8V DFN-4 10k/Reel 332 28 WR0332-30FF4R 3.0V DFN-4 10k/Reel 332 30 WR0332-33FF4R 3.3V DFN-4 10k/Reel 332 33 Quantity Marking* * XXXX is variable. The chip is universal whether the marking has j or not. Contact Information No.1001, Shiwan(7) Road, Pudong District, Shanghai, P.R.China.201202 Tel: 86-21-68960674 Fax: 86-21-50757680 Email: market@way-on.com WAYON website: http://www.way-on.com For additional information, please contact your local Sales Representative. ® is registered trademark of Wayon Corporation. Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. March 2021 – Rev1.5 www.way-on.com 13
