www.msksemi.com
FR101W THRU FR107W
Semiconductor
Compiance
FEATURES
2
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Fast switching speed
1
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
SOD-123FL
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
FR10W
F1
FR10W
F2
MARK
F1
F2
F3
F4
F5
F6
F7
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current at
Ta = 65 °C
IF(AV)
1.0
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load (JEDEC
Method)
IFSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.3
V
Maximum DC Reverse Current
at Rated DC Blocking Voltage
IR
1
50
μA
P/N
Parameter
Ta = 25 °C
Ta =125 °C
FR103W FR10W
F3
F4
FR105W FR10W
F5
F6
FR10W
F7
Units
ns
Maximum Reverse Recovery Time 1)
trr
Typical Junction Capacitance 2)
Cj
15
pF
Tj, Tstg
-55 ~ +150
°C
Operating and Storage Temperature Range
1)
2)
150
250
500
Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A
Measured at 1MHz and applied reverse voltage of 4V D.C
www.msksemi.com
FR101W THRU FR107W
Semiconductor
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARDCURRENT,(A)
CHARACTERISTICS
50
10
3.0
1.0
1.2
1.0
0.8
Single Phase
0.6
Half Wave 60Hz
Resistive Or Inductive Load
0.4
0.2
Tj=25 C
Pulse Width 300us
1% Duty Cycle
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE ( C)
0.1
.01
.6
.8
1.0 1.2 1.4 1.6 1.8 2.0
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50
NONINDUCTIVE
10
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PULSE
GENERATOR
(NOTE 2)
1
NONINDUCTIVE
OSCILLISCOPE
(NOTE 1)
PEAK FORWAARD SURGECURRENT,(A)
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
50
40
30
Sine Wave
JEDEC method
10
-0.25A
1cm
SET TIME BASE FOR
50 / 10ns / cm
50
100
35
30
25
10
5
-1.0A
10
FIG.5-TYPICAL JUNCTION CAPACITANCE
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
+0.5A
5
NUMBER OF CYCLES AT 60Hz
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
trr
8.3ms Single Half
Tj=25 C
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
Compiance
.01
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
www.msksemi.com
FR101W THRU FR107W
Semiconductor
Compiance
1.8± 0.3
0.95 ±0.25
PACKAGE MECHANICAL DATA
1.15±0.25
0.05-0.30
2.75 ±0.25
0.6±0.3
3.7 ±0.30
Dimensions in millimeters
1.4
2.85
1.2
REEL SPECIFICATION
P/N
FR101W THRU FR107W
PKG
SOD-123FL
QTY
3000
www.msksemi.com
FR101W THRU FR107W
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such
as
life-support
systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and
products must not be exported without obtaining the export
license
from
regulations,
theauthorities
such
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“FR104W F4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07571
- 500+0.05940
- 3000+0.04850
- 6000+0.04310
- 24000+0.03834
- 51000+0.03586
