Shenzhen Orient Components Co ., Ltd
OR-357
ORIENT
Photo coupler
Product Data Sheet
Part Number:
OR-357
Customer:
Date:
SHENZHEN ORIENT COMPONENTS CO.,LTD.
Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD
TEL:0755-29681816
FAX:0755-29681200
www.orient-opto.com
Copyright© 2020 Orient .All rights Reserved
1
V7
OR-357
1. Features
(1) Current transfer ratio(CTR : MIN. 50% at IF = 5mA, VCE = 5V, Ta=25℃)
(2) High input -output isolation voltage (VISO=3,750Vrms)
(3) High collector-emitter voltage (VCEO = 80V)
(4) SOP-4 package
(5) Operating Temperature -55 ℃ to 125 ℃
(6) ESD pass HBM 8000V/MM 2000V
(7) Safety approval
UL approved(No.E323844)
VDE approved(No.40029733)
CQC approved (No.CQC19001231256)
(8) In compliance with RoHS, REACH standards
(9) MSL Class Ⅰ
2. Instructions
The OR-357 series device consists of an infrared led, photo transistor detector. They are encapsulated
in a 4 pin SOP encapsulation.
Pin pitch of OR-357 is 2.54mm
3. Application Range
(1) Hybrid substrates that require high density mounting.
(2) Programmable controllers
(3) System appliance, measuring instruments
4. Functional Diagram
2
V7
OR-357
5. Max Absolute rated Value (Normal Temperature=25℃)
Parameter
Input
Output
Symbol
Rated Value
Unit
Forward Current
IF
50
mA
Junction Temperature
TJ
125
Reverse Voltage
VR
6
V
Consume Power
P
70
mW
Collector and emitter Voltage
VCEO
80
Emitter and collector Voltage
VECO
7
Collector Current
IC
50
mA
Consume Power
PC
150
mW
Total Consume Power
Ptot
200
mW
*1 Insulation Voltage
Viso
3750
Vrms
Working Temperature
Topr
-55 to + 125
Deposit Temperature
Tstg
-55 to + 150
*2 Soldering Temperature
Tsol
260
V
*1. AC Test, 1 minute, humidity = 40~60%
Insulation test method as below:
(1) Short circuit both terminals of photo coupler.
(2) No Current when testing insulation voltage.
(3) Adding sine wave voltage when testing.
*2. soldering time is 10 seconds.
3
V7
OR-357
6. Opto-electronic Characteristics
Parameter
Input
Output
Symbol
Min
Typ.*
Max
Unit
Condition
Forward Voltage
VF
1.2
1.4
V
IF=20mA
Reverse Current
IR
5
μA
VR=5V
Collector capacitance
Ct
30
250
pF
V=0, f=1KHz
Collector to emitter Current
ICEO
100
nA
VCE=20V,
IF=0mA
Collector and Emitter
attenuation Voltage
BVCEO
Emitter and Collector
attenuation Voltage
BVECO
*1.Current conversion ratio
CTR
50
600
Collector Current
IC
2.5
30
mA
Saturation Voltage
VCE(sat)
0.2
V
Insulation Impedance
Riso
Ω
80
V
IC=0.1mA
IF=0mA
7
V
IE=0.1mA
IF=0mA
IF=5mA
VCE=5V
Transforming
Characteristics
5×1010 1×1011
IF=20mA
IC= 1mA
DC500V
40~60%R.H.
Floating Capacitance
Cf
0.6
1
pF
V=0, f=1MHz
Response Time
tr
4
18
μs
VCC=2V,
IC=2mA ,
Descend Time
tf
3
18
μs
RL=100Ω
Current Conversion Ratio = IC / IF × 100%
4
V7
OR-357
7. Rank table of current transfer ratio CTR(tolerance:±3%)
CTR Rank
Min.
Max.
A
80
160
B
130
260
C
200
400
D
300
600
No mark
50
600
Condition
IF=5mA, VCE=5V, Ta=25℃
8. Order Information
Part Number
OR-357X-W-Y-Z
Note
X = CTR Rank (A, B, C, D or none)
W = Tape and reel option (TP or TP1).
Y = ‘V’ code for VDE safety (This options is not necessary).
Z = ‘G’ code for Halogen free .
* VDE Code can be selected.
Option
Description
Packing quantity
TP
Surface mount lead form (low profile) + TP tape & reel option
3000 units per reel
TP1
Surface mount lead form (low profile) + TP1 tape & reel option
3000 units per reel
5
V7
OR-357
9. Naming Rule
1.
Manufacturer : ORIENT.
2.
Part Number : 357.
3.
Rank Code
4.
Year Code
5.
Week Code
6.
VDE Code
7.
HF Code ‘G’: Halogen Free.
8.
Anode.
: CTR Rank
: '21' means '2021' and so on.
: 01 means the first week, 02 means the second week and so on.
. (Optional)
6
V7
OR-357
10. Outer Dimension
11. Recommended Foot Print Patterns (Mount Pad)
unit:mm
7
V7
OR-357
12. Taping Dimensions
(1)OR-357-TP
2.54±0.1
(2)OR-357-TP1
Description
Symbol
Dimension in mm(inch)
Tape wide
W
12±0.3(0.472)
Pitch of sprocket holes
P0
4±0.1(0.157)
F
5.5±0.1(0.217)
P2
2±0.1(0.079)
P1
8±0.1(0.315)
Distance of compartment
Distance of compartment to compartment
Package Type
TP/TP1
Quantities(pcs)
3000
8
V7
OR-357
13. Package Dimension
(1) package dimension
Packing Information
Packing type
Reel type
Tape Width
12mm
Qty per Reel
3,000pcs
Small box (inner) Dimension
345*345*45mm
Large box (Outer) Dimension
480x360x360mm
Max qty per small box
6,000pcs
Max qty per large box
60,000pcs
(2)Packing Label Sample
Note:
1.
2.
Material Code :Product ID.
P/N :Contents with "Order
Information" in the specification.
3. Lot No. :Product data.
4. D/C :Product weeks.
5. Quantity :Packaging quantity.
9
V7
OR-357
14. Reliability Test
NO.
1
ITEMS
RSH
耐焊接热
Reliability Testing
QTY.
(Pcs)
22
Condition
260±5℃
Process
10s/3 次
Device
Standard
锡炉
JESD22-A106
高温烤箱
测试仪
JESD22-A103
低温箱
测试仪
JESD22-A119
168 hrs
2
HTSL
高温存储
77
125℃
500 hrs
1000 hrs
168 hrs
3
LTSL
低温存储
77
-55℃
500 hrs
1000 hrs
4
5
TC
温度循环
TS
温度冲击
77
H:125℃ 15min
∫5min
L:-55℃ 15min
300
cycle
冷热冲击机
JESD22-A104
77
H:100℃ 5min
∫15s
L:-40℃ 5min
300
cycle
冷热冲击机
JESD22-A106
高温烤箱
测试仪、老
化电路板
JESD22-A108
ESD静电测
试仪
JESD22-A114
锡炉
JESD22-B102
高温烤箱
,测试仪
JESD22-A103
恒温恒湿
机,测试仪
JESD22-A101
压力锅
JESD22-A102
168 hrs
6
7
8
9
10
11
HTOL
高温操作
ESD-HBM
人体模式
SD
可焊性
HTRB
高温反向偏压
H3TRB
温湿度反向偏
压,寿命试验
Autoclave
压力锅
110°C
IF=10mA
Vce=5V
500 hrs
22
≥8KV 1Cycle
1次
22
Pb-free
245±5℃
5S/1次
77
HTRB
@125℃
Vce=80v
77
77
77
H3TRB
85℃,85%RH
Vce=80v
Ta=121
℃,100%RH,2atm
1000 hrs
168 hrs
500 hrs
1000 hrs
168 hrs
500 hrs
1000 hrs
96hrs
10
V7
OR-357
15. Temperature Profile Of Soldering
(1) IR Reflow soldering (JEDEC-STD-020C compliant)
One time soldering reflow is recommended within the condition of temperature and time profile shown below.
Do not solder more than three times.
Profile item
Conditions
Preheat
- Temperature Min (T Smin )
150˚C
- Temperature Max (T Smax )
200˚C
- Time (min to max) (ts)
90±30 sec
Soldering zone
- Temperature (TL )
217˚C
- Time (t L )
60 sec
Peak Temperature
260˚C
Peak Temperature time
20 sec
Ramp-up rate
3˚C / sec max.
Ramp-down rate from peak temperature
3~6˚C / sec
Reflow times
≤3
11
V7
OR-357
(2) Wave soldering (JEDEC22A111 compliant)
One time soldering is recommended within the condition of temperature.
Temperature
260+0/-5˚C
Time
10 sec
Preheat temperature
25 to 140˚C
Preheat time
30 to 80 sec
(3) Hand soldering by soldering iron
Allow single lead soldering in every single process. One time soldering is recommended.
Temperature
380+0/-5˚C
Time
3 sec max
12
V7
OR-357
16. Characteristics Curves
13
V7
14
OR-357
V7
很抱歉,暂时无法提供与“OR-357C-S-TP-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31789
- 100+0.25235
- 600+0.21948
- 1200+0.21619
- 3000+0.18939
- 国内价格
- 10+0.34679
- 100+0.27530
- 300+0.23944
- 3000+0.20661
- 6000+0.18512
- 9000+0.17442
- 国内价格
- 1+0.30800
- 200+0.19910
- 1500+0.17270
- 3000+0.15290
